Lite-ON made Dell SX280 PSU
  • hardwareguy
    • Jun 2006
    • 405
    Just fixed/modded one of these. Filled with OST and L-Tec caps. No bulging but a lot of mediocre (in case of OST) and bad readings on some of the Ltec caps.
    A weird mix of Nichicon PW, HD, HM and UCC KZE was used to recap it. Mouser's stock was funny this time.
    The main switching MOSFET isnt very good and has a drain-source on resistance of almost two ohms. Swapping this for something more modern results in a cooler running supply. You can FEEL the difference! 2SK2654 was swapped for a Fairchild FQA8N100C.
    Fan was good, unlike the other version of the supply I'm used to (Hipro IIRC). The Lite-ON uses a 60x15mm fan, the other takes a skinny 60x10mm.
    The mobo is weird on this one...all Rubycon MCZ and Panasonic FL except for three Nichicon HNs. Why didn't they go all the way?
  • hardwareguy
    • Jun 2006
    • 405
    Re: Lite-ON made Dell SX280 PSU
    Whoops...its a GX280! My bad.....
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      Had me going with the thread title....was thinking to myself that I've never seen a bad DA-2 PSU (sx280 external, also used on the gx620usff). Made more sense after seeing the gx280 correction.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
      • dell_sadness
        Dell Latitude 3440 - Service tag ending in 0001 - Locked!
        by dell_sadness
        BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
        Have extracted the BIN and want to know how to rebuild a clean BIOS
        I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
        I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
        Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
        11-12-2025, 02:54 PM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
