Repairing bad power supply from Power Mac G4 MDD
  • cyclones
    • 69
    Re: Repairing bad power supply from Power Mac G4 MDD
    I have not had a chance to work on it lately, but will be starting on it again soon. I'm going to replace the main filter cap, which is a cRapXon. Should I replace anything else while I'm at it?
    Also, could someone explain the "light bulb method" to me?
    • Toasty
      • Jul 2007
      • 4171
      >>Also, could someone explain the "light bulb method" to me?<<
      See following thread, Post 23. Good read & same machine PSU.
      https://www.badcaps.net/forum/showthread.php?t=7165
      veritas odium parit
      • cyclones
        • 69
        Any suggestions on rectifier bridge replacement for this PS? Brands, specs? If I'm going to desolder the heatsink assembly again, I might as well replace the bridge.
        • Toasty
          • Jul 2007
          • 4171
          Why? Is it defective? They don't "wear out".
          veritas odium parit
          • cyclones
            • 69
            I just pulled out the heatsink assembly for this one. I'm going to take some high-quality pictures later and post them. Even thought I was being really careful, I almost busted the thermistor. I think it is still OK. I was trying to figure out why the PS still has a dead short in it, and I think I may have stumbled upon something. With the heatsink assembly out, I have continuity between two of the holes for Q2. I can't tell at this point if it's sloppy soldering on my part or something else, but I don't think it's supposed to be that way. The continuity is between the middle pin hole for Q2 and the pin hole towards the edge of the board.
            • cyclones
              • 69
              #26
              I'm going to pull it out and check it, but I think so. After your post, I started doubting myself, but I really think it is. I think this is why I'm getting the weird continuity on the Q1 and Q2 holes.
              We'll see here in a few minutes...
              • cyclones
                • 69
                #27
                Bridge rectifier checks out fine. The + and - holes on the board have continuity. So there must be something else shorting out. Don't know what it is yet.
                • Toasty
                  • Jul 2007
                  • 4171
                  #28
                  Try the Q2 holes with Diode Check function. Should be low one way and high the other. If not, did you pull the Mains cap out?
                  veritas odium parit
                  • cyclones
                    • 69
                    #29
                    I started poking around checking resistance between things and got an itching to take this thing out (see picture -- it's bad; sorry I don't have a good camera with me today). I have no idea what it is, but it looks awfully complex and big for a jumper. It's marked R107 on the board. After removing this thing I removed still has 100% continuity in both directions on its two leads. I then tested the holes for the rectifier bridge and they no longer have continuity. So whatever it is, it is my hypothesis that it's bad and causing the short in the PSU. the only markings are
                    HMR
                    5W 0.06[omega]J
                    I'm not 100% sure on the omega, but it looks closer to that than anything else.
                    • Toasty
                      • Jul 2007
                      • 4171
                      #30
                      5 watt, .06Ω (ohm) resistor
                      It's fine.
                      veritas odium parit
                      • cyclones
                        • 69
                        #31
                        wow way different from the other resistors I've encountered.
                        Any thoughts on where I should look next for the short? Something caused that fuse to blow.
                        • cyclones
                          • 69
                          #32
                          Yep pulled the big cap out log ago. Will try your check on the q2 holes when I get a chance. My recollection is there is no difference whichever direction.
                          • cyclones
                            • 69
                            #33
                            It's fine.
                            My meter measured .04. Assume that's close enough.
                            • cyclones
                              • 69
                              #34
                              This morning I found diode D102 has continuity in BOTH directions. I desoldered it from the board to verify. No resistance either direction.
                              • cyclones
                                • 69
                                #35
                                Only info on this diode is
                                IN5819
                                0340G
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  #36
                                  ONE - N - 5819 ... 1N5819
                                  Schottky diode, 1A, 40v
                                  D101 is the same type. Double-check your measurements. On diode check, both should read about 0.2Ω when forward biased (black probe on banded end).
                                  veritas odium parit
                                  • cyclones
                                    • 69
                                    #37
                                    Double checked them and compared them to the other diode which I had already noticed was the exact same diode type. WAY different measurements. Ordered replacement from Digikey. Came in today. Soldered new diode in and that resistor back in. Checked at rectifier bridge holes for continuity. NONE. Yay! Now I just have to solder the BR back in, the big heat sink, and hook up the light bulb test and check it out.
                                    • JOHNBOY
                                      • May 2010
                                      • 78
                                      #38
                                      Let us know. I have one of the samsungs too and may give it a shot. How long did it take to get the heatsink out.
                                      • cyclones
                                        • 69
                                        #39
                                        Approx. 10-15 minutes if you do it carefully. Take it slow. Use my photos and make sure the thermistor is thoroughly desoldered as Toasty said.
                                        • cyclones
                                          • 69
                                          #40
                                          What kind of resistance should I be getting between the outer two through-holes for Q1 and Q2? I am currently getting about 160 Ohms.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
