Repair of the power supply unit FNP1500-48G
  • muster_alex
    • Mar 2021
    • Ukraine
    Good evening colleagues!
    After purchasing the digital voltage converter Riden rd6018w module, I decided not to purchase a power supply for it, but to restore the non-working FNP1500-48G, which I got a few years ago and power the converter with it. But I cannot restore it due to the lack of firmware for the pic16f818 microcontroller, which is responsible for the operation of the PFC and the synchronization of the MOSFET control drivers, as well as protection for flow and temperature.
    The reason for the failure of the Power-one FNP1500-48G power supply was damage to the MOSFET transistors, followed by the PFC and L4981A control drivers. After replacing the failed elements, it turned out that pic16f818 was also damaged (short for power supply 5V). To start at least in the test mode of the power section of the power supply, you need to know the control and synchronization frequency at the output of pin 8 of the pic16f818 microcontroller. As far as I understand, the firmware in this pic controller is locked from reading by the manufacturer.
    I am asking for help! Is it possible to buy a used pic16f818 microcontroller somewhere with native firmware, or, ideally, one firmware so that you can upload it to a new controller to check the power supply?
    Best regards, Alex.
    • 31087
    Re: Repair of the power supply unit FNP1500-48G
    tech.support@psbel.com
    worth a try
    • muster_alex
      • Mar 2021
      • Ukraine
      Originally posted by stj
      Thanks, I'll try.
      • muster_alex
        • Mar 2021
        • Ukraine
        I tried it! No use, no answer.
        Friends can someone come across and tell me? What is the frequency of the control and synchronization pulses at the output 8 of the pic16f818 microcontroller.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
          07-01-2024, 06:34 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • Gjackson
          Air-conditioning unit power supply failing to power up
          by Gjackson
          Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
          01-08-2022, 09:24 AM
