Delta DPS-200PB-185A Schematic
  • NAVY ET1
    replied
    Re: Delta DPS-200PB-185A Schematic
    These P.S.'s are out of an Interlogix Tru Vision NVR. I just received a new Hikvision NVR by UPS and the P.S. is identical. I opened it up to put the old Hard Drive in and checked the voltage across C801 an it reads 400vdc. They call it an LTS Switching P.S. The voltages out of the new one are 12vdc and 52.6vdc. Thats all the new info I have. LYLE
    replied
    Here is the description of a ring tester
    https://www.youtube.com/watch?v=CFyRO42JMbE
    I hope this helps you
    PFC
    http://power-topics.blogspot.com/200...i-need-it.html
    When I Googled PWA
    I came up with a medical type of switching power supply am I correct about this
  • NAVY ET1
    replied
    This is supposed to be a replacement P.S. from Amazon. I took a peek inside and everything is different. It looks to be lighter weight. The 12vdc output plug is different and the output power ratings are much less. The case looks exactly the same. As for your last comments: It has been awhile since the Navy Schools - please enplane what PFC, PWA, Optic sensor & ring xfmr. are referring to. They have added a lot of new terminology and types of parts in the last years. Thanks for any help. LYLE
  • PeteS in CA
    replied
    That PSU is about 3 1/2 years old, so I doubt it has worn out low value electrolytics. It's a fairly modern model (the 52V output is the clue), so I doubt you'd get a schematic from Delta.
    The layout puzzles me, but it looks like it has active PFC. If so, the 163V at C801 means the PFC circuit is not working, and the outputs are being kept disabled. It looks like it might have two inverters, one for each output.
    The one whose transformer is next to the daughter card looks to be a flyback design, in which the "transformer" is actually a coupled inductor (hence, no separate output inductor). If I'm correct that probably is for the 5V output.
    The other inverter seems to use the transformer near C801, with an output inductor near the corner of the PWA. If I'm correct this probably is for the 52V output, and is probably a forward converter.
    replied
    Do you have a ring transformer tester it might be time to use it on this transformer but before this can you replace change the optic sensor ( to a known working one ) for the 52 volt side of the power supply and see if dose something different than what it is doing now
  • NAVY ET1
    replied
    The fuses are good. I have 163vdc out of the first part of the P.S. across the CAP. C801. the power res. R355 & R505 (.56 Ohm.) do not look real good, they have some marks in the coating on them. The 12 VDC outputs measure 11.5v on one and 10.5v on the other. The 52vdc (POE Power) is dead. I can see volt. on the primary of the trans. It measures the same on all thermals like there is an open in the ckt. No volt on the secondary. The files show how far I have got with trying to figure out the schematic. The board is very tight to see everything. Thanks for any help. LYLE
    replied
    First of all are the low value capacitors below 100uf name brand capacitors if not replace them first then see if any of them work after that
    I would highly recommend that you put an incandescent light in place of the fuse when checking this one if the fuse is blown
    From what you said about one of them that dead what is the voltage across the main filtering capacitor be careful when checking the voltage because this will be high voltage also check the fuse if you have no voltage across the main filtering capacitor
    If you only have 160 some volt then look for the switching power supply regulator ic chip and post the part number for it
  • NAVY ET1
    replied
    I am having a problem with a similar power supply. You asked for some pictures and I have some. I have three of these on my workbench right now. None of them appear to have bad caps but the outputs are low or missing altogether.
    replied
    Please post some pictures of this board that you are working on
  • BruceGilbert
    started a topic Delta DPS-200PB-185A Schematic
    This power supply is dead is there any common failures on these power supplies that would help me get started. Without a schematic I am really fumbling around.
    I do know that it is supposed to have two outputs and I don't have either. The power supply doesn't have that "expensive electrical" smell and I am not able to see anything obvious that is wrong. Any help or suggestions would be appreciated.
    Thankyou
    Bruce
    by sam_sam_sam
    03-31-2024, 02:12 PM
  • Gentian
    Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
    by Gentian
    I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
    09-27-2025, 11:03 PM
  • Russ1
    Starlink GEN2 Router Internal Power Supply Chicony UTP-211C Schematic
    by Russ1
    Sick of seeing big numbers of these routers dead no power light underneath.....
    Chasing Schematic of this power supply I have searched high and low....
    Already spotted a few swollen caps, but Ac fuse ok.....
    This is a dual output 50Vdc 2.5A and 12Vdc 1.25A psu
    Can anyone help with any type of schematic and parts list ?
    Thanks and Regards, Russ
    07-10-2025, 11:01 PM
  • dragon3x
    >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
    by dragon3x
    Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
    that is still quite new, as it worked OK for some months until it failed.
    At the time I was not into power supply electronics; it was put
    aside and a new power supply installed inside the computer. Also at the time
    power supplies were half the price of today's.
    On the PCB there are a D339 and 7500B chips.
    I have found that schematics with these 2 chips (see included file).
    Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
    Some measurements,...
    06-05-2024, 03:34 PM
