Fortron FSP300-60ATV repair
  • everell
    • Jan 2009
    • 1514
    My story starts out last October when a friend gave me a Fortron FSP200-60ATV which was "burned up". Yes it was. See attached photos.
    The two transistor 5vsb circuit was dead. I made an attempt to fix it, but only succeeded in blowing out both transistors again, and the fuse. The culprit on this power supply seems to have been a zener diode which was supposed to have protected the 5vsb from going overvoltage. Instead, the zener went overcurrent, burned, shorted, then caused the rectifier in that circuit to burn. burning both the diode and the pc board. Other parts were also damaged. Due to the burn damage, I decided to use this board for spare parts.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • everell
    • Jan 2009
    • 1514
    Re: Fortron FSP300-60ATV repair
    Last week I got a Fortron FSP300-60ATV, same pc board but not burn damaged. Symptoms were same - 5vsb dead. The main switching transistor was shorted, and the other transistor was blown apart.
    I found this power supply to be most interesting. The brand - Fortron - is the favorite of i4004. The 5vsb uses the two transistor circuit design, but does not have an aluminum "critical" capacitor in the usual location. So this circuit should not have gone overvoltage. Again, the main switching transistor was shorted, and the other transistor was blown apart.
    I decided that since replacing the critical capacitor would not be a fix (it doesn't have one), and due to bad transistors and probably other parts bad, I installed my DM311 mod. On power up, the 5vsb still did not work. Troubleshooting found the problem to be a leaky diode D9 on the secondary side of the 5vsb transformer. Now the 5vsb was up and running.
    Next, I removed the two capacitors which form the pi filter for the 5vsb. Both are 1000 uF/10V OST. I was going to replace them with new Nichicon PW 1000 uF/10V which measured esr = .06......but the two OST capacitors both measured esr = .02.......so I left the OST capacitors in the circuit.
    Voltage measurements after repair:
    12v = 12.16 volts
    5V = 5.18 volts
    3.3V = 3.35 volts
    5vsb = 5.23 volts
    Photos attached to show repaired board before putting it back in case. Also photo of back side of transistor blown apart.
    • xchequer
      • Mar 2009
      • 3
      That looks like a great mod! I had a burned up power supply just like that, that I gave to a friend.
      • yanz
        • Nov 2004
        • 910
        nice work, everell!
        days are so short when you actually do something..
        • everell
          • Jan 2009
          • 1514
          One more photo showing pc board back in the case. Modification can be clearly seen inside the case.
          • everell
            • Jan 2009
            • 1514
            I have a second Fortron FSP200-60ATV, no 5vsb just like the first one, but not burn damaged. I checked ZD1 the zener diode across the 5vsb, and it was shorted. That makes two Fortrons, same model, same problem. ZD1 is located next to diode D9. I removed the diode, applied power, and everything works fine. In my opinion, this is sufficient proof that putting a zener across the 5vsb is NOT a good solution for 5vsb circuits that go overvoltage. It simply shorts zener diodes.
            In the Fortron FSP300-60ATV there was no zener installed at the ZD1 location. The diode D9 was shorted and took out the two switching transistors. So looks like diodes D9 and ZD1 are a good place to start when troubleshooting these two models.
            Two of the psu had shorted/blown switching transistors. I had email from pieti requesting information - his transistors were blow beyond recognition and he needed part numbers. They are:
            FSP200-60ATV: Fairchild FPQF 3N60 and H945
            FSP300-60ATV: ST P3NC60FP and H945
            The 5vsb circuit looks the same for both models. I tried to repair the two transistor 5vsb circuit on the first psu I worked on, but only succeeded in blowing out the transistors again. Repairing this circuit is tricky! So I put the DM311 mod in it and have had no further problems.
            • cagiva4ever
              • Sep 2011
              • 22
              hi !
              i have 2 broken FSP psu's: FSP200-60ATV(PF) and FSP350-60PN(PF)
              the fsp200 i need to fix desperately as its in a Acer Desktop PC that i use at my mom's house (no other PC there).
              Another problem is that i am not in a situation or at a location to buy new same model PSU or a used1 as they dont exists here where i live, so i have to fix what is broken to keep things going-rolling. ordering new1 would cost me nearly 100 euro's or even more.
              problem with the fsp200 is that it wont power up PC, when Power button pressed ON ,the PSU will only "humm" for a second and then dead (Fan wont spin at all at any stage). to get same reaction i need to take the powercable of the wall and let the PSU be unplugged for a while to get even the 1 second humm at Power-Up.
              i have also tryed the PSU separately, meaning all cables taken of the Motherboard, and problem is still exactly the same. Cooling Fan wont spin at all and PSU shows no life at all.
              Prior this problem PC worked wonderfully and while it hasnt been used i have had it OFF the wall, so no Lightning or any voltage spike problem causing this on our house electricity. at 1 day i just went for the PC and was about to Power it up and start using it ,and Nothing happened. Previous use had been working perfectly and PC was powered of normally etc and power cord taken of the wall at the end (because the PC gets usage once~twice a week at mom's so better take of the PowerCard to avoid Voltage Spikes etc Lightning strikes).
              the fsp-350 is a free carbage picking find that i took for spares, and THANKS to this topic im starting to realise how bad quality PSU's these are.
              i strongly think i see 2 small swollen electrolyte capacitors on it (fsp-350). another is next to the D9 diode and the another swollen Capasitor is about 2cm aside. both swollen Capacitors are TEAPO 35v 100uf.
              now a nooby guestion i have to ask, is there only1 D9-diode and only1 ZD1-diode on this pcb design ? i would assume yes based on what i have learned in past 5 minutes, as i havent ever worked with PSU's before.
              i will take some good photos from the fsp-350 pcb soon in couple days and post them on this topic if its ok to topic starter ?
              also i will have a 4th look on the fsp-200 psu and see where the D9 and ZD1 are on it and if it has also swollen tiny 35V 100uf capacitors, as i didnt notice anything such or anything odd in it at previous times.
              i would very very much appriciate Tech support etc help on this issue from Topic starter or other people able to help me.
              bye
              m from Fi
              • everell
                • Jan 2009
                • 1514
                Still waiting for pictures. I located my FSP200-60ATV and have it handy as a reference if you have any further questions. Yes, any capacitors that are bulging are bad and need to be replaced. Also look for glue on parts which is turning dark brown or black. This indicates that the glue is becoming conductive and causing shorts or resistive paths.
                You can use this thread as a place to discuss repairing your power supplies, or you can start a new thread for your power supply problems. Your choice.
                Welcome to the forum. Fixing a power supply can be both fun and interesting.
                • Longbow
                  • Jun 2011
                  • 623
                  My opinion is that your conclusion is a bit hasty. This particular circuit may have other design problems, but the faulty zener is there to protect everything that is downstream, which it apparently did.
                  Is it plugged in?
                  • everell
                    • Jan 2009
                    • 1514
                    More "opinions" please
                    • DSTACY
                      • Sep 2011
                      Does any one have a schematic for this power supply?(FSp300-60ATV0 I cant find D9
                      I am first timer to work on power supplys but work on other things eletronic.
                      • everell
                        • Jan 2009
                        • 1514
                        I started drawing the schematic of this thing about two years ago, but this is as far as I got. Perhaps you can add to it!
                        • cagiva4ever
                          • Sep 2011
                          • 22
                          Still waiting for pictures. ....
                          hi !
                          sorry, i havent been here for a while as i thought my try to get help was blank useless.
                          but now i can see that your active and here.
                          i have dismantled PCB from Case at FSP200 and i have tryed to look faults by my eyes but cannot see anything odd on it at anywhere.
                          apparently the FSP needs a 5v signal voltage from Motherboard to fireup, so i put a jumber wire connection to PSU Green cable and Black at connector block (PSU taken of the PC and Bench testing PSU separately)
                          with this jumper cable the PSU and its cooling fan still only like Blink, like 1 Fan rotation and thats it. with this im trying to say that most likely Problem is In the PSU and not at the Motherboard.
                          i dont know what do do next with my FSP200. any ideas ?
                          i do not have replacement 35v Caps or equivaliment for my FSP350, so i cannot fix it yet. my friend who is more PC geek than i said to me that FSP350 400V (iirc) BIG Caps 2 of them looked Swollen (as they dont have the Split grooves on top its hard to say, as they have like a sticker Tap on top and it can naturally be a Dome'ish shape anyway (?)
                          bye
                          m
                          • everell
                            • Jan 2009
                            • 1514
                            As a quick check, use ohmmeter to check resistance of the diodes....the big ones attached to the heat sink on the output side. Typically they measure a low resistance, but a shorted one will measure ZERO ohms. It should be quite noticeable if shorted.
                            A shorted output diode will give the symptom you are describing.
                            • cagiva4ever
                              • Sep 2011
                              • 22
                              hi !
                              ive been out of internet for many months now, as no internet connection at home, so im using Library's connections once again these days @ village Library.
                              i have now managed to get a replacement ( used) better wattage PSU and it works. Problem now is that there is no Monitor Signal and Monitor doesnt work hence that.
                              maybe my OEM broken PSU did some damage to Motherboard or something, or something else (as i have tryed another working monitor)
                              i will try and find a used working Graphics Card to "replace" the Motherboards integrated1, and see if that cures the Monitors "No Signal" notification.
                              if some1 has ideas what could be wrong, please let me know.
                              meanwhile , as promised, i will now start posting good photos to here from my broken FSP350-60PN(PF) PSU as a data to this great topic.
                              that fsp350 is just a individual item i have found separately as a broken from scrap container..
                              bye
                              m
                              • hctan
                                • Dec 2012
                                • 5
                                • malaysia
                                Hi. what is the color code for R31 and R68 (unable to see clearly burn damaged) near the jumper (J 31) / fuse. Your help in this regard will be highly appreciated. Thanks.
                                • everell
                                  • Jan 2009
                                  • 1514
                                  I found my FSP200-60ATV but could not locate the FSP300-60ATV which I had some time ago. I found the J31 jumper you were referring to, but could not locate R31 or R68. I would suggest that you post a picture of your power supply and draw a circle around the resistors you need information on.
                                  My power supply had a LOT of burnt glue which needed to be removed. I suggest that you remove any dark brown glue before attempting repair.
                                  I think you are describing resistors in the 5vsb circuit. Is that correct? These Fortrons use a two transistor circuit which I have found to be very difficult to repair.
                                  • hctan
                                    • Dec 2012
                                    • 5
                                    • malaysia
                                    Hi. Before that, i wishing all the christianity members a merry christmas. i hope the attached photos below can help me to solved the problem regarding the 2 burn damaged resister color code for R31 dan R68. Any help appreciated. Thanks.
                                    • hctan
                                      • Dec 2012
                                      • 5
                                      • malaysia
                                      h
                                      • hctan
                                        • Dec 2012
                                        • 5
                                        • malaysia
                                        Hi all members. my power supply's resister had burn damaged. so anyone can help me to find the resister color code for R31 dan R68. any help appreciated. Thanks.
                                        • прямо
                                          Viper22A 5VSB circuit
                                          by прямо
                                          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                          01-13-2024, 07:05 PM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • rddube
                                          Lenovo L490 Ram voltage circuit malfunction
                                          by rddube
                                          Hello friends,
                                          Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                          I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                          07-15-2025, 04:41 PM
                                        • Tarot Superstars
                                          Short Circuit tester
                                          by Tarot Superstars
                                          Hello.
                                          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                          Link
                                          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                          https://www.youtube.com/watch?v=0eixDdCpiO4
                                          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                          09-25-2023, 09:11 AM
                                        • M1NEBLANK SHOW
                                          MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                                          by M1NEBLANK SHOW
                                          Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                                          (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                                          Schematic and Boardview here
                                          04-04-2025, 03:57 PM
