Antec SP500P "resurrection"
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Antec SP500P "resurrection"
    Will do, as soon as i get back home, in a couple of hours. "Top down" = photo from the component & heatsink side, right?
    Time zone difference <= i'm currently studying and working in Finland; currently 1:34pm over here
    The 5vsb board is only done "virtually"; i'll enlarge the drain trace anyway, for better heat dissipation. I'll figure out something until i actually etch it / put it together.
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • everell
      • Jan 2009
      • 1514
      Also, before etching that pc board, you might want to add a little more heat sink. See my attached photo as suggestion.
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • Khron
        • Sep 2006
        • 1350
        • Finland
        Yeah, something like that is what i meant by "enlarging the drain trace"
        • Khron
          • Sep 2006
          • 1350
          • Finland
          Ok, here are the results of today's photo shoot: two views of the solder-side (so each side can be well seen in the foreground), one view from the top, and a detail with the PFC section.
          • everell
            • Jan 2009
            • 1514
            Solder side photos look great. Now you might as well remove the other heat sink and its transistors The smaller of the three transistors is the 5vsb switcher which you won't be using. So you will have to remove the heat sink to get it out. Then you can take some photos of the entire top side of the board and we can begin looking for other damage around the switchers. You won't be able to see it very well until that heat sink is out of the way.
            While you have the heat sink out you will be able to measure the transistors for leakage. Also let us know what transistors are being used (markings on the transistors). Mine were D209, yours may be something else.
            • Khron
              • Sep 2006
              • 1350
              • Finland
              #26
              Yeah, i was thinking about removing the other heatsking as well. Gonna do that when i get back home today (leaving for school / work pretty soon; 7:30am here).
              Expect updates in about 8-9 hours from now.
                • 31065
                that's the pfc coil that's desroyed on mine.
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  #28
                  Update: As i was de-soldering the main switchers, i got to the 5vsb switcher, and i noticed there's an exfoliated track (the one that passes under the J6 chip jumper, and maybe under the (MELF) ZD4 (there's some black stuff between it and the board surface).
                  This is somewhat visible in the 3rd photo from my initial post.
                  • Khron
                    • Sep 2006
                    • 1350
                    • Finland
                    #29
                    I ended up bringing the PSU and my soldering gun to school, so here's a couple more photos, the primary heatsink with the silicon, and a "more naked" top view of the board.
                    • Khron
                      • Sep 2006
                      • 1350
                      • Finland
                      #30
                      The main switchers (2SC3320) seem ok (Vbc=436-438mV, Vbe=527-540mV). PFC diode = 392mV, PFC switcher seems ok (483mV with red probe on drain and black probe on source).
                      • everell
                        • Jan 2009
                        • 1514
                        Resistors in main switching circuit don't look burnt - that's a good sign.
                        The value of the burnt resistor (see attached photo) is 22 ohms 5%. I think you will need to replace it!
                        • Khron
                          • Sep 2006
                          • 1350
                          • Finland
                          #32
                          A "sanity check" question: if i remove the blown resistor that goes to the PFC's Vcc (upper right of the standby trafo), it SHOULD stay off, and the coil and diode in series on the V+ shouldn't hurt anything, right?
                          Speaking of which, i don't suppose anyone has a value for that, right? Oh, and then there's the well-cooked zener (i assume), between the two small caps, next to the green NTC...
                          Just thought i'd make sure and try to "cover all the bases" before starting any sort of testing...
                            • 31065
                            i can give you value / part number for anything - i have one in bits myself.
                            • Khron
                              • Sep 2006
                              • 1350
                              • Finland
                              #34
                              That's great The only "anonymous" parts are the ones i mentioned in my previous post. Apart from those, and the resistor that everell mentioned and the PWM, everything else looks ok.
                              • everell
                                • Jan 2009
                                • 1514
                                The bad transistor which caused the burn damage needs to be replaced. See circled parts in attached photo. The diode in the circle is probably bad also. You will not be able to measure it while in circuit. It is just a 4148 diode, very common.
                                • everell
                                  • Jan 2009
                                  • 1514
                                  Remove this transistor from heat sink. The new 5vsb IC will replace this. Just put it in your hope chest (hope you get to use it some day!)
                                  • Khron
                                    • Sep 2006
                                    • 1350
                                    • Finland
                                    #37
                                    That small bad driver transistor is an H945 device. I looked up the datasheet for that, and the 2SC1815 and they seem to be a 95% match (a difference in the ft, but for switching at under 200KHz, that shouldn't be so critical). I've got a few of those recovered from some other psu's so i'll make the switcharoo tonight.
                                    Still wondering about the values of those other two burnt parts i mentioned earlier, though
                                    • everell
                                      • Jan 2009
                                      • 1514
                                      Did you measure the H945 transistor after removing it from the pc board? I am curious as to what you find.
                                      If you change the H945 transistor to a 1815 from another psu board, change BOTH H945 transistor drivers - they are a push pull driver and should be somewhat matched. Using two 1815 transistors off the same board should match close enough - but one H945 and one 1815 MIGHT cause some problem.
                                      Not sure about the zener. Looks like protection for VCC on the pfc chip. My guess is something on the order of 18 to 20 volt zener should work. Perhaps someone else could be more specific. Since the zener is fried, the capacitor next to it might also be bad. Since you are recapping all caps, guess that problem is already solved!
                                      • Khron
                                        • Sep 2006
                                        • 1350
                                        • Finland
                                        #39
                                        I wasn't even considering a "half-arsed" job regarding part replacement. And i'm quite a fan of symmetry anyway, so of course i'll shove in two 2SC1815's. And "of course", that Teapo (with the pattern on top) next to the fried zener is bulged. Haven't seen such small caps bulge too often, though
                                        The PFC chip datasheet says max Vcc's 21V, so i'll see if i can get my hands on an 18-20V zener somewhere at school.
                                        Thanks for all the assistance this far, and i'll keep you posted with any progress i'll make these days
                                        • Khron
                                          • Sep 2006
                                          • 1350
                                          • Finland
                                          #40
                                          I just measured the (first) extracted H945, the one where the burnt trace leads to, and it shows open-circuit all the way, no matter which way i connected the test leads (both diode test and the 200ohm range on the DMM).
                                          • sirpsychol
                                            Antec Earthwatts EA-380 smd element type/value
                                            by sirpsychol
                                            While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                            09-03-2023, 07:58 PM
                                          • ajdrenter
                                            Picking caps for Antec SU-380
                                            by ajdrenter
                                            In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                            https://www.badcaps.net/forum/showthread.php?t=14159
                                            It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                            05-13-2023, 10:40 AM
                                          • CWEastwood
                                            Antec Smart Power SL300S capacitor replacement.
                                            by CWEastwood
                                            I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                            The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                            I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                            Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                            03-25-2023, 12:18 PM
                                          • s_henya
                                            Antec VP-600P and NE550M dead
                                            by s_henya
                                            Got in these 2 nice PSUs, both died after power surge.
                                            Both seems to be suffering from the same fault.
                                            Blown main fuse
                                            Shorted N mosfet 550v
                                            VP-600P: 5R280CE short between GDS
                                            NE550M: MDF18N50 short between GDS
                                            In terns of board layout these seems pretty identical.
                                            From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                                            I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                                            Is it worth to try and replace the mosfets? is there a chance that the...
                                            12-03-2024, 10:00 PM
                                          • GnatGoSplat
                                            Antec BP500U APFC Coil
                                            by GnatGoSplat
                                            Antec BP500U PSU fried in my wife's gaming PC. I smelled something unpleasant last night, so I had a hunch something might be amiss. Woke up this morning to a popped breaker and immediately assumed the APFC cap must have blown. I last fixed it sometime in 2011, there's a thread about it here someplace. APFC and secondary caps that time. Replaced them with Panasonic caps. 10+yrs is probably a good run. It's been running 24/7 the last 3yrs, eth mining with a 1070ti and AFK fishing in Black Desert Online, lol.
                                            Anyway, cracked it open this morning, expecting it to just be the APFC cap...
                                            11-02-2021, 09:22 AM
