Tefal GV8962 Pro Express steam iron - no power
Re: Tefal GV8962 Pro Express steam iron - no power
You are not getting Voltage feeding the D pin of the IC, you need to check the Voltage between the two legs of main filter cap C4 (Green cap next to the resistor) first and also check your soldering works.
BTW, 100 Ohms is too high for that fusible resistor, but of testing purpose t is OK for now.Never stop learning
Arh... indeed, one end of R1 solder joint is done poorly.. Reworked, and now D pin & C1 (I believe not C4) get 325Vdc, and C2 gets 24Vdc.You are not getting Voltage feeding the D pin of the IC, you need to check the Voltage between the two legs of main filter cap C4 (Green cap next to the resistor) first and also check your soldering works.
But pressing the power on/off button still no led light..
*Noted on R1 being a 100 ohm resistor, should get a 2W 8-10 ohm replacement?Last edited by beetle1303; 10-27-2020, 08:24 PM.Comment
At this point you can leave the 100 Ohms resistor for testing for now.Arh... indeed, one end of R1 solder joint is done poorly.. Reworked, and now D pin & C1 (I believe not C4) get 325Vdc, and C2 gets 24Vdc.
So the 24V buck converter is working now, now we need to trace out the other power supply section for low Voltage that is used for running those IC's (U3, U4) next.
So look up the part number of some of those IC's so you can look up the spec sheet to locate the VCC pin of the IC then you can find out if the VCC is present or not for the IC's to run.
Check Voltage of U2, it looks to be LDO Regulator IC.
I also see some bad solder joints, one looks burnt, others you can see ring developing around the joint, so look for ring around the solder joints and resolder them.
BTW, that small white connector, what is connected to that connector?Attached Filesif you find these attachements useful please consider making a small donation to the site
The black color that looks burnt is permanent black marker ink, on the the joints that have wired soldered directly onto. The ring around the solder joints - except for the huge wire joints with black marks, practically all the joints has some sort of indentation. Some looks like a ring, most are just dings. I re-soldered most of them.At this point you can leave the 100 Ohms resistor for testing for now.
I looked up for and these are the 2 ICs:
1) Top, bigger one: PIC16F1933: pin 19 & 20 measure 0.03Vdc
2) Bottom, smaller one: HC595A: pin 8 & 16 measure 0.03Vdc
Pressing power button on/off has no effect on the readings.Attached Filesif you find these attachements useful please consider making a small donation to the site
You need to check Voltages of U2 which looks like LDO Regulator IC.Never stop learning
How do I check this U2?
I put DMM in Volt mode, put black on common pad, and Red on each lead:
Left one reads 23Vdc
Middle and Right ones read 0Vdc
*left side is bulged..Attached Filesif you find these attachements useful please consider making a small donation to the site
I just googled to learn more about LDO. If the picture is a correct pinout of a LDO, then it measured input is 23Vdc, and output is -0Vdc.
Does this mean this LDO is faulty/open?Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/forum/attach...9&d=1603871079
It looks like it is blown up when the high Voltage dump occurred.
Circuit ground for your probe will be the Negative leg of C2, then test Voltage on each leg of that U2.
It looks like the center pin is ground, if that is the case then will not be the same as typical 1117 regulator. You can verify if center pin is connected to circuit ground or not by checking the resistance between C2 negative leg and center pin of U2 to see if it shows <1 Ohm or not. You should also check the resistance of the two outer pins against ground.
If you cannot read the print then it will be hard to figure out what the output Voltage should be, it may rated as the same Voltage for the IC's VCC.Last edited by budm; 10-28-2020, 01:43 PM.Never stop learning
BTW, look real close at C6 and C7 soldering joints connected to U2 pin 1 and pin 3, they do not look right.Never stop learning
Black probe on C2 -Ve, Red probe onhttps://www.badcaps.net/forum/attach...9&d=1603871079
Pin1: 23 Vdc / 146 ohm
Pin2: < 1 Vdc / < 1 ohm
Pin3: < 1 Vdc / 14 ohm
Black probe on Pin2: Red probe on
Pin1: 23 Vdc / 152 ohm
Marking on U2 is completely not readable.
*** Just to be clear: Pin1 is on the left and Pin3 is on the right of the picture I attached.Last edited by beetle1303; 10-28-2020, 10:25 PM.Comment
Pin1 to C6: < 1 ohm
Pin1 to C7: 210 ohm
Pin2 to C6: 180 ohm
Pin2 to C7: 15 ohm
Pin3 to C6: 210 ohm
Pin3 to C7: < 1 ohmComment
As shown in your picture: Pin 1 (Right pin) of U2 is connected to C7, Pin 3 (Left pin) is connected to C6.Black probe on C2 -Ve, Red probe on
I do not understand why your readings show Voltages. Are you checking the resistance of C6 and C7 with POWER applied to the unit while doing resistance test?Attached Filesif you find these attachements useful please consider making a small donation to the site
Sorry for not stating it clearer, I powered on to read voltages, and powered off to ready resistance, and recorded them in the same row..
So my reference of Pin1 & Pin3 is reversed. Based on your picture:
Pin3: 23 Vdc / 146 ohm
Pin1: < 1 Vdc / 14 ohm
Pin3: 23 Vdc / 152 ohm
Pin1: < 1 Vdc / 14 ohmComment
I removed U2 (I don't have a proper tools and skillsets, and damaged Pin3 pad).
With U2:
C6: 178 ohm / 0L on capacitance
C7: 14 ohm / 0L on capacitance
Without U2:
C6: 539 ohm / 103 uF on capacitance
C7: 20.8 ohm / 0L on capacitance
** Pin1 resistance now 20.8 ohm vs 14 ohm previously.Attached Filesif you find these attachements useful please consider making a small donation to the site
Now check the resistance between GND and VCC pins of the IC's.I removed U2 (I don't have a proper tools and skillsets, and damaged Pin3 pad).
With U2:
Without U2:
** Pin1 resistance now 20.8 ohm vs 14 ohm previously.Never stop learning
HP EliteBook 840 G5 + Tefal Daily Cook Saucepan Set Notebook 800 Specification for Upgrade or RepairThis specification for the HP EliteBook 840 G5 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Tefal Daily Cook Saucepan Set boardview and 840 G5 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-06-2024, 09:00 AM
This specification for the HP EliteBook 1050 G1 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Tefal Daily Cook Saucepan Set boardview and 1050 G1 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-06-2024, 09:00 AM
This specification for the HP ProBook 640 G4 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G4 + Tefal Daily Cook Saucepan Set boardview and 640 G4 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-06-2024, 09:00 AM
This specification for the HP ProBook 450 G6 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Tefal Daily Cook Saucepan Set boardview and 450 G6 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-06-2024, 09:00 AM
HP EliteBook 850 G5 + Tefal Daily Cook Saucepan Set Notebook 800 Specification for Upgrade or RepairThis specification for the HP EliteBook 850 G5 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Tefal Daily Cook Saucepan Set boardview and 850 G5 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-06-2024, 09:00 AM
- Loading...
