Re: Tefal GV8962 Pro Express steam iron - no power
https://www.badcaps.net/forum/attach...9&d=1603871079
It looks like it is blown up when the high Voltage dump occurred.
Circuit ground for your probe will be the Negative leg of C2, then test Voltage on each leg of that U2.
It looks like the center pin is ground, if that is the case then will not be the same as typical 1117 regulator. You can verify if center pin is connected to circuit ground or not by checking the resistance between C2 negative leg and center pin of U2 to see if it shows <1 Ohm or not. You should also check the resistance of the two outer pins against ground.
If you cannot read the print then it will be hard to figure out what the output Voltage should be, it may rated as the same Voltage for the IC's VCC.
Originally posted by beetle1303 View PostHow do I check this U2?
I put DMM in Volt mode, put black on common pad, and Red on each lead:
Left one reads 23Vdc
Middle and Right ones read 0Vdc
*left side is bulged..
Does this mean this LDO is faulty/open?
Originally posted by budm View PostYou need to check Voltages of U2 which looks like LDO Regulator IC.
Originally posted by budm View PostAt this point you can leave the 100 Ohms resistor for testing for now.
So the 24V buck converter is working now, now we need to trace out the other power supply section for low Voltage that is used for running those IC's (U3, U4) next.
So look up the part number of some of those IC's so you can look up the spec sheet to locate the VCC pin of the IC then you can find out if the VCC is present or not for the IC's to run.
Check Voltage of U2, it looks to be LDO Regulator IC.
I also see some bad solder joints, one looks burnt, others you can see ring developing around the joint, so look for ring around the solder joints and resolder them.
BTW, that small white connector, what is connected to that connector?
I looked up for and these are the 2 ICs:
1) Top, bigger one: PIC16F1933: pin 19 & 20 measure 0.03Vdc
2) Bottom, smaller one: HC595A: pin 8 & 16 measure 0.03Vdc
Pressing power button on/off has no effect on the readings.
Originally posted by beetle1303 View PostArh... indeed, one end of R1 solder joint is done poorly.. Reworked, and now D pin & C1 (I believe not C4) get 325Vdc, and C2 gets 24Vdc.
But pressing the power on/off button still no led light..
*Noted on R1 being a 100 ohm resistor, should get a 2W 8-10 ohm replacement?
BTW, that small white connector, what is connected to that connector?Last edited by budm; 10-27-2020, 09:39 PM.
Originally posted by budm View PostYou are not getting Voltage feeding the D pin of the IC, you need to check the Voltage between the two legs of main filter cap C4 (Green cap next to the resistor) first and also check your soldering works.
BTW, 100 Ohms is too high for that fusible resistor, but of testing purpose t is OK for now.
*Noted on R1 being a 100 ohm resistor, should get a 2W 8-10 ohm replacement?Last edited by beetle1303; 10-27-2020, 08:24 PM.
Originally posted by beetle1303 View PostYes, D3 no longer show 30ohm. It shows 532ohm in resistance mode, and 579 in diode mode.
C2 shows 0.1v and U1 shows 0.2v between Drain pin and each of all other pins.
Pressing the BP5 Power on/off button has no effect..
does u1 get power from the resistor?
Originally posted by budm View PostSo now you are saying the resistance on C2 no longer show 30 Ohms?
Do you have 24Vdc on C2?
You also need to find out if you also have low Voltages to runs those IC or not
I decided to restore all the good and new components back into the PCB and do a basic continuity check - new 2W 100ohm R1 resistor, new 50v 100uF C2 capacitor, new U1 LNK304, and the original L2 inductor.
All pretty much the same, except now D3 now reads 579 in circuit.
I connect a 40W incandescent bulb between the Live wire of the incoming power. Power on - the incandescent bulb do not light up at all, the I measure to incoming voltage to the PCB - 243V.
But pressing the power button of the device - nothing happened, nothing blown, no led light.. Something component(s) blown opened?
Originally posted by R_J View PostWhy don't you remove C2 and check it out of circuit, or remove it and check the solder pads to find out what is reading 30Ω
Not sure where to trace further...
D3 is basically in parallel with the load through the Low DCR of the Buck inductor, that is why you see 30 Ohms when D3 is measure in the circuit, look at the circuit of the Buck converter then you will understand why.
Originally posted by budm View PostThe buck converter looks to be set up for 24V output, you can verify that by checking the value of the feedback resistor network , that is why the blown up C2 is rated at 50V, twice the operating Voltage.
I would not pull the relay out, you should concentrate on what component are connected to + lead of that filter cap C2. if you check the resistance between the two legs of the filter cap c2 solder pads, what do you get, 30 Ohms?
Originally posted by CapLeaker View Postthe first 2 pictures show a 24v relay not a 12v, the 3rd pic the inductor. The inductor should be ok showing 1.8 Ohms.
With Inductor L2 removed, D3 measured correctly at 579 one way. When removed, it measured 30. Seems to by-passed to a shorted circuit somewhere?
I trace out the relay driver, the buck converter is set to 24V for the relay coils.
Transistor T2 drives the relay REL1
I would not pull the relay out, you should concentrate on what component are connected to + lead of that filter cap C2. if you check the resistance between the two legs of the filter cap c2 solder pads, what do you get, 30 Ohms?Last edited by budm; 10-26-2020, 01:03 PM.
