Ripple decreased by changing cap diameter?
  • tj2
    • Oct 2009
    • 85
    I recapped my AGI BPS-2504-4U 250 W AT style PSU this week and ran into an interesting problem with ripple. The first problem was simply my being a bonehead -- in my haste to check out the recapped unit, I measured the waveform on the scope without putting the PCB back into the PSU case. Wow! There was an awful lot of RF ripple -- more than a hundred millivolts on all rails. That was a dumb idea.
    OK, having calmed down and put everything back together, I got more reasonable numbers, except the +12 V rail still had about 90 mV of ripple. I had replaced the two CapXon 470 uF 16 V caps, one each on the -5 and -12 V rails, with Panasonic FMs of the same capacitance and voltage rating. (The old caps had about 0.2 Ohms of ESR and the new ones about 0.03 Ohms. Nonetheless, the PSU was working OK.) I managed just barely to squeeze in 10 mm caps in place of the old 8 mm ones. I figured that I had ordered the wrong size. These 10 mm caps were each touching an inductor. To make a long story short, I looked through my order and found that I had also ordered many of the 470 uF 16 V Panasonic FMs of the correct 8 mm diameter. (I have no idea why I ordered two different sizes.) When I replaced the 10 mm caps with the 8 mm caps the ripple came down to a more reasonable 30 mV!
    The only explanation for this improvement that I can come up with is that the larger diameter caps, each touching both a straight inductor and the +12 V filter cap, must have managed to couple some ripple from an inductor back into the output, while the smaller diameter caps have a smaller coupling because of the gap.
    • 31029
    Re: Ripple decreased by changing cap diameter?
    that may explain why some of my supply's have thick heatshrink sleeving over some of the caps that go near the heatsink.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      That's why I don't like cramming 12.5mm caps in where 10mm were.
      Mann-Made Global Warming.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        What Series of Capxon were they?
        - Dr Seuss
        • tj2
          • Oct 2009
          • 85
          I believe that they were KM series. I'll double-check tomorrow; the old caps are at work.
            by momaka
            03-12-2025, 03:42 PM
            by momaka
            03-15-2023, 10:17 PM
          • quickname
            Cyberpower 1500AVR UPS repair
            by quickname
            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
            Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
            I decided to verify that the batteries were...
            11-12-2023, 09:57 AM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • SwedishDiesel
            Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
            by SwedishDiesel
            Howdy folks,
            I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
            10-30-2021, 12:47 AM
