Atng
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Atng
    What does everyone think of ATNG?
    I've seen reviews of a couple of rosewill ATNG units.
    They seem to perform well.
    http://www.jonnyguru.com/modules.php...=Story&reid=32
    Look at the voltage regulation, it's almost perfect. Efficiency is kind of bad as well as the PF, but look at the ripple! 35mv dumping 55C out the back! 10mv lower in the cold test. Too bad Fujiyuu on the secondary, though you could always just recap!
    http://www.jonnyguru.com/modules.php...Story2&reid=60
    Those two didn't do as good, not as good in the voltage regulation department, but ripple did pretty good. 12v ripple stayed under 70mv, but 5v and 3.3v ripple was a little high and went out of spec on the (unrealistic) crossloading tests.
  • ss627
    Super Member
    • Mar 2008
    • 52
    Re: Atng
    I find that there are better alternatives for the price. I have 2 CU-500B modular units which I think are built by ATNG.
    I've recapped both units and one of them works perfectly but the other one stopped working after a thunderstorm. I've tried changing the fuse but it blew immediately upon power up. I don't know what else could be wrong with it [MOV?] or if its even worth trying to repair. Overall, I dislike the build quality. The pcb, parts and especially the housing reminds me of cheap retrofitted crapola supplies.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      Re: Atng
      I believe those are sirtec's. The only 500W atng's are non-modular.
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • Antonynl
        What are typical ripple voltages on a laptop motherboard?
        by Antonynl
        I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
        So I have two questions:
        1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
        2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
        Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
        12-09-2022, 06:51 AM
      • Ady2017
        Is there a manufacturers tolerance for ripple?
        by Ady2017
        Hi all
        I need to replace a 680uF 35V SamYoung NXB cap which has got a ripple of 1820. Whilst passing my local little electronics shop I picked up what they had in stock which was a 680uF 35V Panasonic FC with a ripple of 1655.
        As the ripple rating is only 9% below what the original was I am wondering whether to risk it and fit it.
        The catalogues specify a capacitance tolerance of +/-20% but state nothing about the ripple. If there is a similar tolerance for ripple then I might be worrying about nothing. Does anybody know?
        11-13-2021, 11:46 AM
      • Antonynl
        Lenovo 530 Vcore : what is the maximum ripple?
        by Antonynl
        Hi
        I have a Lenovo 530 14ikb i5 8th gen motherboard and it fails to start Windows: it normally dies after I try to load Windows. Getting into bios screen works fine.
        Made some measurements and I suspect that there is to much ripple on the 2 Vcore coils.
        What is normally the maximum ripple allowed on say any of the power supplies? A few %??
        The ripple is on both Vcore as outlined in red in attached photos.
        Could be a bad driver?
        Cheers...
        04-29-2023, 04:59 AM
      • sumilumi
        700mv ripple on Akai Sampler linear supply
        by sumilumi
        Hi fellow troubleshooters. This is my first post on badcaps. I've recently setup an electronics workbench. i'm also building a studio with old equipment bought faulty at low cost.
        I've been into electronics since the mid 80's and particularly in the last few years though only getting hands on with repairs now. My knowledge gaps are significant so I'll be posting here to seek guidance advice and general practical applied learning.
        On my bench today is an old ca. 1993-95 Akai hardware sampler. This runs on both a linear and Smps supply. Both are getting on in age and ripple...
        01-02-2022, 10:12 AM
