I just received the identical unit pictured here . The pictures don't do it justice. It is beastly to behold and requires a 10x magnifier to appreciate the complexity of the circuitry.
It has a PIC16C717 8-bit MCU on that side board behind the output wiring in the second picture. That board alone is a real jewel. Beautifully crafted.
The Problem
Brand new, will not start.
The fan bumps a bit for 1 spin. +5VSB is on and correct.
Loaded it with 2 hard drives and another fan. Fans spin 1 time. Voltages all bounce up a bit then shut down in < 1/2 sec. I have had it to the point where the voltages are oscillating/pulsing near what they should be at perhaps 4 cycles per second.
What am I missing? Does this NEED to be hooked to mobo to work? Is there a sense voltage it needs to see?
Toast
It has a PIC16C717 8-bit MCU on that side board behind the output wiring in the second picture. That board alone is a real jewel. Beautifully crafted.The Problem
Toast
