need some help with resistor values
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: need some help with resistor values
    any thoughts on correct value for R4 ?
    • R_J
      • 9622
      I can make out a 4 and a 0 so it might be a 470 (47Ω) try cleaning it off and see if you can read the number.
      Is it between the ic drive output and the fet gate?
      • petehall347
        • Jan 2015
        • 4448
        • United Kingdom
        i thought 470 too . think its across D7 will check later
        • petehall347
          • Jan 2015
          • 4448
          • United Kingdom
          ok R4 connects from IC to gate so must be gate resistor .
          it also connects to R5 and R11 .
          D7 also connects to ic same pin then to R5 then to gate
          so need to now know correct value for R5 as was earlier thought to be gate resistor i think .
          • petehall347
            • Jan 2015
            • 4448
            • United Kingdom
            looks like same as R27 on this schematic ....page 17
            • R_J
              • 9622
              I suspect R5 would be a low value also, maybe in the 30~50 ohm range? This is just a guess based on other schematics.
              • petehall347
                • Jan 2015
                • 4448
                • United Kingdom
                #27
                i cant even find any schematics with values on the resistors . most schematics i have looked at dont even have the diode and resistor in series . what is the purpose of them i wonder ?
                • R_J
                  • 9622
                  The resistor is used to adjust the mosfet turn on speed and stop gate loop ringing, basically the diode is used to help turn off the mosfet. I suspect the resistor in series with the diode is to adjust the turn off speed.
                  See page 2, it shows this configuration
                  In post #19 I mentioned the ncp1251, It is not a replacement I only mentioned it because the way it operates is similar and the datasheet is in english
                  Here is a Chip-Rail CR6853 datasheet, in english. I suspect it is very close to the CR6855, and you can see how it operates.
                  • petehall347
                    • Jan 2015
                    • 4448
                    • United Kingdom
                    #29
                    thanks for the info .
                    i am not too good at following the calculations . what value resistors would get me in the ballpark ?
                    • R_J
                      • 9622
                      The Chip-Rail datasheet was so you could see what voltages (ie:VDDon) are required to get the ic working which should be similar to the ic on the board (which is likely dead) R6 seems to be 47Ω so I would try a 47Ω for R5 as well.
                      I doubt you would be able to calculate the values from the datasheet, they likely picked them with the operation of the mosfet in mind. Without another board or schematic I don't know how else you will find the exact values.
                      On R9 I can make out a 5, my guess would be it was a 0.5Ω 1~2 watt but I could be wrong.
                      • petehall347
                        • Jan 2015
                        • 4448
                        • United Kingdom
                        #31
                        nice one thanks . will update as to what happens when i have the parts and fitted them . might take a while as have to go away soon .
                        • R_J
                          • 9622
                          Have you priced out a new charger or looked for a good used one? it might be cheaper to go that route then trying to repair this one.
                          • petehall347
                            • Jan 2015
                            • 4448
                            • United Kingdom
                            #33
                            nothing available at all .
                            i did think like i mentioned earlier to get a plug in supply and wire to charging terminals . just need to know the right one to get . original is 18v 1500ma . i guess it should actually be higher than 18v though with the battery being 18v . just crossed my mind with that is there wont be a light to say the battery is charged .
                            • petehall347
                              • Jan 2015
                              • 4448
                              • United Kingdom
                              #34
                              am thinking i could use this . all i need to do is transfer the led part and wire the charger to original box . https://www.ebay.co.uk/itm/Workzone-...ess-Batteries-
                              • redwire
                                • 3912
                                I found typical part values for CR6855 in a 12V 3A power supply and 5N60 MOSFET, and laptop 19V 2.1A application.
                                R9 Current-sense I see a "5" and guess it was 0.56 ohms.
                                R6 Gate drive on I see a "4" and guess 4R7 as datasheet says its 1-5 ohms.
                                R5 Gate drive off ... I would guess the same
                                • Petr0x
                                  Bosch 12V and 18V chargers modification
                                  by Petr0x
                                  Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                  You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                  Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                  05-24-2024, 01:00 PM
                                • flat-earther
                                  Hoover FM216LI cordless vacuum refuses to charge
                                  by flat-earther
                                  I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                  I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                  5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                  So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                  06-06-2025, 03:14 AM
                                • Maggiore
                                  GIGABYTE AORUS 15 X5LF mb GA-X5L Values ​​of knocked down resistors.
                                  by Maggiore
                                  mb GA-X5L
                                  Good day to all, I need help with the values of the knocked down resistors.
                                  04-02-2025, 06:15 AM
                                • motormayhem
                                  Lenovo T460 Only Charges on One Charger
                                  by motormayhem
                                  Laptop Question
                                  I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                  A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                  05-12-2023, 01:46 PM
                                • corrize
                                  Replacing resistor fuse in Sony DV charger
                                  by corrize
                                  Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                                  So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                                  It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                                  06-30-2025, 06:59 PM
