Delta DPS-250AP-62 Schematics?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys does anyone have a schematic for this PSU?
    DPS-250AP-62
    I have the DPS-250AP schematics from elektrotanya but they are not the same
    As far as I can see this PSU (which comes from a Fujitsu TX100 S3 and are not cheap to buy!) has a problem with the standby PSU not running
    When powered on via a light bulb it takes a surge of power then drops to nothing.
    I have about 285V across B+ and B- going to a TNY777 which I am certain is supposed to be the 3.3V SB PSU - but it isn't running and so the main capacitors take a very long time to discharge to a safe level!
    I suspect the main PSU section is probably OK
    But before I take it apart to get the PCB out, which gonna be a bit fiddly to do, I was wondering if someone could kindly give me the schematic.
    Best regards
    Rich
    Follow me on YouTube
    Learn Electronics Repair
    • 31051
    Re: Delta DPS-250AP-62 Schematics?
    get rid of the rubber around the tny chip so you can see if it;s damaged and replace the 2 caps next to it - the small one starts it up.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Sorry - TNY277 not TNY777
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        I cleared off all the rubbery shite. The TNY277 looks OK
        I changed both caps - though to be honest the original ones tested fine on my capacitance and ESR meters. Anyway it made no difference.
        I had to go do some onsite work so didn't get further but tomorrow I'll check for around 280V on pin (Drain) and see if there is 5.85V on pin 2
        There is a funny looking resistor near the TNY277 marked black gold gold which doesn't make sense. It's definitely marked as R801 on the silk screen so it is a resistor for sure. Anyway it's reading about 1M0 in circuit. It's not a start up resistor as the TNY does that internally and I don't know what value it is supposed to be - may that is the problem?
        Rich
        • R_J
          • 9551
          It would be nice to know where that resistor connects, It could be from the feedback/run diode going to pin2
          Maybe there is another band, IE: brown,black,gold,gold (1Ω)
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            Yeah I'll have a look to see where it is. You can see it clearly in the 2nd pic on #4 next to the wire B+, its black gold gold. There is no space for another band before black
            Hmm I wonder if it is supposed to be a fuse inline with B+ 280V because it's right next to that.
            But I never saw one look like that before if it is
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              Oh I'll bet it's that resistor you can see in Figure 1. on the datasheet, connected to + on the HV DC input and the diode cathode
              https://pdf1.alldatasheet.com/datash...T/TNY274P.html
              • R_J
                • 9551
                A picture of the bottom of the board would help to see where the resistor is connected. That resistor could also be in the VCC supply for the pfc ic. Check if it connects to Q901
                The resistor has another color band (violet?) Could it be violet,brown,gold,black? If the resistor ran hot the colors could change slightly.
                  • 31051
                  looks like black, brown, brown, purple to me
                  maybe desolder the transformer and check for broken windings
                  • dicky96
                    Sun Seeker
                    • Mar 2017
                    • 1825
                    • Spain
                    OK guys mystery solved
                    I removed the odd looking resistor - it's Yellow Blue gold gold Black so that would make it 4R6 if it is 4 band as gold is not valid as band 3 of 5 band. Maybe actually it is a 4R7 and the violet has turned blue with age
                    The resistor is open circuit and it is in line with the B+ connectred to Drain on the TNY277
                    The resistor didn't look 'stressed' but I didn't have any 4R7 resistors of that size so I connected 2x 10R in parallel and fitted them
                    I left the light bulb in series with the mains and when powered on it was lit up to about half brightness continually
                    I didn't have any 3.3V standby.
                    Obviously that current draw was too much for a PSU in standby so I checked TNY277 Drain to Source and it's reading about 27 ohms. I removed it and confirmed it is low resistance D-S
                    I guess that explains why the resistor went open
                    I'll order some TNY277, I don't have any in my component stock. As usual Ill order a pack of 5 or 10 as they are cheap.
                    Unless it is really expensive, I always do that when i come across a faulty component that I don't have in stock, on the basis that if I saw one faulty one I will most likely see another at some point.
                    Rich
                    • dicky96
                      Sun Seeker
                      • Mar 2017
                      • 1825
                      • Spain
                      Pic attached
                        MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                        This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 03:40 AM
                      • Junkrepair
                        Calculating ESR from tan delta -- tan delta's dependence on capacitance
                        by Junkrepair
                        I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                        I found this nice little description of the conversion:
                        Calculating capacitor ESR from Tan(delta)
                        https://forum.digikey.com/t/calculat...-from-tan/2633
                        It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                        06-12-2023, 02:45 PM
                        MSI Delta 15 A5EFK-081AU Notebook 15 Specification for Upgrade or Repair
                        This specification for the MSI Delta 15 A5EFK-081AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-081AU boardview and 15 A5EFK-081AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-07-2024, 06:11 AM
                        MSI Delta 15 A5EFK-046UK Notebook 15 Specification for Upgrade or Repair
                        This specification for the MSI Delta 15 A5EFK-046UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-046UK boardview and 15 A5EFK-046UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-07-2024, 05:50 AM
                        MSI Delta 15 A5EFK-088NL Notebook 15 Specification for Upgrade or Repair
                        This specification for the MSI Delta 15 A5EFK-088NL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-088NL boardview and 15 A5EFK-088NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-07-2024, 04:30 AM
