Velodyne switching PSU ?
  • Pong Tsui
    • Feb 2020
    • China
    Re: Velodyne switching PSU ?
    Originally posted by PlayerOne
    Is the problem now fixed? I’m still working on mine and waiting for replacement components to arrive before I can continue.
    One thing I discovered is my original Q3 & Q4 FEP16DTA common anode rectifying diodes (marked on the TO-220AB case as being manufactured by Fairchild Semiconductor...Fairchild is now ON Semiconductor) is now an obsolete component. The obsolescence notification letter that was published at the time lists the replacement component as ‘none’ so finding a suitable replacement requires some careful consideration. I was able to track down MUR1620CTRG and after rereading your post, I realized you may have done the same; although you list the part number as MUR1620CTA. Was this just a typo or was the original component on your board actually an ON Semiconductor MUR1620?
    In any event, I mention this because the FEP16DTA (the original part on my board) description on Digi-Key website states the max current rating is 16A FOR EACH DIODE (the actual data sheet for this part does not distinguish if the 16A rating is for each diode or if it’s for both diodes combined) - please see attached screen shot. The MUR1620CTRG data sheet lists the max current for the device as 16A, which seems to be a match, however it states that this is a combined rating and that each diode only supports 8A. Could this explain why your power supply only lasted a few moments after installing Q3 and Q4 using the MUR1620?
    Another difference between the FEP16DTA and MUR1620CTRG is Peak Forward Surge Current rating; the FEP is 200A while the MUR is rated at only 100A. I have not decided yet if this is significant or not and would welcome any thoughts. My initial guess is it is not significant, but will need to investigate further.
    I also found another possible replacement for FEP16DTA using NTE6244, but it has very similar specifications as the MUR1620CTRG so may have same 8A vs 16A concern described above.
    Would love to know more about your situation and if it has been fixed or if you learned anything more.
    Yes fixed and found out the problem,the main point Q3= MUR1620CTG(common Cathode),Q4 = MUR1620CTRG(common Anode),
    Please refer the U1=IR2153 circuit diagram
    • Pong Tsui
      • Feb 2020
      • China
      Yes fixed,and found out the problem,the main point is Q3= MUR1620CTG(common cathode,
      Q4= MUR1620CTRG(common Anode)
      please refer the U1=IR2153 regulation circuit diagram
      • mr_good_luck
        • Jun 2020
        • Saratov
        Good day, please see the capacity and voltage of the C15 capacitor in the power supply, it exploded, I can not understand what it was originally.
          • Jul 2011
          • 6061
          Originally posted by bianchi77
          all the capacitors are good, it's alive now, thanks guys
          What did you do to fix it
          • ds2010
            • Oct 2016
            • 21
            • Russian Federation
            It is 22uF x 25V.
            Can I please ask you for the favor in return (or anyone who has an access to this Power Supply board).
            Can you please make a photo of the front of capacitor C9 (that blue HV cap) and post it here? It is charcoaled in my unit, and I need to find a replacement, but can't read a marking on it.
            Or at least please re-type all text that appears on it.
            Thank you.
            • vladm74
              • Russia
              #26
              I fixed my SPS. Here are some recomendations and my board scematic.
              1. You have to replace all the electrolytic capacitors even if they look good. Note that C7, C10, C12, C13 and C14 must be LOW ESR. At this step just remove them from the board and go to the next step.
              2. Check MOSFETs Q1 and Q2. Replace both even if just one of them is bad. Check gate resistors R7 and R9 if your MOSFETs are shorted.
              3. Check the diode bridge BR1 and all the diodes including zener D3 and D4.
              4. Check the NTC mounted on radiator. It must be shorted.
              5. After checking and replacing bad elements solder new capacitors.
              6a. If you have oscilloscope, put 15V DC from any power source to U1 (+1pin, -4pin) and check oscillogram at pins 7(HO) and 5(LO). You are to see identical meandres. If not, replace U1 IR2153 and test again.
              6b. If you don't have oscillascope and your MOSFETs was bad, replace U1.
              7. Apply mains power. I highly recommend doing this through a 75-100W incandescent bulb. It will prevent MOSFETs from burning out.
              8. Check all the voltages at the connectors J3, J4 and J5, and if they are ok, let it idle for a while watching there is no smoke or smell. Check the voltages again. Disconnect mains power.
              9. I highly recommend to replace all the electrolytic capacitors on amp and pre-amp boards too. Especialy the two big ones on the amp board.
              10. Connect amp and pre-amp to SPS and supply mains power through a incandescent bulb. You are to hear relay clicking. Check all the voltages again. Let it work for a few minutes watching there is no smoke or smell. Recheck the voltages.
              11. If everythint is ok, assemble the subwoofer and check it.
                03-31-2024, 02:12 PM
                07-01-2024, 06:34 AM
              • DynaxSC
                Extreme High Current & Low Voltage Short Killer ??
                by DynaxSC
                Hi Folks
                I'm looking for a extreme high current short killer solution for a reasonable cost.
                I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                After taking off the socket, the shorts dissappear again.
                The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                10-15-2024, 10:13 AM
              • Stephen
                MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                by Stephen
                I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                02-06-2025, 12:03 PM
              • adelfr2009
                HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
                by adelfr2009
                I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
                After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
                09-28-2025, 10:21 PM
