APC Back-UPS Pro BP1000I Issue.
  • CidiRome
    • Jan 2015
    • 49
    • Portugal
    Hi there.
    I'm trying to troubleshoot an APC Back-UPS Pro 1000VA BP1000I that is not working correctly and I don't know where to start.
    If I turn it on without load it will start ok and switch to battery without issue, but if I put loads on it it will start beeping and the overload led will turn on despite the load being not even close the the maximum load this UPS can support. (I will try to access the maximum load it will withstand without overloading)
    This is a fairly old UPS, but I know it is good quality and it is better that most newer ones, specially the cheap ones.
    Any ideas where I should start troubleshooting this problem?
    Cheers.
  • petehall347
    • Jan 2015
    • 4423
    Re: APC Back-UPS Pro BP1000I Issue.
    check battery first
    • FrozenHaxor
      • Jun 2015
      • 260
      • Poland
      They tend to do this when battery has high internal resistance. It will show you good voltage but won't have any grunt behind it.
        Always check battery with load, open (no load) Voltage may show good on the meter but it does not mean if the battery is good.
        • AJ847.63e
          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
          by AJ847.63e
          Hi Folks,
          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
          05-06-2025, 10:37 PM
        • Chippa
          Asus m4a785td-m Evo motherboard bios load issue
          by Chippa
          Hi, help needed if anyone can spare any knowledge for me.i understand its an old spec now but been reliable enough for me until this.
          bootup suddenly doesn't show bios screen/menus.So can't do anything!🥴
          I don't know how to upload video of what happens.
          So I have screenshot 4 pics of what happens when power button pressed.
          1st beep from board sounds normal,
          Bios screen should show up.
          I always have connected from onboard hdmi port to TV.
          Tried VGA lead same issue.
          Also tried swap ram,and clean everything.
          But with no luck.
          System is...
          02-23-2024, 02:07 PM
          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 02:20 PM
          HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
          This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
          09-06-2024, 10:56 AM
          HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
          This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
