Vision Fitness T9700 treadmill motor controler/power suuply dead
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    i found a nice higher end vision fitness T9700 treadmill..i would like to attempt at repairing it
    it seems is dead..i get 0dcv to the top display panel
    the motor controller board is where the 115vac is input at and there is a circuit breaker at that location too.
    on the motor controller/power supply board there are several led status lights that are all off...according to the serv manual they should all be on to indicate that portion is ok
    the 2 fuses on the board are good
    the circuit breaker seems to be ok
    there is a power switch that lights up when plugged in
    i do have 115v throughout the motor controller board
    but the unit is dead...nothing turns on and no display panel power on at all...no sounds nothing
    any ideas what i can test?
    see photo stock photo of the motor controller board
    any help would be appreciated..its a nice treadmill would love to keep it out of landfill or not have to scrap it
    thank you
  • shelby5041
    • Feb 2009
    • 1505
    Re: Vision Fitness T9700 treadmill motor controler/power suuply dead
    correction controller and supply
    • R_J
      • 9606
      This does'nt tell us much, Do you have 115v (AC) between LINE & NEUTRAL next to the transformer? (the red led, D38 AC should be lit)
      If you do have 115VAC at those points, REMOVE POWER and check the resistance between those same two points, that will check the resistance of the transformer primary
      • shelby5041
        • Feb 2009
        • 1505
        Hi
        Yes i have 115v at terminals next to transformer
        • shelby5041
          • Feb 2009
          • 1505
          No red leds are lit at all on the board
          • shelby5041
            • Feb 2009
            • 1505
            None of the red status leds are lit when power switch is turned on
            • shelby5041
              • Feb 2009
              • 1505
              I will double check the 115v next tomtransforemer when i can...just very odd that none of the status red leds are lit
              • shelby5041
                • Feb 2009
                • 1505
                What should resistance be when checking the line/neutral points? And also what could be explanantion of all status red leds not lit up?...those arent all controlled bybtransformer are they?
                • shelby5041
                  • Feb 2009
                  • 1505
                  Unless all the leds are dcv fed
                  • R_J
                    • 9606
                    You do know you can edit a post? instead of making the thread a mile long.
                    If you have 115 volts at the transformer primary, Check the primary resistance, it could be around 10~100Ω
                    • shelby5041
                      • Feb 2009
                      • 1505
                      Hi
                      Yes i have 115v next to transformer and checked resistance between the two pins and get 29 ohm
                      • petehall347
                        • Jan 2015
                        • 4440
                        • United Kingdom
                        check the fuses and plug connections and power switch
                        • shelby5041
                          • Feb 2009
                          • 1505
                          Fuses all good
                          Power switch good lights up when turned on and i have 115v
                          Connections good
                          Caps not bulged
                          No visually burned components
                          What about the relay in the center of the board?
                          Taking a pic of bottom board not possible now...as its in storage
                          Board part # is 013732-B
                          • R_J
                            • 9606
                            Check if you are getting 115vac across the primary of the transformer, then you should have ac on the secondary windings, check them. If you get secondary ac on the secondary windings, check for DC on the secondary capacitors
                            Upload a clear straight on picture of the bottom of the board
                            • shelby5041
                              • Feb 2009
                              • 1505
                              hi rj here is an actual photo of back of the board i have..
                              • R_J
                                • 9606
                                I suspect the A/C line connects to the two terminals labeled Line & neutral
                                Can you check if you have a/c on the two secondary windings? As for the relay, it requires 12 volts to operate the coil, that 12 volts must come from a 12 volt supply which is likely from one of the transformer secondaries. There must be a standby voltage from somewhere.
                                The picture helps, but being double sided its almost imposible to trace.
                                I am guessing, but it looks like D38 (AC) led should lite with a/c applied to Line and Neutral. It looks like line connects to D33, then to R15? and should light D38
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  thanks currently the board is out of the machine..removing and installing requires a lot of time due to design...is there anyhting i can check while out of machine?
                                  i tested all 3 1000uf caps and they all test ok
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    yes ac line connects to line and neutral near the transofrmer and as i have said none of the status led lights on the board light up and i assume if the external circuit breaker near the power switch was not working i would get no 115ac voltage....so since i have 115acv and the light switch illuminat3es means the circuit breaker is ok....its very odd that none of the led status lights are on..
                                    • R_J
                                      • 9606
                                      You should be able to connect 115vac to the line & neutral with the board removed, just be carefull. Then you can measure the voltages.
                                      There is a trace that connects from the neutral contact to one side of D38 (led) The line contact should connect to the anode of D39 (diode above R123) Check if this is correct.
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        hi rj
                                        interesting...when i connect 115v to board outside of the machine i get the follwoing red leds to light up
                                        D38 115v
                                        D34 18v
                                        D33 vcon
                                        maybe i should reinstall in machine and start removing connections to see if one of the items is causing entire board to not power on???
                                        what do you think rj?..if the board shows life outside of machine and not when installed in machine that would be my guess
                                        • G0RIT
                                          Reebok one GT40s treadmill lift motor runs at switch on
                                          by G0RIT
                                          Good evening I am working on a Reebok oneGT40s treadmill. It had a flashing display which the replacement of D3 rectified. However the lift motor now runs when the mains is turned on and does not stop. If I then select start so the tread motor runs and disconnect the up lead to the lift motor it stops. If I then reconnect the lead the lift motor works as it should with the controls. It will continue to work correctly until the mains is turned off and on again, or the safety device is removed and replaced. It then runs again and only by disconnecting and reconnecting the up lead will it operate...
                                          06-23-2022, 05:57 PM
                                          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch boardview and ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-12-2024, 02:30 PM
                                          HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch EliteDesk 800 i5-9500T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch boardview and EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          HP EliteDesk 800 G3 + Fitbit Flex 2 Fitness Wristband EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + Fitbit Flex 2 Fitness Wristband can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + Fitbit Flex 2 Fitness Wristband boardview and EliteDesk 800 G3 + Fitbit Flex 2 Fitness Wristband schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-12-2024, 02:00 PM
