Re: Few questions from a beginner
I use the same method (solder sucker) of ratdude747 for PSUs because they are single layer.
For MOBO I use solder sucker and sewing needle, I learnt to use it reading on Badcaps.
When I can, I bring stuff in office where I can use a desolder station, much better than solder sucker. Unfortunately they are expensive and for the amount of work I do at home I really don't need one.
About using solder sucker when I have to free an hole on a MOBO I heat the hole with the solder on one side and I remove the solder with the solder sucker from the opposite side. Usually it works but on some holes I have to use the sewing needle because I'm not able to remove completely the solder with solder sucker.
Willawake is right about solder debris but cleaning very often the solder sucker reduce the risk.
Ciao
Gianni
Ciao
Gianni
