This is a sticky topic.
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!
A very dusty Macase MG-250EP AT 250W unit.
Board is dated 04/01/95, QC test dated 04/12/97 and the internals is covered in cobwebs and spider exoskeletons. "Quaranty Lapses After Removal"
The insides started off looking good with a Delta AC socket and Panasonic primaries, as well as sockets for the AC input and fan, then went downhill from there by exclusively using Fuhjyyu throughout the rest of the board. Eighteen of them. Surprisingly, none have bulging tops yet, except for one suspect-looking primary (although this could simply be the plastic 'lid' on the cap). I just can't see how a Panasonic could be outlasted by those tiny Fuhjyyus though!
C5: Matsushita UP 470uF 200V 85C 6928
C6: Matsushita UP 470uF 200V 85C 6929C
C10: Fuhjyyu TNR 1uF 50V 105°C
C11: Fuhjyyu TNR 1uF 50V 105°C
C14: Fuhjyyu TNR 220uF 25V 105°C
C15: Fuhjyyu TNR 220uF 25V 105°C
C16: Fuhjyyu TNR 2200uF 16V 105°C
C17: Fuhjyyu TNR 1000uF 16V 105°C
C18: Fuhjyyu TNR 470uF 16V 105°C
C19: Fuhjyyu TNR 470uF 16V 105°C
C20: Fuhjyyu TNR 1uF 50V 105°C
C21: Fuhjyyu TNR 10uF 50V 105°C
C24: Fuhjyyu TNR 47uF 35V 105°C
C25: Fuhjyyu TNR 4.7uF 50V 105°C
C26: Fuhjyyu TNR 4.7uF 50V 105°C
C27: Fuhjyyu TNR 47uF 50V 105°C
C28: Fuhjyyu TNR 4.7uF 50V 105°C
C29: Fuhjyyu TNR 2.2uF 50V 105°C
C91: Fuhjyyu TNR 10uF 50V 105°C
C92: Fuhjyyu TNR 10uF 50V 105°C
I still have the original tower case for it as well, and it has enough slots to house five hard drives (six if you swapped out the floppy). Two hard drive bays rest right underneath the PSU. There are three 5.25" drive bays.
It would have been a decent server case back in its day, however being of AT design there isn't really any use for it now - you can't even fit a MicroATX board in there because it fouls the rear HDD/PSU area (I wouldn't care about dremeling out the keyboard port to fit the back of an ATX mainboard).
Anyway, try pushing down on the plastic top. If it goes flat, they're probably fine.
FSP200-60ATV 200W OEM power supply from my Acer T310 desktop. This PSU worked without failure running 24/7 for 6.5 years (late Dec 2005) up to June 3 2012, where a power cycle rendered it unable to do much more than turn on the power LED for a second (after draining the leftover power from the caps and turning it back on, it was completely dead). There were no faults in operation prior to shutting down the PC to add/test a PCI SCSI card.
In the following images, the fan has been removed - I clipped the wires since I couldn't be bothered desoldering it. The 80MM fan is a Yate Loon Electronics D80SM-12 (0.14A), which didn't actually spin that fast compared to other 12V fans I have (Globe fans are quite fast by comparison).
Every single cap is from Teapo, with the exception of a single Jamicon hiding amongst the transformers. Even the miniature one on the fan control board is a Teapo 10uF 35V. There are four bulging caps, probably more have failed but are not physically deformed. There were two resistors (R47, next to possibly-failed 1uF 50V C39; R51, next to failed 3300uF 10V) which had got very hot during its last minutes of use, leaving scorched dust marks on the case, and the glue around R47 and its miniature friends shown in picture 7 had turned brown and crispy (I have since removed it). No PCB markings yet, since there's that nasty yellow glue all over the board; I can't make out most locations and there doesn't seem to be a schematic for the 200W version.
The big boys are Teapo LXK 470uF 200V 85°C 05/04.
Nice power supply there.
Originally posted by Heihachi_73In the following images, the fan has been removed - I clipped the wires since I couldn't be bothered desoldering it. The 80MM fan is a Yate Loon Electronics D80SM-12 (0.14A), which didn't actually spin that fast compared to other 12V fans I have (Globe fans are quite fast by comparison).
Originally posted by Heihachi_73Every single cap is from Teapo, with the exception of a single Jamicon hiding amongst the transformers. Even the miniature one on the fan control board is a Teapo 10uF 35V. There are four bulging caps, probably more have failed but are not physically deformed. There were two resistors (R47, next to possibly-failed 1uF 50V C39; R51, next to failed 3300uF 10V) which had got very hot during its last minutes of use, leaving scorched dust marks on the case, and the glue around R47 and its miniature friends shown in picture 7 had turned brown and crispy (I have since removed it). No PCB markings yet, since there's that nasty yellow glue all over the board; I can't make out most locations and there doesn't seem to be a schematic for the 200W version.
Originally posted by Heichachi_73The big boys are Teapo LXK 470uF 200V 85°C 05/04
If you don't mind me asking, how many power cycles did that machine have with that PSU in it (in total)?Last edited by Wester547; 06-14-2012, 01:52 AM.
Originally posted by Heihachi_73 View PostEvery single cap is from Teapo...There are four bulging caps, probably more have failed but are not physically deformed.I love putting bad caps and flat batteries in fire and watching them explode!!
Originally posted by Wester547 View PostIf you don't mind me asking, how many power cycles did that machine have with that PSU in it (in total)?
So far my next [victim] PSU has been on 24/7 since June 3 (although it's a 2010 model with everyone's favorite Fuhjyyu primaries visible through the honeycomb grille at the rear). See how long it fares, even if it makes 2 years it will be long enough for me to upgrade from this dinosaur to the next generation of PCs. I'm also thinking of dropping Windows like a ton of bricks, since my reaction was when I was loaned a Windows 7 laptop overnight earlier this year. I already can't get used to the default XP themes, the first thing I do with a junk-find PC is change it to the 'Classic' Windows 2000 look! Kubuntu time, if the GUI doesn't crash every 5 minutes and kick me to the bash screen whilst failing to reload the interface without a reboot (bad experience with Kubuntu 10 on an IBM ThinkCentre 8191KMQ - both the full install and the live DVD did the exact same thing).
Delta DPS-266AB Rev.01 (266W Max.) ...custom size PSU from VAIO PC
I own this PSU it is right now powering a P4 based PC (Cedarmill), this photos are before the recap ...like 7 months ago, sorry didn't take pics after recap was done, maybe next time it need some cleaning.
Bridge Rectifier is GSIB 1560
Primary Cap 1x 1500uf/200V Nichicon GN Series
Primary Side MOSFET W20NK50Z
5VSB Switcher TNY267P
Schottkys:
2 x MBR3060PT
2 x STPS3045CW
1 x STPS20100CT
Didn't have the time to trace what rail use each schottky...any guesses here?
Original caps:
+5VSB - 1 x 2200uf/10v Taicon PW - 1 x 1000uf/10v Ltec LZG
+3.3v -2 x 2000uf/6.3v Rubycon ZL
+5v - 2 x 2000uf/10v Ltec LZG
+12v -1 x 2200uf/16v Rubycon ZL - 1 x 1000uf/16v Rubycon ZL
Caps used for recap:
+5VSB - 1 x 2200uf/10v Nichicon HE - 1 x 1000uf/10v Rubycon ZL
+5v - 2 x 2000uf/10v Rubycon ZL
+12v -1 x 2200uf/16v Rubycon MCZ - 1 x 1000uf/16v Rubycon ZL
I know... overkill but that was the only one I have at hand in that moment.
I doubt if you had to replace the Ruby ZLs. Even junk caps like CapXon and LTEC usually do OK in delta power suppliesI love putting bad caps and flat batteries in fire and watching them explode!!
Originally posted by c_hegge View PostI doubt if you had to replace the Ruby ZLs. Even junk caps like CapXon and LTEC usually do OK in delta power supplies
Originally posted by goodpsusearch View PostMCZ is a very bad choice for psu recapping.Last edited by SIDMX; 06-14-2012, 11:07 AM.
Yes, but most of the failures I see happen much sooner.I love putting bad caps and flat batteries in fire and watching them explode!!
This PSU is out of my parents Dell rig. Pentium D 3.4GHz/4M/800, 2.5GB 667, Reference GeForce 6800GT 256MB, 64GB SSD. I remember setting this thing up for my parents when it arrived on our doorstep on 3/3/06. I figured it was time to check the PSU and make sure that all the caps were okay..plus I was curious I thought it was going to be a Delta unit....but it looks more like a Liteon PSU...that big ass thing, is that passive PFC?
I was surprised to see 820uf primary caps. Unfortunately they're OST @ 85C...
All the secondary caps are OST and Ltec. Looks like they have some pressure between the vent stamps but not a full on bulge. Should still be working okay?
I'm surprised to see the caps in pretty good shape after almost 6 and a half years, about 8 hours of use a day. Only been cleaned a few timesLast edited by Pentium4; 06-23-2012, 05:57 AM.
Originally posted by Pentium4 View PostThis PSU is out of my parents Dell rig. Pentium D 3.4GHz/4M/800, 2.5GB 667, Reference GeForce 6800GT 256MB, 64GB SSD. I remember setting this thing up for my parents when it arrived on our doorstep on 3/3/06. I figured it was time to check the PSU and make sure that all the caps were okay..plus I was curious I thought it was going to be a Delta unit....but it looks more like a Liteon PSU...that big ass thing, is that passive PFC?
Originally posted by dmill89 View PostDefinitely a LiteOn. Can tell from the model # L375P (the L at the front means LiteOn). Yes that big coil on top is for the passive PFC. The caps look ok (although OSTs are famous for failing without any visual signs), the "bulges" between the vents appear to be from the stamping process. However Ltec and OST are not particularly great brands (far from the worst but mediocre at best) and that secondary appears to run relatively hot, there is little room for airflow, and caps are right up against hot components such as coils and heat sinks (those 2 small Ltecs right against the heat sink could definitely be cause for concern). These Dell units with the fan in the front (inside of chassis) don't get the best airflow and do tend to run a little hot.
Whats its rotation speed? These things often do not have speed controll and such a fan on full speed can do lot of airflow.Less jewellery, more gold into electrotech industry! Half of the computer problems is caused by bad contacts
Nice power supply there, overall.
Originally posted by Pentium4 View PostI was surprised to see 820uf primary caps. Unfortunately they're OST @ 85C...
Originally posted by Pentium4All the secondary caps are OST and Ltec. Looks like they have some pressure between the vent stamps but not a full on bulge. Should still be working okay?
Originally posted by Pentium4I'm surprised to see the caps in pretty good shape after almost 6 and a half years, about 8 hours of use a day. Only been cleaned a few times
One other thing I noticed is the yellow glue on those primary capacitors, in your Liteon. Is it safe to have that in a PSU? I've heard it can eventually eat components off the PCB, kinda like the tan/brown glue in some PSUs, though I hope that doesn't hold so (not to scare anyone, just something I read).
Also, even though the heatsinks are bunched up together, that fan does look and sound nice. What brand is it (if I may ask/if you know)?Last edited by Wester547; 06-23-2012, 02:51 PM.
