Free power supply
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Free power supply
    YAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAYYYYYYYYY!
    http://www.antec.com/Believe_it/Even...0520/award.php
    For the TP550, third name, thats me. Free Antec TP550.
  • Nama
    • May 2009
    • 127
    Re: Free power supply
    Good Job!!!!!. I love free stuff!!.
    ^Learning to walk on rice paper without leaving a trace,
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
    • CMCM
      Russound CA4 Power Supply Repair
      by CMCM
      Hello Everybody,
      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
      The outputs marked 12v and 20v are all measuring only 1v.
      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
      The capacitors physically look clean (no bludgesor leaks) and...
      07-03-2025, 01:12 PM
