Bad caps in FSP FX700-GLN
  • hardwareguy
    • Jun 2006
    • 405
    Bad caps have brought down an Epsilon series 700W supply. Culprits are 8x20mm 6.3V 2200uF CapXon KF series units.
    Unit shut down gracefully and was nice enough to spare the dual Opteron server.
    Said server now has a Seasonic S12 650...which is full of UCC caps. The FSP unit will be recapped and held on as a spare.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Bad caps in FSP FX700-GLN
    recapped seasonics are good.
    could you please post pictures of the dead one so we can assess quality and value of a potential recap. some are worth it, others are not (aka deer, a-power, etc.)
    sigpic
    (Insert witty quote here)
    • hardwareguy
      • Jun 2006
      • 405
      There are pics inside the PSU quality thread IIRC.....It's definitely worth a recap!
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Save for a few bummer caps an FSP FX700-GLN is a great PSU.
        I use one for testing dual xeon server boards.
        It's one of those that uses a higher switching frequency [so smaller xfmers] and double components of the silicon [diodes, rectifiers, ect] so less heat and smaller heatsinks.
        Mann-Made Global Warming.
        - Dr Seuss
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
        • madscientist750
          Replacing electrolytic caps by solid caps on old motherboards
          by madscientist750
          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
          10-19-2025, 06:10 AM
