Enermax Revolution87+ 850W high pitched noise
  • MichR
    • Jan 2016
    • 42
    • Italy
    Here we go again with another PSU!
    Because of the last two successful repairs a friend of mine brought his Enermax Revolution87+ 850W power supply. He complains that his PSU emits an annoying whining when using the PC in idle.
    Actually it's true, it's really annoying and disappears on higher loads (for instance when running a game). On idle, this whine is louder whenever I do something (e.g. move the cursor or a graphic element, such as the scroll bar on a web page). I assume that, since output voltages are constant, the whine is definetely caused by a change of current (supplied when doing something indeed).
    Because of this, I must think the issue is caused by an inductive element in the PSU. Starting from that, I tried to find the culprit using the straw method, but couldn't really understand where it comes from. So, I reversed the schematics involving the inductors and transformers present on the secondary side. The schematics is attached below. Pictures of the power supply can be found here.
    The switching controller, a CM6901, works at 125kHz on the test setup (a motherboard+cpu, without ram, so looping in POST) and a variation of the controller's internal oscillator frequency causes a louder and different whine. The whine definetely comes from one (or both?) of the two transformers T1 or T2, or maybe from the inductor L1.
    What should I do to clearly understand which one of these emits the whine? If it's a transformer, what can I do to fix it?
  • oldmanhouse
    Panasonic TX-L50B6B | High pitched noise and black lines
    by oldmanhouse
    Hi folks, I have an issue with my 7 year old Panasonic TX-L50B6B that has appeared within the last few days.
    The symptoms are:
    • A high pitched "buzzing" / "whining" noise coming from the TV when it is turned on. There is no noise during standby, and the noise persists with all AV connections removed.
    • There are noticable horizontal lines in the picture. Upon closer inspection it looks like every few rows of pixels are dead/black.
    Attached is a close-up of the picture in "test mode", to demonstrate the rows of black lines.
    07-09-2020, 06:30 AM
  • tony359
    by tony359
    11-28-2023, 05:18 AM
  • MegaZAC
    Onkyo TX-SR805 noise in one channel
    by MegaZAC
    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
    There's some logic behind it. As soon as I select an input I get only left...
    04-23-2025, 10:09 PM
  • courtcircuit
    Philips HTS8000 home cinema noise problem
    by courtcircuit
    Hello
    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
    Removed each of tyhe boards
    02-08-2025, 08:22 AM
  • Camarada78
    MXR Carbon Copy High Pitched Noise
    by Camarada78
    I have a MXR Guitar Pedal here that turns on, passes audio but does not add the effect. It has a high pitched squeal that varies tone depending on delay speed.
    Its a analog delay pedal using four BBD (BL3208A), one compander (SA571D), one clock (cd4047), one TL082 and one 33178.
    This pedal is prone to some issues (ESD), but i replaced the common faulty transistors and the problem remained. In fact, the original ones were still good (tested on component tester).
    Anyone familiar with this pedal to give me some light?
    06-07-2021, 02:33 PM
