Well, I just joined the club. And the forum! Antec TP 550 EPS died.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Well, I just joined the club. And the forum! Antec TP 550 EPS died.
    Originally posted by i4004
    bonez, that's a coil that's part of output pi filter...
    HOG WASH
    The toroidal coils are NOT the PI filter inductors.
    i4004, you need to stick to something you know about, like antique TV's.
    The output PI filter inductors are circled in yellow.
    Mann-Made Global Warming.
    - Dr Seuss
    • i4004
      • Oct 2006
      • 2029
      you know about element markings on the pcb, right?
      what letter is used to mark those things u call "torroidal transformers"?
      and what letter is used to mark 2 "other"(hehe) transformers?
      anybody home, bonez?
      put more of that medicine on your moustache, it's making you silly beyond belief!
      oh yeah
      >"Should be" ?
      It is, that's exactly what I said.
      i was talking to corbin. look
      "corbin, uc3845 should be main supply pwm controller, not the 5vstby's...."
      see?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        A Torroid with 2+ windings is a Transformer whether you like it or not i4004.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I mentioned the Toroidal Transformer as point of reference to assist corbin in locating on the PCB where I was talking about.
          Your useless erroneous argumentative BULLSHIT is helping NO ONE.
          - Dr Seuss
          • i4004
            • Oct 2006
            • 2029
            no, you just wanted a fight with me.
            now that you've lost it you're using excuses.
            essentially your piece about coil being trafo is just a spam in this thread.
            stop making clown out of yourslef and let the man answer questions which might actually help him.
            read the remainder of the thread to learn something about troubleshooting psus.
            basics of electronics lesson you just attended ends now.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              You are full of shit Idiot4004. - That one is a flat out lie.
              And ~EVERYONE~ can see it. - You are fooling no one!
              I was giving corbin the PCB layout and you picked through it to find something to start an argument about just for the hell of it.
              It is self evident by your behavior that your SOLE purpose in being here is to start arguments.
              It's certainly NOT to actually help anyone.
              No one [except you] believes that you are here to help. - For good reason.
              - Dr Seuss
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Hey hey hey hey
                settle down now you two.
                • clcorbin
                  • May 2009
                  • 13
                  #28
                  so you have 300v being supplied to that oki chip, yet nothing appears on 5vstby trafo(it's the smaller trafo of the two)?
                  where did you see 10khz signals? they end on mosfet? checked that mosfet?
                  should be mosfet that supplies 5vstby's primary.
                  The 10khz signal is generated by the oki50 chip and is present at the gate of the MOSFET. The duty-cycle is only 16usec, so there is no way it is turning that FET on. I don't have an isolation transformer, so I don't want to hook my scope up to the nonisolated AC/DC on this side of the board to get more information on what is coming out of that chip.
                  by pwm ic do you mean oki or uc? they should both be makinbg pwm pulses, if oki indeed is chip that's making oscillations on primary side of 5vstby trafo..
                  I have not tested the other chip at this point. If the oki50 is for the standby, then I am looking in the right place at this time.
                  again, pix would be handy....esp. around 5vstby supply...and that oki chip...
                  Sorry about that. Both digital cameras where out of the house yesterday and didn't get back until this afternoon. I'll take some pics and see if I can do half as good a job as some of you at labeling things to better explain what I have measured and where those signals were.
                  --Clint
                  • i4004
                    • Oct 2006
                    • 2029
                    #29
                    oki-dokey..
                    <wink>
                    if it can't trigger the fet you should check passive components around it and pray it's not ic itself, as it's seems it's some custom job (if oki50 is all that's written on it)
                    something else; perhaps it's latched into protection as a result of short on secondary, or even trafo windings...
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      I have several TP and TP2 here to look at and none of them have an Oki IC.
                      Where is it on the PCB?
                      It may be something with alternate parts in production.
                      - Dr Seuss
                      • clcorbin
                        • May 2009
                        • 13
                        #31
                        I might have a winner: shorted primary on standby transformer. I pulled it out to measure the resistance on the primary and secondary sides and this is what I got:
                        Secondary: 0.32 ohms.
                        Primary 1: 0.53 ohms.
                        Primary 2: 1.65 ohms.
                        Do these numbers sound even close to normal?
                        Here are a few pics with some labels to clarify things some (I hope):
                        Here is the back of the board with the labels
                        Here is a shot of where the standby transformer used to be. Note hot spots around diode D20
                        Different angle of the standby transformer's location to show the other diodes around it
                        While the transformer was out, I also ohmed out the two pair of primary pads. The pads for both pair of windings showed completely open. I also tested the six diodes around this transformer and they all tested as good, even the one that appears to have been very hot.
                        After powering up the supply with the transformer out, I was seeing the 324VDC at the pad for one leg of the primary coil and I could hear a bit of electronic humming going on (I generally have better than average hearing). I went ahead and soldered the transformer back in to verify the voltage readings at the primaries and secondaries and got this:
                        324VDC at pads P1a and P1b (in and out of the first primary coil)
                        0VDC at pads P2a and P2b (in and out of the second primary coil)
                        0VD at pads S1a and S1b (while there are four pins on the secondary side, they are wired together in pairs by the transformer and by the PCB)
                        For the record, all of my DC voltages where measured relative to the point labeled "DC 1 REF" (aka: ground). The voltage on the secondary coil was measured across S1a to S1b.
                        Ideas?
                        --Clint
                        • i4004
                          • Oct 2006
                          • 2029
                          #32
                          hard to say without numbers from the working unit.
                          bonez should pull that trafo from his unit and measure it.
                          i have 3 supplies i'l be dismantling(pulling the caps and sending them to bonez, he likes used caps...) so i could check values on those....won't be done tomorrow, i'm afraid...
                          and it doesn't have to be relevant for you...
                          those burn marks are suspicious, yes, as there shouldn't be much load there(or overall on 5vstby supply).
                          (offtopic/ bonez, cy3 connects primary and secondary ground... <wink> /endofftopic)
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            i4004
                            I fail to see what CY3 has to do with anything at all here.
                            The only possible reason to bring it up is to instigate another arguement.
                            And just because you'd rather aquire your used caps from from dumpsters (or where ever) for free vs buying mine or KC8's doesn't me -we- like them.
                            Reusing old caps is totally YOUR thing.
                            clcorbin
                            I have plans tomorrow but I might be able to pull one of those transformers Monday.
                            What are the markings on it?
                            I have both TP and TP2 here in various watts and there should be an exact match in the mix somewhere.
                            - Dr Seuss
                            • i4004
                              • Oct 2006
                              • 2029
                              #34
                              any plans to acquire some sense of humor?
                              all the teasing and jokes are flying right by you...
                              (psssstt: it's rhetorical..don't answer it...)
                              i won't tease you anymore...in this thread...hehe...
                              (but next time you say psu has toroidal trafo i will...such things deserve tease...)
                              (you don't have to address this either, just skip it...please...)
                              i pronounce our lil feud over. undoubtedly you'll soon repeat i use used caps(which is your fabrication...and a thing you seem to believe..you don't use it as a joke) and then i'll tease you again. untill you figure out the truth, which is that i don't.
                              i tease you because you're extremely stubborn.
                              cool off, already.
                              • clcorbin
                                • May 2009
                                • 13
                                #35
                                PCBONEZ,
                                The transformer is marked:
                                E216944 CWT 0519
                                09L190042-ON
                                Viking B-2 Class 130(B)
                                It looks like it is a custom transformer as I couldn't find much of anything about it online.
                                --Clint
                                • clcorbin
                                  • May 2009
                                  • 13
                                  #36
                                  I'm not sure just how relevant it is, but I had a small standby transformer from another old power supply lying around (a couple of it's power transistors decided to go burn in hell). Both the primary and secondary coils measured around 0.3 ohms.
                                  That's in the ball park with this one. They are totally different PC power supplies, but I would guess that most of the basic functions will be very similar just because they are all trying to do the exact same job.
                                  Now I'm starting to wonder if that PWM IC has decided to pack it in or is latched due to an overload.
                                  --Clint
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    #37
                                    Replace the 47uF cap and see if it comes back to life. Grab a close value from another supply if you have one. Up to 100uF would be okay, and a voltage at or above its present rating. Just to see if it comes back, then you can get the correct one.
                                    I don't think an ohmmeter test of that transformer will reveal much unless you're getting a reading from the P1 pins to the P2 pins or either show a reading to the secondary, that may indicate a short. Or not. Without knowing how the transformer is wound, or manufacturers resistance specs, it is difficult to say.
                                    Toast
                                    veritas odium parit
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      #38
                                      If the 5vsb is having a problem the PWM chip is doing its job by preventing the PSU from starting.
                                      veritas odium parit
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        i4004
                                        My plans are none of your business.
                                        I do have a sense of humor but YOU never say anything funny.
                                        PSU's DO have toroidal transformers, there's a photo of one earlier in the thread.
                                        And YOU do NOT have the power to call the war over.
                                        You are only permitted to surrender unconditionally.
                                        - Dr Seuss
                                        • PCBONEZ
                                          Grumpy Old Fart
                                          • Aug 2005
                                          • 10661
                                          Originally posted by clcorbin
                                          PCBONEZ,
                                          E216944 CWT 0519
                                          09L190042-ON
                                          I have that one. That PSU is already apart too.
                                          0519 is just the date code. All the rest of the numbers are exact matches.
                                          They are custom, they are built by or for CWT. [Channel Well Technologies]
                                          CWT built most of the PSU's for Antec for several years.
                                          - Dr Seuss
                                          • omega
                                            Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                                            by omega
                                            Hello all,
                                            as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                                            Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                                            02-09-2024, 03:34 PM
                                            HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                                            This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                                            09-06-2024, 11:39 AM
                                          • harp
                                            Comparing FreeNAS, FTP server, SMB server, multimedia server...
                                            by harp
                                            I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
                                            I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
                                            Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
                                            What is general difference between this products, and what be most useful...
                                            01-04-2024, 02:44 PM
                                          • Fireballcz
                                            Windows 2016 server L2TP/IPsec VPN - two subnets
                                            by Fireballcz
                                            Hello, please how to properly configure VPN in this environment?
                                            I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
                                            Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
                                            2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
                                            I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
                                            I have no problems with VPN connection...
                                            07-29-2022, 03:20 AM
                                          • frans00000001
                                            Supermicro Server mainbaord x10dri-ln4+ schematic
                                            by frans00000001
                                            Good day
                                            I am looking for a mainboard schematic for a Supermicro Server mainbaord x10dri-ln4+ as the track broke off on the BIOS chip and I want to repair to use the server again. If possible can someone assist to get this schematic?
                                            08-06-2025, 05:36 AM
