Antec cp-850
  • indy_chuck
    • Aug 2018
    Antec cp-850
    Hello, I have the ANTEC CP-850 power supply that died on me and unfortunately it's a pretty specific power supply that fits in only one of 3 towers (I have the Antec P183).
    I'd like to have my CP-850 refurbished or repaired due to it sort of being such a specific power supply for the case it's intended for, not to mention it was pretty expensive.
    ANTEC has a power supply "test" to confirm if it's the power supply that's dead or if another component is the culprit (motherboard, HDD, CPU, etc.). It did not pass their test by jumpering a couple pins together on the 24 pin connector, so I'm assuming the problem is within the power supply itself and not another component of the desktop.
    Is there a reputable forum member that anyone can recommend on repairing my CP-850?
    Thank you,
    indy_chuck
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Antec cp-850
    As I suggested in PM, check to see if the +5V Standby is OK, typically a purple wire:
    PeteS in CA
    • indy_chuck
      • Aug 2018
      Re: Antec cp-850
      I have a big 0.00 VDC on pins 7 and 9 (purple and black).
      • PeteS in CA
        • Aug 2005
        • 3581
        Re: Antec cp-850
        Time to unplug the thing and open up the case. Or just replace it. The problem is somewhere between the inlet and the 5VSB regulator.
        If nothing is splattered around the inside of the case, I'd start with checking the fuse. If it's open that probably means you have shorted PFC (if it has active PFC) or Inverter MOSFETs.
        If the fuse is OK, find out if there is high voltage (~300V without PFC, ~400V if there is) to the 5VSB regulator. If there isn't, the problem is between the fuse and the 5VSB regulator. If there is high voltage present, then you need to find out why the regulator isn't working. At this point both output electrolytics and small value electrolytics in the 5VSB regulator primary side are prime suspects.
        Hopefully someone familiar with this PSU model can help you from here. I'm just going by my familiarity with common PSU design architecture.
        PeteS in CA
        • indy_chuck
          • Aug 2018
          Re: Antec cp-850
          PeteS
          This is starting to get too complicated vs. simply replacing it, with the exception of the fuse. I'll open the shroud and have a look around for the fuse.
          Since I'm leaning toward the power supply needing replaced, based on age and make, do you have any suggestions on quality power supplies I can look at when making a power supply decision for my desktop?
          It's been pretty consistent that my last 3 desktop builds have all experienced power supply failures, albeit they've provided a good 4 or 5 years of life, I'd still like to invest in one that is more reliable as well as repairable.
          Thank you for any input or suggestions you can offer.
          indy_chuck
            master hoarder
            • May 2008
            • 12175
            Re: Antec cp-850
            Post some pictures of the inside of your power supply, and hopefully we should be able to guide you with those to continue with PeteS's troubleshooting steps above, which are pretty standard in how to troubleshoot really any PC PSU.
            You will just need a multimeter and familiarize yourself on how to use it (there are videos on that on YouTube and some other websites).
            Of course, it all also depends on your time. If you don't have a whole lot of it, then replacing the PSU may be a better option. On the other hand, if you do like DIY, you may find this fun.
            As for replacement PSUs, what makes this PSU so special that you can't use just any other regular off-the-shelf ATX PSU? For example, if it's size (like you mentioned in your first post), what are the constraints of the case? Also, what kind of fan should the PSU have, in case that's a problem too? 80 mm, 120 mm, or 140 mm?
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              03-31-2024, 02:12 PM
              07-01-2024, 06:34 AM
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
