HP Power Sup?
  • ivtec
    • Dec 2008
    • 1967
    HP Power Sup?
    Hi guys;my HP power sup failed to work=
    https://www.walmart.com/ip/HP-Pavili...-65W/834703083
    now i have in my scrap another power sup,i tried it and it fits and works,.
    Now my question is it safe to use it = https://www.amazon.com/PK-Power-ADP-.../dp/B06XHJLHTJ
    Thanks for your input .
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    Re: HP Power Sup?
    Well, HP and Dell have totally different middle pin functions.
    HP power adaptor middle pin has around 10-19V (analog ID) while Dell has up to 5-6V onewire (digital ID) communication. (Although it actually uses 12V to enable programming mode but that is for a short time, not constantly applied)
    I wouldnt use a HP charger on Dell but Dell charger on HP should be safe enough to connect. The problem is that your laptop might refuse charging like my HP did when middle pin was broken. Might be different on other models tho.
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
      03-31-2024, 02:12 PM
      09-06-2024, 05:59 AM
    • meraklinetx
      Asus Z97-a power cycle, no boot no cpu voltage
      by meraklinetx
      Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
      05-10-2023, 06:08 AM
    • Joe24
      2070 Super with crazy power consumption numbers
      by Joe24
      Have a Gigabyte 2070 Super with some bonkers power draw readings. Card runs fine, other than some GPU throttling because of the power numbers. But GPU power always reads too high, more than the power reading for the entire card. And VRAM power always reads way too low, along with PCIe and 6-pin power readings. The 8-pin reading seems plausible.
      Typical readout while running 720p Furmark, 8x AA:
      GPU clock: 1590 MHz
      Mem clock: 1750 MHz
      GPU temp: 58.8 °C
      Hot spot: 71.8 °C
      Fan speed: 33% / 1000 rpm
      Mem used: 454 MB
      GPU load: 97%
      02-03-2023, 02:07 AM
