psu ac240as-01 dell Optiplex 7010 pc tower
  • matser
    • Apr 2012
    • 30
    • Austria
    #61
    Re: psu ac240as-01 dell Optiplex 7010 pc tower
    OK, then I will give it a try without lamp.
    • matser
      • Apr 2012
      • 30
      • Austria
      #62
      First it works, then I put the PSU in the PC, also works. I go the BIOS, then I try to reboot and the room was dark. At the moment I'm not in the mood to disassembly it once again and take a look if the fet is shorted again.
      Anyway thanks for your help stj, I think I give up now.
        • 31288
        worth atleast checking if it was the fet or the vdr failed.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5093
          • New Zealand
          #64
          Fizzing sound may have been tracking/arcing somewhere in the primary section.
          Did you clean the flux off well after you did the work?
          -David VanHorn
          • matser
            • Apr 2012
            • 30
            • Austria
            #65
            @stj: The fet is shorted again. I don't think the CM6800 is bad (the new one shows nearly the same values at meassuring without fet, as the old one). I have another fet in reserve, but as long as I don't know the real guilty part, it doesn't make sense to give it another try. I meassured and compared (diode mode) every part of the primary side with a good PSU and didn't find any differences. OK, there where some differences at the voltages of CM6800 but why isn't clear to me (as I mentioned, I'm not a electronic technician). Where do I find the VDR? Should look similar like the caps which I changed.
            @Agent24: It seems the fizzing sound was from the fan. I did some greasing and it looks like it was gone (maybe also because of switching on without lamp), but the PSU was running maybe about 1-2 minutes, after that the fet was shorted again.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5093
              • New Zealand
              #66
              Were those blown capacitors, C6 and C10, part of the snubber network for the FET? Did you get correct values for replacement? Are there any other components in the snubber network? If any parts are open circuit in that area you would get problems.
              -David VanHorn
              • matser
                • Apr 2012
                • 30
                • Austria
                #67
                I'm sure stj gave me the right values for C6/C10, on one of these caps I saw 300 (or 333nF) at 1KV, stj recommended one 680nF at 2KV for these 2 caps, which I did on every PSU I have left. Hopefully the broken C6/C10 caps are the reason for the PSU failing (I saw also broken C6/C10 caps, but the PSU was still working!).
                Sorry, I'm not sure how to isolate or find the "snubber network"? But I didn't find any great different values by measuring (via diode mode) and comparing the values of the components of the primary side with a good PSU.
                • kaldeis
                  • Feb 2023
                  • Poland
                  #68
                  Hi guys. Can u tell me what value is in R107 and R26 ?
                  • kaldeis
                    • Feb 2023
                    • Poland
                    #69
                    in attachment
                    • Air-Sidney
                      • Jul 2019
                      • Россия
                      #70
                      R26 - 39 Ohm
                      R107 470 Ohm
                      R105 or w14... - 0 Ohm
                      • metsys
                        • Apr 2023
                        • Netherlands
                        #71
                        Today got the same PSU with exploded M5 tny280pn which may be caused by broken C6 and C10.
                        On one the piece was marking 331K 1KV
                        Waiting for parts to replace
                        seems like this caps is crap in this PSU
                        • Ndabu
                          • Jul 2022
                          • 6
                          • Albania
                          #72
                          Originally posted by Taruga
                          5 Band resistor
                          BLUE RED WHITE GOLD GREEN
                          63 Ω ?! If my eyes got the right colors
                          Thank you very much , God bless!
                            DELL OptiPlex 7010 OptiPlex 7000 i3-3240 Specification for Upgrade or Repair
                            This specification for the DELL OptiPlex 7010 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7010 boardview and OptiPlex 7010 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                            09-12-2024, 02:20 PM
                            DELL OptiPlex 7010 OptiPlex 7000 i5-3470 Specification for Upgrade or Repair
