psu ac240as-01 dell Optiplex 7010 pc tower
    • 31288
    Re: psu ac240as-01 dell Optiplex 7010 pc tower
    i would try swapping the chip,
    but before you do, if you want to check the input it may not react how you want because of the pfc circuit.
    if you leave the mosfet out then in theory you can plug it in and check the power on the cm6800 pins
    and see if the standby is running
    • matser
      • Apr 2012
      • 30
      • Austria
      #42
      If I understand right, I put out the mosfet, plug the PSU in and meassure the voltage on the CM6800 and can the values compare with the working PSU?
      • matser
        • Apr 2012
        • 30
        • Austria
        #43
        On the bad PSU I put out the mosfet plug it in and compared with the good PSU I found a difference on a transformer on pin 3 (see attached picture) between good and bad PSU. The other voltages I found, where exact or nearly the same between both PSU.
        Transformer bad PSU
        pin 1: 312V
        pin 2: 1.590 up to 1630V
        pin 3: 306V
        Transformer good PSU
        pin1: 312V
        pin2: 1.600 up to 1670V
        pin3: 462V!
        On IC CM6800 where no voltages measurably. But I haven't tried to switch it on via shorting pins on the ATX plug (neither the good nor the bad PSU).
          • 31288
          i was going to say that you probably need to power it up to get power to the chip.
          but i forgot
          what your seeing on pin3 is probably caused by the pfc booster,
          does the 5v standby have 5v on the bad psu?
          • matser
            • Apr 2012
            • 30
            • Austria
            #45
            I appreciate your help very much stj, thanks!
            I compared now the values of CM6800 on both PSU, there are some big differences. What I should mention is, that I have connected a consumer (HDD) on the good PSU!
            Pin...Bad PSU....Good PSU
            01:....7,26..........0..........IEAO
            02:....1,5...........1,4
            03:....0..............0
            04:....4,8............3,6.......VRMS
            05:....9,84..........0..........SS
            06:....3,95..........2,59.....VDC
            07:....2,56..........2,52
            08:....0,75..........0,18.....RAMP2
            09:....0..............0,01
            10:....0..............0
            11:....5,64..........1,2.......PWM out
            12:....0,06-0,1....1,3.......PFC out
            13:....13,97........13,2
            14:....7,59..........7,49
            15:....2,53..........2,5
            16:....0,46..........0,77.....VEAO
            Do you think this IC is broken because of the differences?
              • 31288
              does pin5 have a capacitor on it?
              btw, pins 11 and 12 you need to meter the frequency, not the voltage because they will be pulsing
              • matser
                • Apr 2012
                • 30
                • Austria
                #47
                I found only a small SMD capacitor. Measuring with diode mode shows the same values on both PSU. Measuring farad seams not to work soldered in, shows 0 also on both PSU.
                @pins 11 & 12: OK, but I only have a multimeter and a second one for measuring capacitors.
                  • 31288
                  so your multimeters dont do frequency?
                  all mine do.
                  • matser
                    • Apr 2012
                    • 30
                    • Austria
                    #49
                    Unfortunately it seems to me not, only V, A, Ω and hFE.
                      • 31288
                      "voice" ??
                      • matser
                        • Apr 2012
                        • 30
                        • Austria
                        #51
                        It's the name: Mc Voice M-930L
                          • 31288
                          o.k.
                          well if your willing to risk a fet, try swapping the cm6800 if your sure there are no bad transistors between it and the fet.
                          but use a 60w lamp bulb in series with the power to limit the current.
                          you may stop the fet blowing like that.
                          • matser
                            • Apr 2012
                            • 30
                            • Austria
                            #53
                            I suppose to buy a new CM6800 and try it with this one, then I can leave the working PSU as it is.
                            Where should I connect the 60w lamp bulb?
                              • 31288
                              in series with the mains supply - like a fuse.
                              • matser
                                • Apr 2012
                                • 30
                                • Austria
                                #55
                                The new CM6800 arrived today, I soldered it in and also connected a 60W lamp bulb in series with the power main in, also I shorted the green/black cable of the ATX connector to switch on the PSU. After connecting with main power, the lamp bulb goes on and off, also the PSU does so (fan begins to spin, slow down, spins... so did also the green led on the back side of the PSU). The fet still seems to be ok, after this test.
                                Is this a sign, that I may try it without the lamp bulb, or is there still something wrong?
                                  • 31288
                                  remove the green/black link first and see if the 5v standby runs with the lamp still in circuit
                                  • matser
                                    • Apr 2012
                                    • 30
                                    • Austria
                                    #57
                                    I have 5V on the violett cable of the ATX connector.
                                      • 31288
                                      then you can try it with a higher wattage lamp if you have one - or risk the fet a run it direct
                                      i reccomend a bigger lamp 100w or more
                                      • matser
                                        • Apr 2012
                                        • 30
                                        • Austria
                                        #59
                                        I've tried it also with a 100W lamp, nearly the same, but I forgot to mention, that I also have connected a HDD. Without this HDD, the fan is spinning, but the green LED on the backside shows no light neither with the 60W nor the 100W lamp. Also there is a fizzing sound coming from the PSU.
                                          • 31288
                                          a lot of psu's dont run well without a load, thats probably the fizzing
                                            DELL OptiPlex 7010 OptiPlex 7000 i3-3240 Specification for Upgrade or Repair
                                            This specification for the DELL OptiPlex 7010 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7010 boardview and OptiPlex 7010 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 02:20 PM
                                            DELL OptiPlex 7010 OptiPlex 7000 i5-3470 Specification for Upgrade or Repair
