ICT12012-10A Comm Series folds back under load (fixed)
  • CapLeaker
    Leaking Member
    • 8352
    Here is a ICT Comm Series, model ICT12012-10A power supply.
    Complaint: Folds back to 9.3V under load (40W VHF radio).
    So I open this up and see nothing visual. Took another look with my ESR meter. AND? Yeah, all caps besides the main filter cap are bad. It got a full recap, including the main filter cap.
    Replaced: C7 200V 330uF, C10 35V 22uF, C15 35V 100uF, C18 35V 47uF, C 27 35V 10uF, C28 63V 47uF, C32 and C33 16V 2200uF.
    Another PSU saved from being tossed into the bin.
    • Jul 2011
    • 6070
    Re: ICT12012-10A Comm Series folds back under load (fixed)
    How is this unit
    • CapLeaker
      Leaking Member
      • 8352
      What do you mean? How old is it? 7 years, been running 24/7/365.
      • CapLeaker
        Leaking Member
        • 8352
        I have another exact same power supply on my bench with the exact same problem as the original one.
        I did the same thing, recapped everything. Just this one had a new "feature"! After the recap, the PSU worked just fine as long as I didn't exceed roughly 4 to 4.5A. After that she instantly dropped down to 0.5V. After a couple of educated guesses, I found out R28 to be the problem. Replaced it and all is good.
          • Jul 2011
          • 6070
          Very good job repairing this power supply
          Yea one less item in the landfill
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8716
            hams? use switching power supplies? Thought they'd all go Astron...
            (eh... my VHF and UHF radios are connected to an Xbox PSU... yeah, so I use a switching PSU...)
              • Jul 2011
              • 6070
              So how did you modify a Xbox PSU to work like this I sure would like to know
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8716
                PSU is a PSU of course of course... what's so special?
                Then again I did mod it from 12V to 13.8V IIRC, but I had a vague recollection I or someone posted the mod somewhere.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8716
                  [Threadjack]
                  Ahh ... was https://www.badcaps.net/forum/showpo...1&postcount=18 not clear on what I did? I just soldered that 36K resistor on top of R318 so i cid not need to remove the old one. Forgot what the value of the original resistor there....
                  • CapLeaker
                    Leaking Member
                    • 8352
                    Yeah, you never know when you need one!
                    Well, switching PSU's are fine for VHF / UHF and that's where this was used in a commercial application.
