Samsung DLP primaries...in series?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    So I have this 8 year old DLP. It has two CapXon LP's that are surprisingly in series. Ive seen most of these in parallel on most power supplies. This hooks directly to the lamp ballast, that has a bloated cap I replaced. It bloated after I recapped it with a Panasonic EE. I'm assuming this was because of the dried out capXon LP's
    getting replacements have been difficult, as almost all 200v 470u has been rated at 2.2Arms. Highest i've seen at mouser have been like 1.8Arms
    what margin of error do I have here? Would these POS's actually be rated @ 2.2A out of the factory, being that they're capXons?
  • R_J
    • 9633
    Re: Samsung DLP primaries...in series?
    I suspect this is for a 60hz (fullwave bridge 120hz) power supply. not a SMPS, caps ripple current are rated different at different freq.
    is it a snap mount? any of these should work, This is what I have used in the past without any problems
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      so at 60hz, the multiplier is 0.81, which puts the ripple at 1.78
      so I have to find a cap with a decent enough ripple at 1.78 @ 60hz
      • R_J
        • 9633
        its actually at 120hz if its a full wave bridge, some people like to pick the fly shit out of the pepper when it comes to picking a cap but its not that critical
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5045
          • US
          I just looked at the tv service manual and it does list it as smps
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5045
            • US
            and also finding a replacement for these capXon KM's. UCC KME's are the best but i'm having trouble finding those. Closest I can find are audio caps. KM's have no listed ESR (general purpose) like the KME's. So i'm concerned with going for a low ESR cap for this type of power circut
            • R_J
              • 9633
              So are you saying the caps are in the secondary of the sm power supply? most of my samsung dlp schematics list those type of caps in the primary, which is not high frequency
              Usually those caps are rated 85 degree which is also fine in that part of the circuit
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5045
                • US
                Yeah these are the secondaries. 25v, 2200u. But all 105c due to placement
                The ones listed first were the pris. I think I found a replacement for those with 250v ones that are about 2A
                But these secondaries are 1200mArms general purpose. Closest match I can find are either audio purposed caps or ones with really high Arms and really low ESR which I think will drive the spec too far off
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5045
                  • US
                  what about Wurth?
                  https://www.mouser.com/ProductDetail...6b1P%2fA%3d%3d
                  • jazzie366
                    • May 2016
                    • 304
                    Originally posted by Uranium-235
                    Found Wurth in many an audio circuit. They're good in my book, never seen them fail before. However, in your situation I think it might be alright to get a higher voltage cap, as that can add ripple current handling to it. I know this sounds silly, especially considering what's already there, but it can solve the problem quite easily.
                    Popcorn.
                      09-07-2024, 05:50 AM
                    • Kjell
                      Samsung Series 9 - BIOS issue
                      by Kjell
                      After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                      Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                      08-01-2025, 09:15 AM
                    • Biruslapio
                      Samsung's AU series "high quality" panel internally melting
                      by Biruslapio
                      I got this 55 inch AU7X00 TV, it was rebooting and showed no image only a blink of the backlights.
                      I assumed it was either panel or motherboard. Turns out it was the panel, and after applying some tape on the ribbon cable that goes to the left side of the screen, the TV turned on with image, then I suddenly noticed a dark spot and the pixels were turning black on the left edge, I was sad and thought I smashed the screen somewhere, found nothing visually, it looked in perfect condition and if it was there before it would've been noticeable while I was inspecting the TV the first time....
                      07-12-2024, 10:08 AM
                      ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 03:28 PM
                      ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
