s18k150 MOV replacement
  • Zorix
    • Sep 2013
    • 19
    I picked up an APC UPS (BK650) a while back that was was not providing any power output. I have done a few APCs before so I don't have a problem getting in there and looking for problems. I found a shorted out s18k150 MOV which appears to be a unit made by Siemens. I haven't been able to find a replacement and It's not a part of the circuit I have much experience with so I don't know what would be a suitable replacement. I know its an 18mm disc, and a 20mm would fit, but I don't know how this would affect it's protection capabilities. Any help would be appreciated. Thanks.
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: s18k150 MOV replacement
    We, at the steel mill, if a MOV is blowing fuses, sometimes we run without the MOV. That will work in a pinch situation. So if you need the UPS asap, go without the MOV. Its not suggested to do so for long term or on a regular basis but it all depends on the situation.
    BY THE WAY: there is a lot of 10 of these on ebay for about $16
    • Zorix
      • Sep 2013
      • 19
      Thanks Dgtech. I figured this would work as well but it's not needed at the moment, just keeping it as a working backup. Strange part was this MOV was on the protected backed up side so I think something took a surge from another point and came back into the UPS. Tested every other semiconductor for shorts and everything else seems fine, other than a small 1A fuse near one of the transformers showing as open, but no visible damage to any component.
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        yeah, you might be able to find a datasheet on the part and then either find a similar replacement or simply buy those from ebay.
        • PeteS in CA
          • Aug 2005
          • 3582
          • USA, Unsure of Planet
          Here's a datasheet. MOVs are a common part. You could use any available brand with matching or slightly better (max. surge current and power) specs.
          This sounds like it may have been a wear-out failure. If the unit is 5 or 10 years old and was in an area with lots of surges due to thunderstorms or industrial motors, it's probably wear-out. MOVs are very fast and can absorb a lot of energy. But every surge they absorb does a little damage. Over time and surges, the damage is cumulative, with the consequence being that the break-over voltage gets lower and lower until the MOV is conducting even with normal line voltage. The MOV soon self-destructs.
          This is the same reason it's wise to replace power strips with surge protection after every 5-10 years of continuous use, depending on your power environment.
          PeteS in CA
          • Zorix
            • Sep 2013
            • 19
            Thanks. Best match I have been able to find would be: https://www.digikey.com/product-deta...buynow&site=us
            That was a better datasheet than I was able to find, so that's much appreciated!
            • rewease
              Replacement for the Siemens Bakelite caps in an early 1980s SMPS
              by rewease
              There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
              Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
              Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
              09-17-2023, 12:53 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • the_rem
              Unknown transformer : how to find a good replacement part ?
              by the_rem
              Hello guys,
              I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
              I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
              04-23-2025, 01:48 AM
            • ezenia
              PS4 controller left stick potentiometer replacement issue
              by ezenia
              Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
              So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
              I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
              09-30-2023, 02:19 PM
            • boosti45
              Macbook pro logic board replacement parts quesion
              by boosti45
              i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
              08-21-2024, 05:23 AM
