Re: JVC THS9 Home Cinema System SMPS No outputs or standby power
Nope.
I have done a similar thing with the part still in circuit by connecting a bench supply directly to the HVDC rail. NO MAINS CONNECTION MUST BE MADE, just the bench supply.
An alternate start resistor has to be temporarily added.
It is best to have an oscilloscope.Leave a comment:
In the interest of educating myself, and maybe others here, with the IC now removed, and if I put a 16vdc power supply across pins 3 & 4, Grd & VCC, on a functional IC what should happen?
I guess pins 1 and 2 source/drain switch should start oscillating on/off, or is the feedback circuit needed on start up?
In other words how do you test it, and is it possible without an oscilloscope.
PercyLeave a comment:
No, I also tried cycling the power on/off to unlatch as mentioned in data sheet, but it had no effect.Leave a comment:
Does any voltage briefly appear at any output rail when power is first applied after it has had a long rest?Leave a comment:
Yes the STR-G6651 has that feature.
Data sheet has been uploaded.Leave a comment:
But surely it is only because the IC is out of circuit that the voltage gets to 37vdc, so with a new IC, the currently rated 25v one should be OK.
Or am I missing something?Leave a comment:
Many SMPS ICs have Over Voltage Protection. If the VCC pin even briefly exceeds usually 25V, the IC will totally latch off and wont attempt a restart until totally powered down.Leave a comment:
If I were replacing that 39uf cap I would go to 100 volts if you can get oneLeave a comment:
Good to know, on that basis I will place an order, and wait for them to arrive.Leave a comment:
I have to say I have about a 85% success rate with ali.Leave a comment:
too be honest everything i have brought has worked so far.Leave a comment:
So have you bought IC clones, if so, is your experience a good one?Leave a comment:
yeah, but the difference going from a 39uF to 47uF shouldn't be 37V vs 76V. It will ramp up and down all the time. Sure, the line isn't loaded now, I expected a rise in voltage, but not to 76V because you increased the startup cap by 8uF.
Did this thing go just out one day, or was there a power surge of some kind?
I can only report what happened, it would not help my cause to say any different.
Just went out one day.Leave a comment:
aliexpress are a good company been having a fair few parts etc from them but delivery time varies im on my 6th week for one part too arrive but saying that other stuffs been just over 3 weeks so cant complain i guess,Last edited by vinceroger69; 02-01-2017, 11:41 AM.Leave a comment:
Did this thing go just out one day, or was there a power surge of some kind?Leave a comment:
Vince: Thank you for the link.
Yes it is that package.
They do not state that it is made by Sanken, I am awaiting a reply from them, it should be at that price, but I think it will turn out be an expensive clone, which if it is the case, I may as well take a gamble on aliexpress at 65p each.
theres one on ebay
http://www.ebay.co.uk/itm/STRG6651-I...MAAOSw34FVCvqh
but not sure what package type yours comes inLeave a comment:
Unable to obtain these Allegro STR G6651 in UK.
Can get from china, probably clones, can anyone confirm these are reliable.Leave a comment:
39uF is a very odd value, but that is what the schematic shows too... I thought that was a misprint. Put the original cap back in its place for now and change that IC. Because we need to know that the IC is working to hopefully fix the situation or troubleshoot it further.
Having too much voltage on the cap isn't good, but I am wondering "what" you actually measured. I expected the voltage to rise on the cap, when the IC is gone, but surely not a value of 76V.
Lets see if budm sees this.
The original is back in and the voltage is now 37vdc.
When taking these voltage measurements the probes were kept on the cap pins until it had maxed out, probably took 5 secs to get there.Leave a comment:
by PedroGG90Hi everybody.
I have two 3 phase 400 vac smps siemens sitop 24 vdc giving red light overload and higher output 33 vdc.
The switching is controlled from micro controller.
Is it micro controller or transformer ? Or else pls ,?...Badcaps Electronics Repair Forum & Schematic Search -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by fharris1977Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.1 Photo
by dkneyleThis relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
