Just aquired vintage Apricot PC (1982). It must have been in a damp muddy place cos it had mud inside and hundreds of spider skeletons and webs. I stripped cleaned and then laid it out on the table for its first test. It has a very similar Astec PSU like another Osborne I am also working on. I turned it on for like 2 seconds at a time just to check it wasn't going to go bang and no it didn't and was quiet with fan spinning. So hooked it up to the motherboard and disk drives and tried again turning it on for gradually longer periods until it eventually completely booted into like and it was all working OK. Then I kept trying and watching the filter caps and right enough in the end they blew first the larger 0.1uf then the 0.01uf which completely exploded. Replaced them all now and its working great. Surprising considering how old it is and the filthy muddy environment it was sitting in for who knows how many years. Shows the old stuff was definitely built to last. Here are a few pics
Vintage Apricot another success but exploding caps
Re: Vintage Apricot another success but exploding caps
IIRC, Apricot was a UK-based company that produced Apple II+ or IIe clones and were driven out of business by patent violation lawsuits.
Interesting that the markings on the switch transistor weren't wire-brushed off.
I know that Rifa PME271 safety agency approved capacitors are not held in high regard by some here on BadCaps (I'm not one of them, FWIW), but that microcomputer has seen a bit od abuse. I'm guessing those X-caps took quite a few surges and spikes, and finally were so damaged that they self-immolated.
Back in the late 70s and early 80s, Rifa was the first producer of safety agency approved capacitors to catch on in the US and Asia, and for a time were pretty much ubiquitous.
Edit: I should add that I think at least some of those output capacitors might be higher quality 85C general purpose parts. I believe those light blue capacitors are Nichicon 85C parts, and UCC/NCC's SM (?) series 85C general purpose caps were also sometimes used as output capacitors (including by Astec). I'd keep an eye on those.Last edited by PeteS in CA; 01-29-2017, 10:26 AM.PeteS in CA
Thanks for that info on those blue Caps. Will they pop like a tantallum type or how will I know if they are failing?I should add that I think at least some of those output capacitors might be higher quality 85C general purpose parts. I believe those light blue capacitors are Nichicon 85C parts, and UCC/NCC's SM (?) series 85C general purpose caps were also sometimes used as output capacitors (including by Astec). I'd keep an eye on those.
I was ready and wary of those Rifa filter caps when I powered it up but just wanted to see if this thing was going to work before making a shopping list of parts i will replace. I would have changed them first and foremost knowing there poor reliability. I'm just pleased its all working and now I can get on with the full restoration.Comment
That's actually a good way to make an SMPS go bang! SMPS do not like getting turned on and off quickly.
Besides, if it's got a primary side fault, 2 seconds is more than enough time for it to blow.
A 'dim bulb tester' or other current limiting device would be a much better idea."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
Most likely they would be dried out and the ripple way out of spec. I'd go so far as to suggest replacing them out of hand, using Rubycon YXB or Nichicon PS series parts. Those are very mature series and barely qualify as low impedance. But they're 105C parts and probably not too much better than the original parts (I don't think they'd cause loop stability problems.Thanks for that info on those blue Caps. Will they pop like a tantallum type or how will I know if they are failing?
The 5V O/P caps are ~35 years old too, so replacing them might be reasonable. I'd try to find datasheets for the series used, just to be sure, but the YXB and PS series are probably decent matches.
Rifa makes good stuff. A Roederstein, Wima, or Siemens part of that era probably would not have fared any better.PeteS in CA
****************************Comment
The attached discontinuation notice mentions that YXB was discontinued nearly 17 years ago. Unless they did what Nichicon did with the PA series - discontinue the ancient series and launch a new, RoHS series decades later? I'd say Rubycon YXF, Nichicon PM, PJ, and PS are good choices, as may be Chemi-con LXV or LXY.Most likely they would be dried out and the ripple way out of spec. I'd go so far as to suggest replacing them out of hand, using Rubycon YXB or Nichicon PS series parts. Those are very mature series and barely qualify as low impedance. But they're 105C parts and probably not too much better than the original parts (I don't think they'd cause loop stability problems.
The 5V O/P caps are ~35 years old too, so replacing them might be reasonable. I'd try to find datasheets for the series used, just to be sure, but the YXB and PS series are probably decent matches.Attached Filesif you find these attachements useful please consider making a small donation to the site
Mea goofa! I meant the YXF series. Re the other series: I'd do PS or PM first; PJ and LXV are similar and next; then LXY, which is close to the current (non-aqueous) LXZ series.The attached discontinuation notice mentions that YXB was discontinued nearly 17 years ago. Unless they did what Nichicon did with the PA series - discontinue the ancient series and launch a new, RoHS series decades later? I'd say Rubycon YXF, Nichicon PM, PJ, and PS are good choices, as may be Chemi-con LXV or LXY.
What Nichicon did with the PA series is odd, but I think they just reached PZ and returned to the start of the alphabet. Just like the better known Ford Model A was Ford's second Model A (the first being much older).
BTW, the new PA series has impedances almost as low as the HE series.PeteS in CA
by SolomonManAll,
Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor... -
by redwireExploding motor cap on Ryobi electric pressure washers.
Recall is for 764,000 units and 16,000 sold in Canada.
"TTI Outdoor Power Equipment has received 135 reports of capacitors overheating, including 41 reports of explosions, resulting in 32 injuries and/or fractures to the fingers, hands, face, and eyes."
Broken bones? Shrapnel In your face? Never reach for the on-off switch, just run away!
Found this pic on Reddit, cap looks like a plastic housing electrolytic? with big rubber bung at the end.
Safety vent too expensive! DELETE DELETE
Channel: General Capacitor Questions & Issues
by DrDosHello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
by zomiJust wanted to get some feedback,
whats peoples' success rate with cof bonding repairs..... -
by edugimenoHi there!
My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
I am attaching several pictures of the machine.
It basically has 2 sides, left side has- 2 x 220->12+24v transformers
- 2 relays (1 moves motor UP, other moves motor DOWN)
- IGF and breakers for safety
- Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
- Loading...
