Liteon ps-3291-1df mb rev a
  • polytek
    • Dec 2013
    • 497
    • TUNISIA
    hi, friend the psu is burned and repered by another shop, i want a good photo to see the original component, because i can not get the sch.
    thanks.
  • foshland
    DELL XPS 9560 Burned zone need photo please
    by foshland
    Hi to all, I have a XPS 9560 with some faults, im working on it for fun, I have a "burned" zone I need to dremel but afterwards ill need a photo of the zone for rebuilding as far as I can, I have the schematics and the boardview but will like a photo, if some of you can get any so I see the traces will be cool.
    It was some kind of lucky that the zone had not too much components, so I think I can deal with it.
    Its under the zone where PC308 PC309 and PC337 is located, next to PU300
    Thanks a lot for all and "pray" for me ...
    04-21-2022, 07:33 PM
  • mikey5791
    by mikey5791
    Hi to all forum members,
    12-26-2024, 04:55 AM
  • rilley
    MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
    by rilley
    I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
    I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
    My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
    And the resistor L4004 is literally burned.
    From what I see from the schematics, it does not affect any other rails, only the connection to the display...
    07-10-2024, 01:57 AM
  • corrize
    Identify a burned component in Gimbal Zhiyun smooth-q3
    by corrize
    Hello, in this device, there is a chip (managing battery I guess) burned.
    I can’t read the full marking code because it is really damaged/burned.
    With a best pictures, I deduced that :
    8HA (or 5HA ?) and probably not 2HA or EHA or BHA
    K20
    296
    But I can’t find a component on the web with these marking code. Do you know what it is please ?...
    11-12-2025, 02:57 AM
  • coinwizx
    Burned out PSU Corsiar HX1200 and NZXT C850, connected to wrong Molex/Sata cable from EVGA.
    by coinwizx
    Anybody has experience repair PSU burned out due to connect to EVGA molex/sata cables. I know the cable is not compatible (i got them mixed up), but I though i can connect it and use a PSU tested to find out which is the wrong sata/molex cables. As soo as I pluged in the powered molex cable to the PSU tester, the power supply short out, and will not turn on anymore. After the incident, the PSUs (both HX1200 and C850) try to power on and shut itself off immediately. The ATX PSU tester survice the short circult, still working perfectly. Anybody know if it's an easy fix or know which parts...
    09-09-2025, 03:11 PM
