switched PS
  • golanko
    • Nov 2008
    switched PS
    hi,
    i designed a power supply for RFID application at 125KHz using ST L5970AD according to the application sheet, and added LM7805 at the output to stabilize the voltage and to lower the ripple and noise. i still have a problem at 10% of the boards. i think the problem is with the noise level at the output. can u advice how to reduce the noise?
  • tony359
    by tony359
    11-28-2023, 05:18 AM
  • MegaZAC
    Onkyo TX-SR805 noise in one channel
    by MegaZAC
    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
    There's some logic behind it. As soon as I select an input I get only left...
    04-23-2025, 10:09 PM
  • courtcircuit
    Philips HTS8000 home cinema noise problem
    by courtcircuit
    Hello
    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
    Removed each of tyhe boards
    02-08-2025, 08:22 AM
  • Biruslapio
    LG 50PB690 power supply terrible noise
    by Biruslapio
    I bought this TV with really bad oxidation on the power supply and bottom X boards, it was working but during pickup there was a lot of background noise so I don't know if it had this problem before.
    As soon as I could I opened the tv and started working on it, did not test it before since it had back bars on the screen and obvious signs of humidity. The X boards were replaced and the screen now works 100%, but the power supply...
    I washed the board and resoldered almost everything on the primary, the oxidation happened because of constant mains AC current flowing,...
    07-13-2022, 12:46 PM
  • ktmmotocross
    GB RTX2080 Super - crash on load > second switched 12V instability > what is purpose of this circuit?
    by ktmmotocross
    Hello.
    Have this GB 2080 Super that crash on load. When half load i see instability on one of two switched 12V rails. I dont know its purpose and dont have BV or Schema for this board.
    Can anybody explain me what is purpose of this two switched 12V lines?...
    10-03-2024, 12:22 AM
