Xtreme Gear PSAZ-600
  • goodpsusearch
    replied
    Re: Xtreme Gear PSAZ-600
    Originally posted by Pentium4
    Yeah I'd call it a 275W PSU. I don't know why they even bother with the ceramic discs. If you're going to make crap, just leave it completely empty
    If you update the primary caps to 680uF it can do 350W:
    Switching transistors are good sized TO-3P D209L, heatsinks are thick enough and designed for 120mm fan cooling and the transformer is real ERL 35.
    Originally posted by Drack
    I think a 30a schottky for 12v rail and it would be usable for a new PC if it doesn't crossload because of the light 5v usage
    +1
    I would absolutely add a 30A schottky rectifier for 12V rail.
    I have a Linkworld psu like that in my "for service" pile of power supplies, but I have been too busy to play with it. I remember the metal case was ridiculously thin.
  • Drack
    replied
    The first PSU I fixed was a gutless that had no line filtering and a dead fan, changed the fan and added 2 y caps one x and one coil
  • everell
    replied
    I am mainly after "obscure" PSUs that I have never seen.
    Let me know which "obscure" PSU you have never seen......maybe I have one and can send it to you.
  • Pentium4
    replied
    If you have doubled that collection, I'm amazed and impressed! I am mainly after "obscure" PSUs that I have never seen. And believe it or not...I love refurbishing Sun Pro units. Shame they went out of business
  • everell
    replied
    The reason I began fixing computer power supplies in 2009 is because I wanted to learn what was wrong when they went bad such that computer shops won't repair them, but simply trash and replace. I have come to believe that if you are daring enough to fix just one computer power supply, you have become an expert electronics technician ......... unless the first one you fix is a Bestec ATX-250 12E. That was the first one I fixed and everyone started throwing chairs at me!!! The general opinion was that this model power supply was the worst in existence, a mother board killer, and total trash, certainly not worth fixing. Well......that power supply is still working, powering a computer with AMD cpu (Pentium 3 class). I still use it for playing music, mp3 files, and playing freecell cards. Why throw the psu away, or the "old" dinosaur computer. Still works fine!
    Meanwhile, I think my collection in the attic has doubled from the picture I posted some time ago. So..............Pentium4, if you run out of psu's to fix just let me know!!!!!!!!!!!!!!!
  • Drack
    replied
    Originally posted by SIDMX
    Great job, as always!
    Remember those resistors are the minimum load needed for stability at minimal or no load conditions, i wouldn't attempt to explain exactly why they need a minimum load because there are too many things involved and don't even fully comprehend half of them but each design reacts different when changed, some give crazy voltages but stay on (usually crappy ones), others shut down after a couple of seconds or right away as yours.
    If the power distribution from the 12V rails is right this PSU fits a niche where only a couple of amps are needed from the 6-pin PCIe connector to feed a mainstream GPU like GTX 950/1050Ti and that may explain the 20A rectifier in 12V, so you were right, it's great for HTPC.
    I have heard that some PSUs went kaboom when the didn't have load, and that's why they are there on some PSUs.
    Agreed with you but I will use a 1050 or an Rx 460, less power consumption imagine 65w CPU, 75w GPU, 12w HDD, 20w ram and vrm looses, 12w on fans that's close to 15.33 amps on a part that should not exceed 70% usage and 70% of a 20a part is 14a, or that's what I have heard or read on some places like hardware secrets
    Or something like an r9 270, that's 120w power consumption with peaks at 150w and it only uses one 6pin, I want you guys to know that I respect you and I'm smart enough to know that you know more than me on psus so, I'm just saying not trying to piss you off with my comment
  • SIDMX
    replied
    You were right! I hooked it up to a system and it powered up no problem. It just didn't have enough load with just a paperclip... Yes it indeed only has that one 20A schottky for 12V.
  • Pentium4
    replied
    Thanks. I used nichicon PW, Panasonic FC, Rubycon YXF for the little caps. 1200uF 6.3V Chemi-Con KY for 5VSB, 3300uF 10V Rubycon PX for 5V and 3.3V, 2200uF 16V Chemi-Con KYB for 12V, nichicon PW for -12V.
  • Drack
    replied
    Nice job, those where the minimum load resistor some PSU are kind of a ehh Wells bitches with those, what caps did you use?
  • Pentium4
    replied
    You were right! I hooked it up to a system and it powered up no problem. It just didn't have enough load with just a paperclip. Since the fan spins so slow, I'm glad I changed out the resistors. They will be putting out a lot less heat and increase the efficiency a little. Yes it indeed only has that one 20A schottky for 12V.
  • SIDMX
    replied
    It may be the resistor change, try to put some load in 5V and 12V rails, if that fails and you're absolutely sure that there is no solder bridge, then put original resistors and try again, also re-check caps polarity.
    That's what i do when it happens to me
    First of all, SIDMX, I'm an idiot! I was looking at a different PSU. This one does have two 12V rails with shunts!
    so maybe i'm guessing it's wattage wrong, but then again it's no purpose to put a 20A rectifier in a 2 rail psu, are sure it only uses one 20A rectifier?
  • Pentium4
    replied
    I added an input filter and recapped it. I also replaced all of the 47 ohm resistors on the rails for 200 ohm. However, I think I did something wrong because the PSU just ticks the fan upon hitting power now.
    I know it has nothing to do with the input, because after adding the input filter and permanent 115V wiring, I tested it and saw that it powered up and was running. So it has to do with something I did while replacing caps and resistors. Couldn't be the resistor change, could it?
  • Pentium4
    replied
    Powerfull enough for even something a little bit more demanding I would say, so you recaped this? does it have two 12V rails or is it a single rail design?
    Yeah. I really love silent PSUs for HTPC though Sorry, I forgot to answer your question. I haven't touched it yet, I just desoldered the AC wires to take pictures, and it is just a single 12V rail with no shunts.
  • SIDMX
    replied
    ...It's powerful enough to power a HTPC. This thing is seriously so silent that it would be great for that application.
  • Pentium4
    replied
    IDK but he must be on a quest to recap every single PSU in the USA ...I know someone who even tried to import them from brazil
    He must indeed lol
    I have an obsession for repairing anything I can too, but you won by a lot p4
    Es raro conseguir a un latino por acá sidmx
    No, everell wins. But yes, I do have a large amount of PSUs
    Whether you're going to use 20A or not, the 30A rectifier would just be used for higher efficiency. I don't think I would waste a 30A rectifier on this thing though. It's powerful enough to power a HTPC. This thing is seriously so silent that it would be great for that application.
  • SIDMX
    replied
    The thing is 20A in 12V Rail will not happen that's not the 12V rating in a sub 300W PSU
  • Drack
    replied
    Yep, but remember that pushing a 20a part to 20a would be stressing that rectifier, they have looses (close to 30% or something like that I read it on hardware secrets) so more than 14a would be asking too much, maybe it will be OK but I don't like to push things to the limit
  • Drack
    replied
  • SIDMX
    replied
    ... but you won by a lot p4
    +1
    30A schottky for 12V? ...mmm don't think it needs more than 20A, would bet the protection kicks in before you reach 20A in 12V rail.
  • Drack
    replied
    He must indeed lol
  • render1967
    Problem with the Logitech G27 gaming steering wheel gear lever
    by render1967
    Hello! First, please excuse me if my English is not good enough because it is not my native language!
    Now let me describe my specific problem. For two days, the gear lever on my Logitech G27 has shown the following defect. When switching in the game (for example ETS2) it often does not detect 1st, 3rd and 5th gear - in these positions it shows neutral or flashes between the specific gear and neutral (for example - 1st <> neutral). When I press the gear lever to the left or right while it is in a position, it still manages to guess the gear and engage. In addition, instead of rear...
    11-13-2021, 01:35 PM
  • iyas132
    Corsair RM 750 blown schottky diode near ES1DF
    by iyas132
    Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
    Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
    My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
    Can anyone help me identify the component...
    12-30-2024, 01:34 AM
  • zen
    FH7 Sony cass deck service manual & gear required.
    by zen
    Hi all
    This deck keeps jamming.
    Took a chance & ordered an upgraded FF cam gear, plus slider sold on Ebay, as I thought it might be a common cause of issues being that it was sold a repair kit.
    Well, that's what I get for making assumptions.
    Stripped down & discovered a large black intermediate gear with worn teeth.
    Can anyone help to source it?
    10-10-2022, 08:07 AM
  • The Byter
    Looking for Gigabyte 1070 Xtreme Gaming boardview and schematics
    by The Byter
    It does not look like any other 1070 I got boardview for.
    11-28-2023, 02:00 AM
  • Crystaleyes
    iMac screen problem - PSU schottky's failing?
    by Crystaleyes
    have another iMac with flickering then black screen issue.
    It is a 21.5" 2010 A1311 model.
    When switched on, the screen flickers before going black. With a torch you can see the image is there, as are all four diagnostic LED's.
    Measuring the PSU output only gives around 10.5v with the cable harness connected, although it measures 12.06v unconnected. This leads me to suspect something the power supply.
    I saw that some people had found a shorted mosfet on the output however these seem fine, when tested for...
    03-31-2022, 06:55 AM
