Equal RL value for nixie tube ?
  • bianchi77
    • Jun 2016
    • 1121
    Everyone,
    I want to make a dumy load equal to Nixie tube, what's RL value equal to it ?
    100 K 1/4 will do the job or I need bigger ?
    Cheers
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Equal RL value for nixie tube ?
    Maybe some one with experience with restoring old equipment can give a better answer - nixie tubes were almost out of use in the mid-70s when I started working in electronics. I'd suggest finding datasheet type info on nixie tubes, learning what current they drew and using Ohm's Law to calculate a dummy-load resistor.
    PeteS in CA
      • 31028
      http://www.tube-tester.com/sites/nixie/dat_arch.htm
      • bianchi77
        • Jun 2016
        • 1121
        https://cdn.badcaps-static.com/pdfs/...1768d11c33.pdf
        Cheers stj
        • bianchi77
          • Jun 2016
          • 1121
          https://cdn.badcaps-static.com/pdfs/...f330196059.pdf
          Does the parameter on page 33 that I need to consider ?
          Voltage distribution A and voltage distribution B ?
          • Khron
            • Sep 2006
            • 1350
            • Finland
            The best(?) way to go might be to first know / find out what Nixie tubes you're planning on using, THEN finding the datasheet for them, and THEN crunching the numbers.
            What's the use in using the data from another tube, which could be wildly different?
            PS: That "voltage distribution" thing is for the photomultiplier tubes, which are a very different beast (and for totally other uses) than Nixie tubes.
            In the PDF you linked, you need to look at the BOTTOM of pages 32-33.
            See the "Type no." colums at the left edge on the bottom of page 32, and the right edge on the bottom of page 33? Quite the coincidence, wouldn't you say?
            From what i can tell, for example in the case of the Z303C and Z502s, they draw a current of 300uA / 0.3mA per digit (and you'll only have one lit at any one time, per tube), so there you go.
            But all that's irrelevant, if you end up using another model of Nixie tube...
            Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
            • PeteS in CA
              • Aug 2005
              • 3581
              One other point, once you calculate your resistance and necessary power rating (I'd recommend that the actual power be 75% or less of the resistor's rated power), be sure the rated maximum voltage is higher than the voltage you are using (this rating has to do with the materials and construction of the resistor, not Ohm's Law).
              PeteS in CA
              • bianchi77
                • Jun 2016
                • 1121
                Ok, thanks for the info....that's small ammount of current but already some power on 220V ...0.066VA
                So dummy load is equal to 733K ohm R = V / I , I put V =220 V and I = 0.3 mA
                • bianchi77
                  • Jun 2016
                  • 1121
                  that's the one you're talking about ?
                  I'm not sure I have 733K on my box...probably 680K plus 47K will do the job..
                  • bianchi77
                    • Jun 2016
                    • 1121
                    I got 196V on 727K RL load and 12V input from 7812 regulator...
                    will it be enough to turn on nixie ?
                    • DCJack
                      B&K 707 tube tester. I need help.
                      by DCJack
                      Hi everyone!
                      I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
                      Initially I noticed that I was not getting the red on-light to turn on, but it...
                      03-05-2024, 05:05 PM
                    • edugimeno
                      "First Experience" with a CFL BL Samsung TV
                      by edugimeno
                      Hi There!
                      I just wanted to share experiences trying to fix for the first time a CFL backlight Tv. It is samsung LE32A336J1N
                      The issue it was showing was: As soon as I turned it on, the BL would turn on/off for 2-4 times and them off definitely
                      I suspected the BL voltage generator or the LED strips, at least until I opened it up, cause I had never seen these TV's
                      When I opened it I found a very robust TV with a complex chassis formed by mutiple arms tied together with screws. There was a large PS board with several transformers for backlight,...
                      05-28-2023, 03:41 PM
                    • Schoenradt
                      ECH81/6AJ8 Vacuum Tube Question
                      by Schoenradt
                      Recently I acquired an Eico HFT 92 AM/FM radio made back in 1958. The unit has had some decent modifications done such as replacing the rectifier tube with silicon diodes and replacing the main filter capacitor with electrolytic capacitors. When I powered it up FM wouldn't tune past 105Mhz. I checked the FM tuner front end assembly and found a capacitor not soldered to the coil from the Plate B+ to and ground on the other side of the coil. Some calibration was needed on the trimmer capacitor on the tuner. My question is AM is extremely weak. When I tap on the tube I get all kinds of snapping and...
                      06-10-2021, 05:49 PM
                    • bohaboha
                      neon Tube power supply faulty T8006G V3.0
                      by bohaboha
                      Hi everyone needs your help with this Neon Tube power supply
                      Here are some pictures
                      Large capacitor has 320V but then nothing.has removed some parts but is not sure that they are bad except that they sounded bad on the circuit...
                      04-22-2023, 05:05 AM
                    • linuxguru
                      Fatman iTube (aka Dared MP-5) tube-buffered gainclone upgrades
                      by linuxguru
                      The Fatman iTube (OEM Dared, which also sold its own-branded version, the Dared MP-5) is a tube-buffered gainclone first introduced c.2005, to target the iPod market with a bookshelf tube setup. It became a huge success over the next ~15 years, selling over ~100k units worldwide to a market where it was often their first introduction to vacuum-tube audio on a budget.
                      http://www.enjoythemusic.com/magazin.../dared_mp5.htm
                      One of the Fatman versions landed up for auditioning a few days ago, and I must say that I was impressed with its form-factor, pricing,...
                      03-13-2021, 08:45 PM
