Goldmine Electronics has Avery good sale on fans
    • Jul 2011
    • 6040
    I post this in case any one is interested in this deal if you can use them
    This offer expires on 11-27-16
    http://www.goldmine-elec-products.com
    30 Fans Valued at $1050.00 - Just $10 Bucks!!!
    Papst 24VDC 80mm Multifan 8314/19H
    Powerful high quality Papst 80mm fan model multifan 8314/19H. Operates on 24VDC at 245mA (20-26.5 VDC range) Has 12" flexible color coded power leads: Red (+), Black (-), Yellow - Alarm.
    Specs: Airflow 47.1 CFM, ball bearings, noise 48dB, speed 5000 RPM, Power - 6Watt, Frame 80mm X 80mm X 32mm, housing - Polybutylene Terephthalate (PBT). Rated for 55,000 hours.
    This is a very high quality precision made fan by Papst. Brand new - Retails for $35 per fan - Box Valued at $1050.00! Check out our blowout price.
    Note when purchased in Quantities of 30, you will receive a factory labeled box that contains the 30 fans.
    G21651A $105.00 Only $10.00!!! - (Valued at $1050.00)
    Does anyone know how to change a fan speed controller from 12 volts to 24 volts
    I bought one of these deals to keep some equipment controller cool but I don't want them to run a full speed all the time
  • emil_t
    RTX3090 working fine but fans not spinning
    by emil_t
    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
    04-12-2024, 06:54 AM
  • JayPoorJay
    Hot Water Rad - A Few ECU Fans and a Timer Switch
    by JayPoorJay
    Good Afternoon, Good People.
    I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
    I REALLY would appreciate y'alls help.
    This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
    10-29-2024, 12:54 PM
    Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
    This is a new item at Electronic GoldMine that has arrived within the last few weeks
    Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
    Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
    https://theelectronicgoldmine.com/products/g28392
    One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
    11-24-2024, 01:25 AM
  • sda sad
    my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
    by sda sad
    Hope this is the right place, someone can help me.
    My laptop started having a really strange problem....
    When I turn it on the fans start working at a crazy rate and with random breaks...
    They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
    And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
    The model of the computer:
    Xiaomi Notebook Pro X 15 OLED (A30)
    04-23-2024, 09:55 AM
  • joesmoe91
    Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
    by joesmoe91
    My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
    02-22-2024, 07:38 PM
