Corsair CX430
  • acs5071
    • Oct 2016
    • 23
    Corsair CX430
    I have an older system that I personally built and I am in the process of determining whether to repair it or not. It has some obvious capacitor issues currently. (There is a post about it in the capacitor sub-forum) These recent issues are possibly the result of 2 PSU failures and/or a CPU fan failure in the past (yes, I used the PSU that came with the Apevia case that I bought when I built it) . I am currently running a new (6 mos. ago) Corsair CX430 PSU in this machine.
    So the obvious question is this: Is this PSU of sufficient quality to continue using after the repair or should I be looking for something different? Money is DEFINITELY an issue so if it is not likely to cause future drama I would love to leave it in service. If not, what is a reasonable replacement to look for? It's a fairly simple build with no high power cards and such. We just use it for basic computing and organizing tasks.
    Thanks in advance for your assistance. Any advice or suggestion welcome. I have read about Asus's dubious (at best) quality and their poor choice in capacitors. I do wish I knew this when I built it... Having said that, you may feel free abuse me about my choices when I built this system. I have a fairly thick skin and maybe I will learn from my mistakes.
    Current specs:
    Asus P5E-VM DO
    Intel Core 2 Duo e6600
    Crucial 2 x 2GB DDR2 ram
    Running Windows 10pro 64bit
    Corsair CX430
    2x Asus 2014LT optical drives
    1TB Western Digital Red HDD
    cheap PCIe x1 sound card (onboard sound quit several years ago)
    cheap PCI 56k fax modem card
    FWIW - we have always used the onboard video up until now. It always served our needs well and no drama. Now the onboard video crashes over and over which has brought us to this point... I may need to install a video card if the problem persists and everything else seems stable. This might factor into the decision about the PSU and it's capabilities.
  • nick122
    • Jul 2016
    • 110
    • Slovenia
    Re: Corsair CX430
    That psu is filled with aishi (made by fuhjyyu) and capxon caps, although the older ones had teapos and samxons. It's built by cwt (DSAII platform - their entry level stuff). It's definitely better than some "el cheapo" units like deer, sun pro, leadman etc. I were you, I would keep it. It's good enough for that rig.
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3264
      • Singapore
      Re: Corsair CX430
      according to a teardown (there's also a version 2 of this unit) by jonnyguru, it uses samxons and teapos. since u cant open up your power supply to take pictures of your actual unit as its still under warranty, we'll just have to accept jonnyguru's review as being that of the actual unit u have.
      anyway, this power supply is about a grade B- to C+. the two year warranty on this unit is telling and gives u a rough idea of how long its meant to last.
      if u want to use this power supply with that asus p5e board, definitely recap the board with polymers. polymers can last longer with a low or average power supply compared to electrolytics. however beware, see my other post about how the board *may* not be fixable.
      • acs5071
        • Oct 2016
        • 23
        Re: Corsair CX430
        Seems like just about what I expected from the level of equipment that it is. Decent utilitarian unit but nothing fancy. I guess it'll do for now if the rest of the unit is willing to be fixed.
        • acs5071
          • Oct 2016
          • 23
          Re: Corsair CX430
          So here's the big question:
          Is there a consistantly reliable, at least somewhat affordable, manufacturer of power supplies? A company (or companies) that I could count on to produce a solid and reliable product. Something I could buy in a pinch without doing a month of research and also not having to regret my decision several years later because of collateral damage?
          I am reading through the forum but even though there's a lot of great information on here, it can be like trying to get a sip of water from a fire hose...
          Andy
          • Audison
            • Sep 2016
            • 46
            • Slovenia
            Re: Corsair CX430
            https://seasonic.com/ - very high quality
            http://www.evga.com/products/ProductList.aspx?type=10 - decent quality
            http://www.super-flower.com/powersupplies.html - ok quality
            • acs5071
              • Oct 2016
              • 23
              Re: Corsair CX430
              Originally posted by Audison
              Well now I really feel like a cheap skate... None of these are particularly expensive. Maybe twice what you pay for a bargain model (doesn't feel like a bargain right now).
              Andy
              • retiredcaps
                • Apr 2010
                • 9271
                Re: Corsair CX430
                There is a good chance this power supply will last 5 years as is given it is only 6 months old especially if money is tight in your situation.
                I have only seen one power supply die within a year. It was inside a friend's brand new Acer desktop and I think it was a HiPro. I tried to diagnose the problem, but it still eludes me.
                Otherwise, I use used power supplies that I have fixed (generally just a single bloated capacitor on the 5V standby rail) on all my builds at home. I also use used hard drives.
                It doesn't matter if you buy new or used, having multiple backups of your data is key.
                --- begin sig file ---
                --- end sig file ---
                • junktv
                  • Nov 2010
                  • 3065
                  Re: Corsair CX430
                  The seasonic S12, M12(modular) ,s12g, G and X series are reasonably priced. When I replace my corsair vx550 I'll be going with one of these.
                  • ChaosLegionnaire
                    HC Overclocker
                    • Jul 2012
                    • 3264
                    • Singapore
                    Re: Corsair CX430
                    power supplies based on the superflower leadex platform are currently the best around with the lowest ripple. in the US, its being sold under the evga brand name under the g2 series. a word of caution: its the eVGA G2 series. dont get the gs series which uses junk caps.
                    i avoid seasonic as i dont have good experience with them. had an m12ii once and it kept killing my hard drives by reallocating sectors. so it seems like there are issues with the 5v rail on that unit as i also had problems getting my usb devices to be recognised or detected. not the mobo as it uses polymer caps.
                    the seasonic x series also has issues where it will fail to start up.
                    so hard to find a great grade A+ psu these days...
                    • junktv
                      • Nov 2010
                      • 3065
                      Re: Corsair CX430
                      I need to side stj on that thread you linked chaos for the fan noise. My pc is only quiet now because it's been years since cleaned and fans started making noise because the dust cakes. 4 of 12 120mm work still. 12" fan blowing in is easier.
                      Hope those ky aren't bad caps now.
                      • benareeno
                        corsair cx430 sudden power loss
                        by benareeno
                        This seems to happen once or twice if I cold boot the system from full power off and it pretty much happens every time I cold boot. Also, it seems to happen when I wake the pc after putting it to sleep for a while..seems to happen every 2 or 3 times. So, does this mean I should either junk it or look into recapping it? It has plenty of power for me and it's really quiet...so I do like it.
                        What are your thoughts?
                        03-02-2024, 04:29 AM
                      • h0m3w0rk
                        Random Shutdowns/Startup Failure with Corsair SFX 450
                        by h0m3w0rk
                        I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                        For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                        02-09-2025, 03:19 AM
                      • coinwizx
                        Corsair HX1200 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
                        by coinwizx
                        The power supply is 2020 Corsair HX1200 modular power supply.
                        Cause of damage: I connected EVGA molex cable to the Sata port and test it with a ATX tester. Since the pin out on the EVGA is wrong, result in the 12V pin shorted to the 5V pin, in the 12V back-feeded to the 5v port.
                        Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then try to re power up....
                        09-15-2025, 12:46 PM
                      • zunasthegreat
                        Dead corsair VS450 with blown TNY chip (cwt)
                        by zunasthegreat
                        I have this Corsair VS450 PSU which lies dead and has an exploded TNY chip. Upon removing primary side parts like mosfets, the bulk cap and the bridge rectifier I've found that the primary cap is also a goner. (Photos)
                        The mosfets and the diode are fine and survived the collapse it seems. The TNY chip is shattered and from the online review/sources it was probably a TNY176~177....
                        08-30-2025, 03:11 AM
                      • hobostove
                        Corsair RM1000e - Help identify 5VSB Zener diode
                        by hobostove
                        Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                        Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                        There's a 22ohm resistor that's melted and open, but it still has the bands.
                        The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                        It looks like the diode connects the source and drain of a TNY284...
                        03-27-2025, 02:25 PM
