Premier DR-B300ATX keeps blowing fuses
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    • Romania
    It's me,with another Deer. (I have a few of these - a JNC,this and a Modecom,the last being really well built,which just needs new 13009 transistors and a new 12v rectifier - not shorted or anything,just crappy)
    Anyways,this one I've got along with a case,made by just the same company - Deer (just for the record,I use the case right now and the PSU I installed in it is a CWT ISO PSU).
    The problem with it is that it repeatedly blew almost 3 or 4 fuses (and it actually came with a cracked,blown fuse.) and I still can't find what is wrong with it.
    Here's what I did so far:
    -replaced fuse - blew again,just installed a new one now
    -replaced primary transistors (C5706 iirc) with 13007s and original standby transistor with new 2N60 transistor
    -replaced primary caps (tiny 330uF Saturn caps) with 470uF Fuhjyyu MK caps
    -replaced 5vSB caps (G-Luxon) with 1000uF 16v Panasonic FJ caps.
    -even replaced the diodes in the bridge rectifier,but wouldn't bad diodes cause the PSU not to show any signs of life instead of popping fuses?
    I don't know what to do now. I don't have any lightbulb to test with either.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Premier DR-B300ATX keeps blowing fuses
    Well make one. A lightbulb tester only requires a bulb, a bulb holder and a spare ATX power cord to splice (in case you don't have a spare socket or extension cord lying around).
    But yes the diode bridge can SHORT and also cause it to blow fuses. Maybe there is another fault which causes primary transistors to blow and they went short again after you replaced them.
    A working TV? How boring!
      • 31090
      check other diodes for shorts.
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        • Romania
        I don't have any bulb holder lying around. And as far as I remember,wasn't the bulb be supposed to be put in the place of the fuse?
        As for the diode bridge,I replaced the diodes with working ones from another known working Deer,along with the main transistors. I am quite reluctant to turn it on now,but somehow as opposed to shattering,last fuse I installed and popped was actually brownish-black. Any ideas why did it not shatter?
        stj - I checked the secondary side and found nothing out of the ordinary,all rectifiers were fine. I also replaced the two 2.2uF 50v caps in the snubber circuit (I think) with two 10uF 50v caps.
        Main rig:
        Gigabyte B75M-D3H
        16GB DDR3-1600
        Delux MG760 case
          • 31090
          primary side - you often find some diodes related to the switching transistors.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Yes there are 2 1A diodes, you will find them alongside the primary caps. They look like 1N4007s but they are actually fast recovery rectifiers so be careful when you replace them, you want fast or ultrafast there.
            The bulb comes in series anyway, it does not matter if it is used to replace the fuse, or if the fuse is still there... and you can solder directly to lightbulbs.
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              • Romania
              Just wanted to thank you about your idea of using a lightbulb. I just found one,wired it up in the place of the glass fuse and I got a positive result - light flashes when on standby,and stays dim when running. Apparently it was the rectifying diodes that were bad,causing in turn to fry the original 2SC5763 transistors,but somehow the 13007s didn't fry
              While at it,I replaced the 2SC5763s that were shorted (and crappy to top it) along with the 2N60 standby transistor with a new CET 02N60 transistor and the two main transistors with 8A 13007s. I didn't replace the diodes on bracket on the secondary yet,because my only 12v transistor was shorted (16A 60V).
              One thing I didn't expect to find though,was a Power Logic PL80S12M-1 fan. I heard Power Logic fans are good,is that true?
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
                • 31090
                if it passed AC to the transistors then the mains smoothing caps may be damaged too.
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1866
                  • Romania
                  I think it didn't. One thing that tells me that is the fact that if that would have happened,the fuse would shatter to pieces. Instead,the fuse popped and its insides were splattered with something of a very very dark brown (near black,but not 100% black). This tells me the fuse may have sacrificed itself to save the main transistors (if it didn't,it would blow the fuse even if I replaced the rectifying diodes. And are you talking about the two 10uF 50v caps that I replaced (original ones being 2.2uF) just between one of the transformers and the primary heatsink?If so,those are fine. And if it's about the main 470uF caps,those are fine too.
                  Anyways,the main caps are Fuhjyyu LP 470uF 200V (or 250V?). Are those good? Here are some pics of the PSU,after the repair. It does power up now,without blowing anything.
                  Main rig:
                  Gigabyte B75M-D3H
                  16GB DDR3-1600
                  Delux MG760 case
                    • 31090
                    i am talking about the 200/250v ones.
                    and that make is probably the worst ever.
                    i would desolder them, discharge them (carefully) a couple of times - then test them on a meter.
                    dont be too surprised if they are only 330uf anyway - i have seen big caps miss-labelled before.
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1866
                      • Romania
                      First of all,I don't have a ESR meter,or any meter that can measure capacitance.
                      Now,one (possibly) normal thing that the PSU would do in that case,wouldn't it be blowing one of the primary caps,if they would be damaged (damaged as in domed tops,I guess?). This isn't the case here,the caps are still flat.
                      And being primary caps,should I expect Fuhjyyu to nail it even in this case? I have some 470uF 250V UCC KMQ that claim to be from 1995,according to their datecodes,if the Fuhjyyus ever decide to quit.
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                        • 31090
                        if you lack capacitance then you wont see any problems until you run a heavy load.
                        then it could get electrically noisy and cause the computer to crash.
                        • Dan81
                          SNES-powered
                          • Oct 2013
                          • 1866
                          • Romania
                          This PSU won't see a heavy load,since it would power the bare minimum for a PC to run. And also I never had a PSU crash a computer. Are you sure it isn't the line filtering (which is fully present on this psu) and the PI coils (which are present as well) that take care of the noise?
                          Main rig:
                          Gigabyte B75M-D3H
                          16GB DDR3-1600
                          Delux MG760 case
                            • 31090
                            not if the power is not stable into your switching transistors.
                            • Dan81
                              SNES-powered
                              • Oct 2013
                              • 1866
                              • Romania
                              It is stable
                              Main rig:
                              Gigabyte B75M-D3H
                              16GB DDR3-1600
                              Delux MG760 case
                                How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                by sam_sam_sam
                                About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                12-14-2023, 07:45 PM
                              • Sik_6ty_Sixx
                                HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                                by Sik_6ty_Sixx
                                So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                                02-18-2025, 05:06 AM
                                Surface Mount Fuses Fundamentals Datasheet
                                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                10-07-2024, 06:07 AM
                                1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                                by sam_sam_sam
                                I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                                This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                                12-29-2024, 07:18 AM
                              • mon2
                                Gemsound PAX-105 Audio Amp blowing fuses
                                by mon2
                                Hi. New to this side of the forum.
                                Have an audio amp (Gemsound PXA-105) that keeps blowing the 3A fuses upon power up. Owner stated that the amp was on when he plugged in the input (mixer board) and that started this chaos.
                                Would a schematic be available? Advice on what to check? Power supply / output amp transistors? Do see the power on green led turn on for a brief moment before the fuse blows.
                                Thanks.
                                10-30-2024, 08:33 AM
