Recommend a PSU for Benchtesting Motherboards
    master hoarder
    • May 2008
    • 12170
    Re: Recommend a PSU for Benchtesting Motherboards
    Originally posted by KenOlson
    Question: Would be interested to find out what acstech recommended in post "I use these, both for testing and in computer builds:".the old link http://www.hypermicro.com/index.aspx did not work.
    I believe it might have been one of these, though I'm not sure...
    http://www.hypermicro.com/ProductDes...LY-BULK&key=it
    I've seen a lot of other people here recommend this particular PSU, so it's probably it.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      that's the one. the ever infamous ac-bel 550w
      they weigh a ton but they are nice... proud owner of one and was going to buy another but came into a couple units that i fixed up.
      biggest pain is that they have OST and other crap brands in oddball sizes... but it is built like a tank.
      sigpic
      (Insert witty quote here)
      • KenOlson
        • Jun 2011
        • 81
        Hi momaka,
        Thanks for the ac-bel 550wPSU info and link!
        Question: Am a firm believer in Murphy's Law so what will kill the ac-bel 550wPSU?
        Ken
        • KenOlson
          • Jun 2011
          • 81
          Hi ratdude747,
          "ac-bel 550w...they weigh a ton but they are nice... proud owner of one and was going to buy another but came into a couple units that i fixed up."
          Any suggestions or links to info about "fixing up" PSUs? Have some old ones but do not know if worth while? May be a learning experience anyway?
          Ken
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            the one unit needed recapped and the other will need new caps and some reworking of the 5vsb circuit.
            sorry, but i do not have any one worth fixing that i do not have plans for.
            what could break the 550? the caps... otherwise it would take some pretty heavy things to bust it.
            sigpic
              master hoarder
              • May 2008
              • 12170
              #26
              Fire. Water... a combination of both?
              Other than that, I doubt you can kill it with computer hardware - it has all of the necessary protections. Perhaps if you put it in a very hot case with no ventilation, then the capacitors might go bad (but that's applicable to any power supply).
              In short, this is a nice power supply and I don't think you will have any problems with it.
              Just start a new thread and post some pictures of the power supplies in question. Many people here can tell you which ones are worth something and what can be done to improve them.
              • KenOlson
                • Jun 2011
                • 81
                #27
                Hi momaka,
                Did as you recommended "Just start a new thread and post some pictures of the power supplies in question. Many people here can tell you which ones are worth something and what can be done to improve them."
                As previously mentioned have an old Gateway NS-7000 server and checked the PSU. It is an AOpen FSP300-60BT. The new thread is
                https://www.badcaps.net/forum/showthread.php?t=15093
                Am guessing that it may be best to check all the caps because when searched concerning AOpen FSP300-60BT found "This could be a great psu, but fuhjyyu and jamicon capacitors ruin it all."
                https://www.badcaps.net/forum/showthr...en+FSP300-60BT
                Any comments or suggestions welcome!
                Ken
                  Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook T Specification for Upgrade or Repair
                  This specification for the Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T490s + Ethernet Extension Adapter Gen 2 boardview and T490s + Ethernet Extension Adapter Gen 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                  09-06-2024, 08:58 AM
                • AJ847.63e
                  Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                  by AJ847.63e
                  Hi Folks,
                  Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                  I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                  The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                  05-06-2025, 10:37 PM
                • qwerty99
                  Xbox 1.6 Motherboards and Polymer Capacitors
                  by qwerty99
                  Hello!
                  I need to change the capacitors on my three original Xboxes.
                  Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
                  The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
                  The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
                  I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
                  06-26-2022, 12:53 AM
                • LaszloT
                  Power extension capacitor
                  by LaszloT
                  Does anyone recognise what capacitor this might be? It's from a faulty 230V power extension with surge protection. Thanks in advance for any help!
                  03-07-2025, 06:43 PM
