silverstone sst st50ef with bulged caps
  • manthi
    • Feb 2014
    • 39
    • canada
    hello guys, i need your advice,
    here i have a PC with a weird behavior, occasionally it will start, with a delay,
    i push the power button, nothing happen, no light no spin, nothing, then 30 sec later the pc starts without me touching anything.
    i think the problem could come from the PSU, i opened it up and found 5 bulged caps, 3 teapo 2200uf 16v, and 2 others i cannot see the specs
    do you think there is a link between the bad caps and the delay the pc takes to start
  • retiredcaps
    • Apr 2010
    • 9271
    Re: silverstone sst st50ef with bulged caps
    Yes, definitely the bulged caps are to blame of the delay. They may have high ESR and low capacitance. As the caps heat up, the ESR will drop allowing for the power supply to function.
    Replace all the capacitors, bulging or not with Panasonic FM/FR or some other low ESR caps from Rubycon, Nichicon or United Chemi-Con from a reputable distributor like digikey or mouser.
    --- begin sig file ---
    --- end sig file ---
    • manthi
      • Feb 2014
      • 39
      • canada
      ok thanks for the explanation, now i understand why it was not happening during a restart within windows
      • CapLeaker
        Leaking Member
        • 8352
        Try heating the PSU with a hair dryer, it should start instantly.
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
          by momaka
          03-15-2023, 10:17 PM
