Help: Need +12V to +13.8V mod.
  • maxbarjr
    • Mar 2016
    • 46
    • Philippines
    I am new here. I was searching for a schematic diagram for an ENERMAX EG651P-V when I came across this forum. Been reading this thread and I found it really interesting. The EG651P is an old PSU, but it's still working. I would like to use it for my ham radio power supply. How can I crank up the +12V to +13.8V? This SMPS is using the LM339N Comparator not the usual TL494 chip.
    See attached pix.
    Looking forward for any help out there.
    Thank you in advance.
    Max
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Help: Need +12V to +13.8V mod.
    It would help to have a schematic of the board to even see if that is possible. You would need to know what is the maximum voltage that is driving the comparator. Is that voltage above the 12 volts and can a just simple different resistor combination drive that to a higher voltage. On pulse modulated power supplies there is a feedback circuity to control the duty cycle. Unless a person is very familiar with this particular supply they would have to have a schematic of the circuitry to tell if the original design would allow for such an alteration. They would also need to know the power supply specifications of your ham radio to determine is this supply would work.
      • 31304
      i wouldnt try that, the primary output is 5v, that is the one the feedback will track.
      • japlytic
        • Oct 2005
        • 2086
        In an number of cases, comparators (usually ICs; sometimes transistors and zeners in old units) can act as overvoltage shutdown protection devices, from a number of computer power supplies I have examined.
        • Behemot
          • 4845
          • CZ
          Such incredibly +5/+3.3V heavy unit will not work anyway as long as you'll draw more than a few amps from the rail. You'd need to draw heavy power from them in order to keep +12V high. Sell it to somebody with powerfull dual PIII or similar system as such units are hard to get, and get 13.8V unit for that money.
          • noppa
            • 41
            look if this may help
            http://www.chirio.com/atx_14_volt.htm
            • Stefan Payne
              • 1267
              I wouldn't do it. Because it's a working, decent older unit wich aren't found that often and needed for some 'special purpose' things. Like an ASUS A7V266-D...
              Besides that:
              This is a group regulated unit. Means that you nead load on at least the +12V _AND_ +5V rail. You have to load it according to the loads of the time -> +5V heavy and not so heavy on the +12V rail.
              Thus this unit is just bullshit for this project because of that...
              Second:
              ATX units have protection ICs, even with the worst possible protection chips, almost 14V is in an area where the OVP will kick in. So no chance whatsoever...
              So in the end, your modification will not work!
              All you could do is to put a Buck/Boost converter inside the PSU that you'll adjust to 13,8V...
              But it's probably better to use a board for that and PCIe connectors as interface...
              BUT:
              You will need a modern ATX PSU for that wich is designed for heavy +12V loading and light +5V loading.
              So in the end, isn't it better to get a 13,8V Powersupply?
              I've taken a short look on what's available in my region (google shopping) and found something like cheap/2nd hand notebook power bricks for under 15€ as well as a MEANWELL PSC-60A for under 25€ (+ shipping).
              So I don't think it's worth modifying this ATX PSU that isn't made for ~14V...
              • maxbarjr
                • Mar 2016
                • 46
                • Philippines
                Thank you all for your comments and suggestions. All of you hit the nail on the head. I have decided to just use the power supply for a Linux Server project.
                Again many thanks.
                maxbarjr
                  Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                  The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                  The bq24745 features dynamic power management...
                  10-23-2024, 02:50 AM
                • Cuboy
                  HP probook 4510s mosfet issue
                  by Cuboy
                  I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
                  I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
                  I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
                  03-16-2024, 10:29 AM
                • прямо
                  TRIAC circuit
                  by прямо
                  Anyone is familiar with a TRIAC circuit?
                  I came across this schematic, and I built it, but I can't seem to figure it out why I'm getting a low AC voltage output at the TRIAC terminals.
                  With 230V AC hot side at the TRIAC MT2, I measured 60V AC between MT1 and neutral side when the comparator output LED indicator is on, and 20V AC when it is off.
                  Same result if 230V AC hot side is at MT1, and I measured between MT2 and neutral side.
                  My heating element doesn't work with 60V AC. It's not even getting hot and the thermocouple amplifier output is a...
                  04-27-2024, 02:12 AM
                • ShadowAi
                  ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                  by ShadowAi
                  Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                  Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                  After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                  03-15-2024, 10:46 AM
                • harp
                  4001 sr latch / latch problem
                  by harp
                  I have simple circuit with cd4001, first is sr latch, which set is inputing from comparator, and reset is inputing from clock. Sr latch output is connected to hard latch I guess, but I do something wrong here... led 2 is flashing just as inverting clock... I want to led2 stay permanently on ance it lock signal, not to be interferencing with invalid state of sr latch. What I doing wrong?...
                  08-28-2025, 09:43 AM
