Is this diode bad?
  • mikay786
    • Aug 2014
    • 765
    Is this diode bad?
    Got a sony BDP-S570 3d bluray player that's completely dead, no power.
    Thought I would check the diodes first are only 3 is the power supply.
    31DQ10 SCHOTTKY Diode - Reading 0.227v (only reading one way)
    Is that too low, normally look for around 0.4-0.6v but not sure if its different on schottky diodes or the same applies?
    • 31304
    Re: Is this diode bad?
    sounds about right
    schottky has a lower volt-drop
    • SuperAman
      PS5 HDMI port diode reading?
      by SuperAman
      I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
      02-03-2024, 10:16 PM
    • Dvsr
      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
      by Dvsr
      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
      After replacing the caps I started testing out the speaker. It seemed...
      09-10-2025, 10:20 AM
    • Baste
      MBR3045CT and SR3045LCT Schottky diode testing help.
      by Baste
      Hello experts,
      Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
      Aneng ST182 Meter.
      Diode mode.
      MBR3045CT:
      Diode mode
      Pin 2-1 - 0.150v
      Pin 2-3 - 0.150v ...
      10-21-2025, 06:14 AM
    • abajor
      A2141 PP3v3_G3H_RTC_X Diode Reading .104V Voltage 3.39V
      by abajor
      Have an A2141 which is reading about 5.2V 0.07A on all USB jacks, started doing the measurements.
      PPBUS_3GH diode: measures good .45V
      PPBUS_3GH Voltage: maybe not so good 12.25V maybe bad T2? Unit did not come up in DFU on configurator.
      The weird so far is
      PP3v3_G3H_RTC_X diode: .104V (WTF?)
      PP3v3_G3H_RTC_X voltage: 3.39V (Normal)
      Stopped there attempted reverse voltage injection at PP3v3_G3H_RTC_X with 1V. Instead of the circuit sinking any current, My PSU suddenly reads 3.4V with no current draw.
      Not sure what any of this means...
      03-18-2025, 10:27 PM
    • iyas132
      Corsair RM 750 blown schottky diode near ES1DF
      by iyas132
      Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
      Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
      My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
      Can anyone help me identify the component...
      12-30-2024, 01:34 AM
