how to start liteon ps 1201-1?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Have two cisco switches that have bad psu. i have schematic for it but dont know what must be done to start it without switch board to be sure that psu is ok. anybody know it?
    it have this out-in cables:
    12V1
    GND
    status_1
    status_2
    PG
    RPS_PRES
  • widgetron
    • Nov 2015
    • Estonia
    Re: how to start liteon ps 1201-1?
    Just plug it in, a working PSU should just start up and provide 12V relative to GND.
    Signals are irrelevant to PSU startup.
    Would you be so kind to share the schematic? I also have a faulty supply i would like to fix.
    • jlstech
      • Oct 2016
      I have just received a switch with the same power supply, of course it also has issues. Did you have any luck? Also, would you be so kind as to share the schematic as well. Thank you.
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • madan1
        cisco poe switch PSU issue
        by madan1
        Hello everyone.
        I'm troubleshooting a cisco switch, which seems to have an issue with the PSU.
        The psu has the following power rails - +12v, -53.5V and +3.3V
        When connected to power, the +12 and -53.5 seem to work fine, but the +3.3 starts at ~3v and then goes down to ~0 (I guess this is the cap discharging). This happens both when the cable is connected and not to the switch board.
        Any ideas what might be causing this behavior?
        04-23-2024, 01:58 PM
      • fuxxy
        Cisco C2960CX managed switch - Won't provide POE
        by fuxxy
        Hey guys, I have 4 of these switches.
        One switch works as intended - Boots, Accepts configuration, Provides POE. However, after about 3 days the switch stops responding. Won't recognize console USB cable inserted, TX/RX lights stay lit when cables unplugged. Works again after power cycle.
        The other three will boot, accept configuration, and will uplink to the network. However they won't provide power to connected POE devices. I've ruled out configuration issue, as I have cloned the configuration from the 'working' switch to all 3 of these non-working switches....
        03-07-2022, 10:26 PM
      • Natob82
        Micro Momentary Push Switch?
        by Natob82
        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
        12-21-2022, 05:22 AM
      • grimacelord
        NEC TurboExpress On/Off Power Switch Replacement Help
        by grimacelord
        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
        11-09-2023, 09:49 AM
