Corsair HX750 - no fan control
  • gintama
    • Sep 2007
    • 59
    Hi all, I just pulled this PSU out of storage and was happy that it still works within expected parameters, but also disappointed to find the fan is stuck on at full speed. From what little I've been able to find on the web, this model's controller makes decisions based on load as well as temperature. As the system I'm using it with doesn't even have an OS installed it seems unlikely that load is the problem, and since the unit isn't even in a case yet I'm guessing there's an issue with the temperature sensing.
    I'm going take some measurements via IR thermometer and then try powering a live system with it. Assuming those tests don't reveal any surprises, can anyone suggest how I'd go about troubleshooting this so I can repair it?
    BTW this is the original CWT-built model with the all-blue decals, whereas I believe later revisions were a bit different.
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
  • h0m3w0rk
    Random Shutdowns/Startup Failure with Corsair SFX 450
    by h0m3w0rk
    I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
    For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
    02-09-2025, 03:19 AM
  • harp
    triac phase control 0-100%
    by harp
    Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
    06-02-2024, 09:00 AM
  • tmhobadcap
    Pioneer VSX-522-K remote control not working???
    by tmhobadcap
    I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
    At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
    12-24-2020, 01:44 AM
    Linear Garage Door Opener Control board took a crap install a new control board back normal
    I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
    02-08-2025, 06:52 AM
