Lc-b350atx
  • mikey5791
    • 521
    • Malaysia
    Re: Lc-b350atx
    Hi fzabkar,
    Appreciate your input of maximum power rating on your LC-B250ATX circuit.
    So, this tells me that the supplier label doesn't always give the actual rating.
    Great sharing though.
    • everell
      • Jan 2009
      • 1514
      Re: Lc-b350atx
      Here are some pictures of the L&C B350 ATX completed with output capacitors replaced and sporting a much improved line filter and bridge diode. It is powering my FIC K7MNF-64 motherboard so that is where I will leave it for now. If I were to want to improve it more later, I would beef up the output diodes, especially the one on the 12 volt rail. I would also increase the lone 12 volt output capacitor from 2200 uF to 3300 uF or maybe even 4700 uF. Anyone have a recommendation for the value of the output capacitor?
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Re: Lc-b350atx
        3300uF for 12V would be enough provided it is low esr and not GP.
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          Re: Lc-b350atx
          You used Teapo SC to recap those failed? I hope they measured in spec.
          Nevertheless, good work, as always!
          • прямо
            Viper22A 5VSB circuit
            by прямо
            So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
            In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
            01-13-2024, 07:05 PM
          • kotel studios
            FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
            by kotel studios
            Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
            Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
            I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
            Any ideas where to go next?
            02-23-2025, 11:47 AM
          • mrcliem
            CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
            by mrcliem
            Hello...
            I got my self a dead CM V700 PSU, with nothing on +5vsb
            I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
            As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
            The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
            I have read the datasheet and and still can not...
            06-29-2023, 08:18 AM
          • socketa
            Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
            by socketa
            Rescued this one
            Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
            Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
            The 5VSB drops to 2.5V when it 'shuts down'
            And the voltage across the primary cap falls from 335V to 330V at the same moment
            I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
            12-20-2022, 03:06 AM
          • hobostove
            Corsair RM1000e - Help identify 5VSB Zener diode
            by hobostove
            Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
            Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
            There's a 22ohm resistor that's melted and open, but it still has the bands.
            The other part is a zener diode and it's top went to jesus, so I can't read the marking.
            It looks like the diode connects the source and drain of a TNY284...
            03-27-2025, 02:25 PM
