Imac 24'' (A1225?) PSU bad?
  • Chron-O-John
    • May 2013
    • 15
    • Austria
    I have an Imac (not quite sure about the model) which does not start. When I turn it on the fans start spinning but there is no picture or start sound.
    Diagnostic light 1 & 2 are lit.
    I suspect the Power supply (PA-3241-02A1). It has no visibly damaged parts, but I measured the output and the voltages (under load) seem a bit to low to me.
    Unfortunately I wasn't able to find an exact pinout, but I measured 11.8 and 2.6 Vols on some pins.
    From what I read there should be 12 and 3.3 volts.
    Any suggestions what the culprint could be before i start to desolder all FETs and Caps (well most of them could stay in circuit) in order to measure them.
    Thanks for your help!
    • 31163
    Re: Imac 24'' (A1225?) PSU bad?
    did you check the battery first? just wondering.
    • Chron-O-John
      • May 2013
      • 15
      • Austria
      you mean the Cr2032 battery?
      Should be OK. Has 3.05 volts.
      • tester272001
        • 91
        How about pull the battery and do a PRAM reset ? Those old mac has a reset button.
        • Chron-O-John
          • May 2013
          • 15
          • Austria
          already did that, unfortunately no success
            • 31163
            lets see some psu foto's then
            • Chron-O-John
              • May 2013
              • 15
              • Austria
              Thanks for your replies so far, here are some pics.
              I already measured all Caps in circuit using an ESR-Meter. All of them seem ok to me (in fact they have a suprisingly low ESR)
              ESR is between 0.02 and 0.8 depending on Capacity and rated voltage.
                Apple iMac 24 A1225 K51 Schematic & Board View
                051-7973
                051-7840...
                10-02-2024, 02:08 PM
              • MikeCebula
                Apple 24" iMac A1225 Liteon PA-3241-02A1 schematic and boardview
                by MikeCebula
                Request schematic and possibly boardview for Apple 24" iMac A1225 Liteon PA-3241-02A1
                Thank you,
                Mike
                11-04-2023, 10:18 PM
              • Loretto
                Samsung SMPS BN44-00339A
                by Loretto
                this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
                I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
                I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
                I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
                03-29-2025, 08:30 AM
              • Loretto
                by Loretto
                03-28-2025, 10:28 AM
              • ryogadan78
                iMac A1418 - No LED, no power after overvoltage on Ethernet port
                by ryogadan78
                Hi guys, I need your help again.
                I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                06-10-2025, 03:49 AM
