Mini split PFC baord repair assistance.
  • milkman6453
    HVAC
    • Mar 2015
    • 39
    • usa
    Hello! I just acquired a new project! It is a Grunair mini split(off brand junk)
    I was hoping that i can get the board repaired.
    So far i have taken photos of and identified two burned parts.
    They are as follows
    https://www.digikey.com/product-deta...23-5-ND/865299
    http://www.digikey.com/product-detai...F%29-ND/871322
    My plan is too replace these two parts as well as test the three large caps on the board. I was wondering if anyone had any advice on whether i should replace anything else? (or how to test them.)
    No burn marks or anything obvious on the other board.
    Here is the manual
    Here are the photos.
    http://imgur.com/yUVnOEx,BY7Powa,TN03yEO,UhN23OB
    there are four images in this link, you can cycle through them at the top.
    Thanks,
    Milkman
  • milkman6453
    HVAC
    • Mar 2015
    • 39
    • usa
    Re: Mini split PFC baord repair assistance.
    on photo 1 there is another burnt component to the left of the white square part is a black cylinder with 3 prongs. It is burnt up. Cant identify it.
      That 3-leg device can be either Transistor or more likely to Programmable shunt regulator IC such as xx431.
      There should be printing on the flat side of the body.
      • milkman6453
        HVAC
        • Mar 2015
        • 39
        • usa
        i found out it was a transistor(first in circuit Q1)
        I attempted to de-solder it. ended up breaking it!! The face reads br9013 h r07t
        • milkman6453
          HVAC
          • Mar 2015
          • 39
          • usa
          ive got the other components out and the transistors legs without damaging the board. Im going to wait a bit for more input until i make the purchase on new components.
          Im still not sure what transistor to buy, any help is greatly appreciated!!
          this is the closest info on the transistor i can find
          http://www.datasheetcatalog.com/data...1/3/9013.shtml
            • 31071
            do you have to use image hosting para-sites!
            upload the image here.
            also, give full details of what it's from - maybe a schematic exists.
            • milkman6453
              HVAC
              • Mar 2015
              • 39
              • usa
              the schematic is in the manual on page 13/14 so is the model number of the mini split..
              Unfortunately i couldn't upload my images here as they were WAY to big and good quality. Thats why i used imgur, which is a fairly respectable site.
              • milkman6453
                HVAC
                • Mar 2015
                • 39
                • usa
                here are the photos on badcaps!
                • milkman6453
                  HVAC
                  • Mar 2015
                  • 39
                  • usa
                  also the reason i think it blew is a lizard was on the "IC OFFLINE SWIT" part. http://www.digikey.com/scripts/DkSea...52480985888806
                  I cant see any fuses so it might have just blown other stuff up.
                    • 31071
                    in that first foto, the track on the smd resistor R106 is missing!!!
                    • milkman6453
                      HVAC
                      • Mar 2015
                      • 39
                      • usa
                      here is a picture of the rear of that track.
                        • 31071
                        not the blue bit, the red bit!
                        • milkman6453
                          HVAC
                          • Mar 2015
                          • 39
                          • usa
                          Ah! i see that, perhaps this board is for more than one unit. This model has units that can run 1 2 3 or 4 heads. Perhaps the boards were roughly the same minus some small stuff like that? or bad QA?
                            • 31071
                            looks removed to me!
                            • milkman6453
                              HVAC
                              • Mar 2015
                              • 39
                              • usa
                              how do i go about repairing it? Would a small electrical fire/explosion tear it off? Thats what happened on the top of the board and by the transistor i removed.
                              • milkman6453
                                HVAC
                                • Mar 2015
                                • 39
                                • usa
                                https://www.acwholesalers.com/Grunai...HXB-3/34381.ac
                                that is the best photo i can find of a "new" board.
                                The only differenc ei can see is the large caps on this one are silver on the bottom/top.
                                • sententia
                                  • Oct 2013
                                  • 269
                                  • Greece
                                  If you check the 2nd photo in badcaps, resistors R20 and R40 look like there is a bit missing on top. Check those as well for correct resistance.
                                  Also above R20 and on R21 label is there a cut on the track or just dirt?
                                  • milkman6453
                                    HVAC
                                    • Mar 2015
                                    • 39
                                    • usa
                                    the material on the resistors came off revealing the numbers beneath.
                                    Attempted checking resistance, failed. I assume i have to remove from circuit.
                                    Thank you for your input!!
                                    • sententia
                                      • Oct 2013
                                      • 269
                                      • Greece
                                      If you cannot measure any resistance on circuit, then they are definitely open. Usually material breaks due to temperature when they burn..
                                      • milkman6453
                                        HVAC
                                        • Mar 2015
                                        • 39
                                        • usa
                                        I haven't removed them yet.
                                        Although, there was a laminate type material over the resister pads. I scrapped them up a little and now can get a in circuit reading on each of them
                                          HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                                          This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:36 PM
                                          HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                                          This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 02:20 PM
                                          HP 260 G2 Desktop Mini PC i5-6200U Specification for Upgrade or Repair
                                          09-12-2024, 02:15 PM
                                          HP EliteDesk EliteDesk 800 65W G2 Desktop Mini PC EliteDesk 800 i5-6500T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk EliteDesk 800 65W G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk EliteDesk 800 65W G2 Desktop Mini PC boardview and EliteDesk EliteDesk 800 65W G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-12-2024, 03:44 PM
