Samsung lcd 46" pd46b1qe_cdy blowing fuse
  • spencer13
    • Jul 2015
    • 13
    Hi everyone hope somebody can help me? I'm having trouble with my Samsung lcd, the problem came from my electric tripping out at the main consumer box after some electric alterations for my shed.
    The TV wouldn't come on and I had the standby light flashing and a ticking noise like it wanted to start up but couldn't, I checked the capacitors and none were bulging or leaking but I replaced them anyway.
    After reinserting the power board and powering up the ceramic fuse blew with a big spark. This resulted in nothing happening and no standby light anymore.
    I bought a second hand board and inserted it and the fuse on the new board blew and took the green part at the side with it I think it's called a thermistor.
    Iv soldered the thermistor on my old board into the place of the blown one and tried again to insert the power, the fuse blew again but the the thermistor seems to have survived.
    I'm ok at soldering and like to give things a go myself before giving in and paying a bucket load of money to a repairer so can anyone tell my what the problem could be? I also have a voltage tester to hand so can do whatever is asked of me to get this TV working again!
    Thanks everyone for reading this and hope you can help me
    Spencer
  • spencer13
    • Jul 2015
    • 13
    Re: Samsung lcd 46" pd46b1qe_cdy blowing fuse
    Added some pics of what I have
    • spencer13
      • Jul 2015
      • 13
      And another
        • 31055
        your "new" board was faulty to begin with.
        the rectifier under the heatsink is probably shorted.
        check for shorts between any of those 4 wires you can see in the foto sticking out from under the heatsink.
        your old board was probably bad startup capacitors.
        • spencer13
          • Jul 2015
          • 13
          Hi stj, thanks for the help, do u have a pic of the part I need to be looking at? Sorry I'm bit of an amateur!
          • spencer13
            • Jul 2015
            • 13
            Is this the heat sink you mention?
            • spencer13
              • Jul 2015
              • 13
              Been to my local maplin but they don't have the part, found it on eBay so I await the delivery. Do you think it's going to be just that part or more stuff need replacing?
              • spencer13
                • Jul 2015
                • 13
                Right, got the part, fitted it, blown again soon as the power supply plugged in with a massive blow. Any other ideas please anyone help ?
                  • 31055
                  dont you own a meter?
                  • spencer13
                    • Jul 2015
                    • 13
                    Yes I do
                    • spencer13
                      • Jul 2015
                      • 13
                      Not sure where to check stuff tho
                        09-07-2024, 05:50 AM
                      • stav242
                        Samsung BN44-006056A Blowing Mains plug fuse.
                        by stav242
                        ive picked up a Samsung UE32F5500AK TV with a BN44-006056A power pcb.
                        It was reported as `blowing the fuse` - the 3A one in the plug.
                        on quick inspection of the power pcb, a ceramic capacitor CM802 has blown apart.. photo attached.
                        Ive found a PDF of the circuit schematic and can identify the neighbouring components (RM801, RM802) but cannot find CM802 on the schematic.
                        Can anyone identify what CM802 is ?
                        thanks.
                        S....
                        12-30-2021, 10:45 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
