My Favorite Things
  • everell
    • Jan 2009
    • 1514
    My Favorite Things
    This thread is from the song These are a few of my favorite things in the movie Sound of Music.
    I was at the Disabled American Veterans thrift store a few days ago, and found a EMachines T2865 for $9.98. The case looked like brand new, clean shiny paint and no dents. I figured the case was worth that much. When I opened the case, I found a Bestec ATX-250 12E power supply. My first thought was 5vsb overvolt problem and complete destruction of everything inside. Since the very first power supply I worked on was the Bestec 12E, I opened it up to take a look see. No blasted capacitors and nothing looked burned. So I applied power to measure the 5vsb with no load. To my surprise, it was 5 volts. To be on the safe side, I installed a different power supply and fired up the EMachines computer. It displayed an error message, black screen with white letters, this computer cannot run 64 bit application program, use 32 bit application program. Someone probably tried to load a 64 bit Windows program. So I put a Ubuntu 10.04 disk in the CD reader and loaded Ubuntu. Now everything works fine. AMD 2800 cpu, 160 gig hard drive, and NVidia chipset. Not bad for ten bucks.
    As for the title of the thread, The Bestec 12E is now one of my favorites. I spent lots of time studying it and modifying my first one. So I decided to fix this one up also. Dug out all my old drawings and notes. Replaced all of the capacitors with Nichicon PW except the two input capacitors. Gutted the two transistor 5vsb circuit and replaced it with a DM311 chip circuit. Added a circuit for the LED indicator on the back of the case. Also added the extra fan which runs when the 5vsb is on but the computer is off. It ran fine when powered up for the first time.
    I am sure many of you have a favorite power supply. So here is the thread to tell us about it.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: My Favorite Things
    As always, nice work everell. Man, I really have to try your DM311 mod. I bought two chips a way while back... like over 5 years ago and still have not built it. Then again, I do have more power supplies than I can use right now. So the one PSU I wanted to try the DM311 mod on is on the back burner.
    Now as far as favorite PSUs... I can think of two from the top of my head:
    HiPro HP-P2507F3P (the unstoppable 250W tank)
    Macron MPT-301 or MPT-401
    The HiPro above really is overbuilt and under-rated, and rarely ever breaks. Even with its original crappy caps, it will still deliver many years of service. Probably my favorite PSU when it comes to "install it and forget it".
    The Macron I like for a different reason. The caps in them are terrible and always bulge or go bad... but the PSU itself is extremely simple, yet wonderfully engineered . Everything is put together nicely, so that it can be easily taken apart if it ever needs servicing (which it always does due to those caps): AC connector on the board, fan connector, and fuse with fuse holder.
    But it gets better than this. First off, this PSU is a great performer. Rock-stable voltages, quiet operation, and the PSU runs fairly cool. Oh, and have a look at this (especially you, everell ): the 5VSB is a "dreaded" 2-transistor design. Yet, it is 100% stable and never seems to be the demise of these PSUs. No "critical" cap either. Moreover, 5VSB has its own output rectifier mounted on the secondary heatsink (usually a TO-220 part), along with two 2200 uF caps for filtering.
    This PSU is pretty much a tie now with the HiPro above, and probably my most favorite PSU in terms of servicing.
    • mockingbird
      • Dec 2008
      • 5484
      Yes, me too. I am now in a place where I would be very comfortable trying your mod.
      Great job, btw. What is that blue Nichicon 16V 1000uF on the secondary?
      • everell
        • Jan 2009
        • 1514
        A few of the small capacitors were replaced with some Panasonic FC capacitors I had on hand. All of the larger ones are Nichicon PW. The 1000uF/16 volt is a Nichicon PW, but the lighting in the picture came out somewhat blue.
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          Most favorite PSU: The one in my main computer.
          Permanently Retired Systems:
          Kooky and Kool Systems
          sigpic
          • everell
            • Jan 2009
            • 1514
            Originally posted by momaka
            .....I do have more power supplies than I can use right now......
            You should see what is in my attic now!
            Had a stroke last Tuesday and am still in the hospital. Still don't know all of effects yet, but still having vision difficulties. Don't know when I will be able to work on power supplies.
            • mockingbird
              • Dec 2008
              • 5484
              Sorry to hear about that everell.
              I hope you have a complete recovery.
              • Wester547
                • Nov 2011
                • 1268
                • USA.
                That's dejecting news! Here's hoping your recovery is very swift!
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  I'm sorry, Everell...
                  Too much bad news on BCN- first Junk Parts, now you.
                  I'm sure you already realize this, but try not to focus on this and turn it into a "loss" that you beat yourself up over.
                  Every day's a new one, and you're still here with us!
                  Here's to a full and speedy recovery.
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                  • everell
                    • Jan 2009
                    • 1514
                    Thanks guys. It hit my left hand and leg, but they are recovering nicely. Physical therapy already has me up and walking. It also hit my eyes causing double vision. This is the problem that is most frustrating. I am told that recovery may happen but will be very slow. I am thankful that I have had NO pain throughout the ordeal, and had NO bleeding in the brain. Cognitive tests indicate that the cognitive area was not hit and is OK.
                    I still think age 66 is too young for a stroke.
                    Sorry for the distraction on the thread title.....this was supposed to be for favorite things.....favorite power supplies.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Well, that's some good news at least. Glad to hear.
                      My favourite PSU in terms of it's indestructible-ness is the Delta DPS-600MB. I also quite like the Hipro HP-D3057F3H, as they are fairly easy to work on, and also seem to be a pretty reliable PSU after a recap and re-lube of the fan.
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Sorry to hear that everell I wish you the best. Nice to hear that you're recovering!
                        I too am a big fan of those older Bestec PSUs but unfortunately the brown glue drives me so insane that I unfortunately pass on most of them nowadays.
                        I'll probably get some flack for this, but I'm a huge fan of simple and reliable. I really like the beefy versions of the Sun Pro AT-2005B platform. They're super easy to work on, easy to acquire, have good ripple, are very quiet, and can output adequate power for most systems, like this one: https://www.badcaps.net/forum/showpo...postcount=1792
                        and I also LOVE Macron power supplies, such as https://www.badcaps.net/forum/showpo...postcount=1786
                        and
                        https://www.badcaps.net/forum/showpo...66&postcount=1
                        I'd say my favorite PSU I own is identical to this one that momaka posted: https://www.badcaps.net/forum/showpo...postcount=2352
                        I have a few of these running, they're great units.
                        In summary:
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          I was given a Dell Dimension 2400 with a Pentium 4 Northwood 2.6 Ghz.
                          It has a 200 W Delta PSU with guts that look like a tank!
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • TechGeek
                            Computer Geek
                            • Jan 2015
                            • 2254
                            ^I think I have the EXACT same Dell you have!!!
                            sigpic
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Last I checked, it was this:
                              https://www.badcaps.net/forum/showpo...6&postcount=22
                              And you say you have more now?
                              That is terrible. I wish you a quick and painless recovery.
                              Well, maybe you can't work on PSUs now... but at least it is summer and the weather is nice. Perhaps take the time to enjoy some good outdoor air .
                              • everell
                                • Jan 2009
                                • 1514
                                I am back from the hospital. hand, leg, and foot about 90% recovered and up and walking. Eye doctor put a special prism on my eyeglasses - right side - which corrects the double vision. He says it will probably improve within the next 3 to 6 months. I hope so! Went back to work, Tuesday half a day, and full day Wednesday thru Friday.
                                Took a quick look in my attic and found a HiPro HP-D3057F3R, which is c_hegge favorite. Guess I will make it my next project. Opened it and found only one bulging capacitor so far. I will have to remove it completely from the case to get a good look at it. It looks so much better than those IMicro power supplies!
                                • TechGeek
                                  Computer Geek
                                  • Jan 2015
                                  • 2254
                                  Good to hear!
                                  sigpic
                                  • LDSisHere
                                    • May 2012
                                    • 727
                                    • U.S.A.
                                    Hello, it has been quite some time since I posted on here on BadCaps, too many things to do and not enough time to do them. I was sad to hear about Everell's stroke but very glad he is making a strong recovery.
                                    My favorite power supply is one that works really good for a long time. That being said, it would seem my favorite ones to tinker with are the old Antec Smart Powers that always seemed to be stuffed with those Fuhjyyu capacitors. I am not sure why I like them other than they seem like decent units in need of good capacitors and they are not especially hard to work on as long as you are careful not to lift the tracks.
                                    • mockingbird
                                      • Dec 2008
                                      • 5484
                                      LDisHere -
                                      I thought about you while you were away. How have you been?
                                      • LDSisHere
                                        • May 2012
                                        • 727
                                        • U.S.A.
                                        Hello Mockingbird,
                                        I have been doing OK, and yourself? I am actually surprised anyone noticed my absence. I am going to try to get back to reading and posting here again on a regular basis or at least as much as I can. I have a few power supply projects I want to work on but I have a few other projects in front of those. I usually spend most of my spare time working on family and friend projects so that leaves little time for my own.
                                          ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 10:50 PM
                                          ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 11:05 AM
                                          ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 07:07 AM
