Chieftec HPC-360-202 PSU
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Hi
    Have tested it with two types of PSU tester (FWIW).
    The first PSU tester does not report any problems.
    The second, however, beeps an flashes a problem with +5VSB, that is the
    PSU tested has an LCD display and details voltage rail readouts.
    What are the views of forum members - are these any good?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Chieftec HPC-360-202 PSU
    a new one should be ok for 3 years or so then if its anything like the 3 i have here will bulge the cap shown in the first link and develop a significant buzzing sound which remains after replacement of that bad cap. The ones i have do not have LCD though.
    https://www.badcaps.net/forum/showthread.php?t=2237
    https://www.badcaps.net/forum/showthread.php?t=1153
    They are made by http://www.highpowersupply.com/ and i guess similar to fortron.
    • JEWilson
      • Sep 2007
      • 369
      Sorry bout the misunderstanding. My mistake.
      I have two new PSU testers, the new(est) has an LCD readout
      The PSU I rec'd and treated as being in an unknown condition.
      No LCD readout on the psu - might be a good sales gimmick
      all the same erm... or is that finely engineered diagonstic
      PSU features!
      Seems you have done most of the work on this PSU type already
      per the thread in prior post - thanks.
      I will do a phy. inspection and post a BOM here for the electrolytics
      in the primary, inverter and filter - at least then anybody else can
      use it for reference.
      Of course, in production suffice it to say, from run to run the
      BOM will very likely change and more likely still, go down in
      quality terms in the pursuit of profit as well as due to supply
      chain fluctuations.
      May be of some help even so.
      Seems I require to get myself an ESR meter as well.
      I usually use panasonic FM for mobo regaultor recaps.
      Are FCs for PSUs a good choice?
      Any help, insight and advice greately appreaciated - thanks
      • JEWilson
        • Sep 2007
        • 369
        Just another question
        The fan. I did wonder as to why it was so quiet.
        Whatch'er reckon? Replace it or leave it?
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          FCs are good for this but maybe you have probs with diameter if you are buying from RS etc.
          fan is adequate, can replace if you prefer not so hot. cant remember if fan is getting 12v from this psu. if not then connect directly to 12v. much noise though with some types of fans running on 12v. I replaced fan on one of these units with stronger one and get same capacitor failure as other 2, go figure.
          esr meter is very useful
          capacitance meter could be useful also
          multimeter and some good load on the psu better than your psu tester method
          • JEWilson
            • Sep 2007
            • 369
            Have a Fluke 175 for cap testing - don't think this does ESR though.
            I have seen a kit - design by a Bob Cater, kit supplied by Dick Smith
            Electronics or EVB (as pic'd in your thread). Is this a good option?
            These seem cheaper in the US than Canada or the UK taking
            a quick peek at a eBay that is.
            As to loads, I have thought about constructing a dummy load
            but if this is too much hassle might just buy one instead and
            save hassle over the long term.
            Any of the forum members views on construcing a decent
            dummy load?
            I've opened up the unit and do not immediately see any cap
            distress - paid particular attention to the cap as you have
            detailed in your own diagnosis. The unit is very clean inside.
            I do recall I had some FCs spare. The dia is fine. Certainly have 16v 1000uF
            Also, my PSU has the primary sub pcb toasted a
            good deal more than your pics and still does not have any
            insulation. It is heated to the extent you can see the glass
            fibre substrate on the board - me thinks bad!!
            Is this a problem? I took a good look at the two main primary
            electrolytics and though for a moment one was beginning to go bad
            as it has a slight bulge but this may be just the plastic cover.
            On the sub pcb there are 2 Teapo 2.2uF 400V with cans
            as H 10mm dia 7/8 mm - these appear to be fine.
            The heating is from the two power resistors on the sub
            pcb being too close to the substrate, possibly a production
            construction error and reflects the relatively poor cooling
            I observered with the fan. See further (bad) pic attached.
            Of course, if any of the caps have gone dry and exhibit
            poor ESR - its : err... take your pick unless I just replace
            the lot!
            As the PSU testers indicated a possible +5VSB standby
            issue, might the problem be aging and drift? I see from the
            +5VSB section, there is a trimmer pot VR1, cap C37 and beside
            it a power res and beside that, a coil L10 just behind the C36 you
            replaced.
            The fan is connected to CN2 and has, what I believe to be an
            FCA connector for a mobo header.
            The phase corrector on this PSU has insulation in the correct palce.
            So... next steps? Suggestions please
            • JEWilson
              • Sep 2007
              • 369
              Sorry
              Forgot the pic - see attached
              As it appears these have problems with +5V and +5VSB due to
              bonding the O/P cap to the load resistor, start my search there
              by replacing cap - C37
              BTW, BOM as best as I can figure below
              Electrolytics Only
              In the primary;
              2 of Black 680 uF 200 V Teapo 85 deg C - H 45 mm x Dia 20 mm
              2 of Brown 2.2 uF 400 V Teapo 105 deg C - H 10 mm x Dia 8 mm
              In the switcher;
              1 of Black 1000 uF 16 V Jenpo 105 deg C - H 20 mm x Dia 10 mm is C36
              1 of Black 22 uF 50 V Jenpo 105 deg C - H 8 mm x Dia 3 mm
              1 of Black uF V deg C - H 8 mm x Dia 5 mm
              2 of Brown uF V deg C - H 8 mm x Dia 3 mm
              In the PFC phase correcter;
              1 of Black 10 uF 50 V Jenpo 105 deg C - H 8 mm x Dia 3 mm
              In the output filter;
              1 of Black 0.47 uF 50 V Jenpo 105 deg C - H 8 mm x Dia 3 mm
              2 of Black 1 uF 50 V Jenpo 105 deg C - H 8 mm x Dia 3 mm
              2 of Black 3300 uF 6.3 V Jenpo 105 deg C - H 25.4 mm x Dia 10 mm
              1 of Green 3300 uF 10 V 105 deg C - H 30 mm x Dia 10 mm
              1 of Black 2200 uF 16 V Jenpo 105 deg C - H 25.4 mm x Dia 10 mm
              3 of Black 10 uF 50 V Jenpo 105 deg C - H 8 mm x Dia 3 mm
              2 of Black 470 uF 16 V Jenpo 105 deg C - H 15 mm x Dia 8 mm 1 is C37
              The rest as far as can I determine, are bead type caps
              • JEWilson
                • Sep 2007
                • 369
                Sorry...
                I see Teapo are found in the bad caps list.
                What's the story for Jenpo? Are these any good?
                Thanks for any advice, insight and help
                • jvschie
                  • Nov 2007
                  For whom this might help:
                  I repaired one of this unit today. It didn't have 5VSB.
                  At first instance it appeared that only FET Q10 died, but after further analysis I saw that under C36 (1000uF/25V KMG brand) the PCB was black and that D14 (zener 6v3) was broken.
                  After I replaced Q10, C36 and C37 (470uF/16V TEAPO brand) (just in case), the 5VSB seemed to work again, but the tension was too high and there was noise on it. This was caused by a dried-out C34 (22uF/50V JENPO brand) on the primary side. After replacing it, the 5VSB became OK. After replacing D1 the job was done.
                  The end conclusion is that probably a bad C34 from JENPO was the cause of the problem.
                  • linuxguru
                    • Apr 2005
                    • 1564
                    In some of these topologies, the small primary side 22uF/50V cap on the auxiliary flyback can be upgraded safely to a higher quality 47 or 100uF cap with improved durability. I have found the 100uF/35V NCC LXA to be a good replacement, but there are numerous other choices.
                    • severach
                      • Aug 2007
                      • 1055
                      Most of the beep codes in the LCD tester are obvious. There is one that is not obvious and I think it's when Power Good shows less than 270ms.
                      sig files are for morons
                      • JEWilson
                        • Sep 2007
                        • 369
                        Hi
                        I have recently recapped this PSU as with;
                        +5VSB Rail
                        1 of 470uF 16.0V 105 deg - done, replaced with Panasonic FC
                        +5V Rail
                        2 of 3300uF 10.0V 105 deg - done, replaced with Panasonic FC
                        +3.3 Rail
                        2 of 3300uF 6.3V 105 deg - done, replaced with Panasonic FC
                        +12V Rail
                        1 of 2200uF 12.0V 105 deg - done, replaced with Panasonic FC
                        Powered up
                        Tested with PSU Tester2 (the one with LCD readout) - go/no-go test.
                        Found +5VSB voltage sits at 5.8V, above upper regulation threshold of 5.25
                        Tester 2 readouts;
                        +12.0V1 : 12.1 V ATX 20 pin ok
                        +12.0V2 : 12.1 V ATX 4 pin ok
                        + 5.0V : 5.2 V ok
                        + 3.3V : 3.4 V ok
                        - 5.0V : Unknown
                        -12.0V : 11.7 V ok
                        + 5.0V SB : 5.8 V - out of regulation
                        PG : 330 mS
                        Appears C34 in this PSU like jvschie found has gone, my ESR meter reads 62 ohms.
                        All the same the +5VSB has not gone entirely as can be seen but is
                        out of regulation.
                        As linuxguru states, I will replace this cap with something more reliable.
                        I have in mind a 100uF 35V Panasonic FC albiet the can is a bit
                        on the large size, that is, 8.0 mm dia, 11.5mm len, 3.5mm lead pitch.
                        Will check out the semiconductors also
                        • DynaxSC
                          Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
                          by DynaxSC
                          I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
                          I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
                          Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
                          Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
                          05-04-2025, 12:08 PM
                        • cheebster
                          LG OLED55CX Clicking No Power
                          by cheebster
                          Hello, i have this OLED here, as the topic says OLED65CX.
                          TV shows standby led, when pressed the PSU clicks, then shut down.
                          Disconnecting the 12V VIN from the T-Con, make the TV boot up, led flashes like normal and it stays on.
                          What i've tried so far:
                          I have a working TV, an OLED55C1. Similar TV... Took all the boards to the C1, 1 by one, and everything works. So basically, all of these boards from the defective CX (PSU, Main, TCON) works either 1 by 1, or together on the working C1.
                          However, none of the C1 boards work on the CX,...
                          01-20-2025, 06:52 PM
                        • MD HOST
                          Esonic H61 FFL ES Original Tested Bios Bin File
                          by MD HOST
                          100%tested.
                          Enjoy......
                          10-11-2024, 11:38 AM
                        • lmcancu
                          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                          by lmcancu
                          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                          Instead of putting it back together I decided to replace...
                          04-01-2023, 01:11 PM
                        • triplefour
                          TCL 75S421 has sound but no backlight not even a flash
                          by triplefour
                          TCL 75S421
                          PSU BOARD: 40-L402H8-PWD1CG
                          it shows not even a flash of backlight when powering up.
                          but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                          testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                          unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                          i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                          with mb connected, PSON...
                          11-17-2023, 09:54 PM
